rubbing/grinding noise on startup, chevy says its NORMAL!?!? - Chevy Colorado & GMC Canyon
post #1 of 16 (permalink) Old 10-07-2009, 12:11 PM Thread Starter
My truck is making a wierd metallic rubbing noise on startup, it usually does it at low speed right as it passes 2000RPM. the dealership claims its just from oil pressure bleeding off, and that it is NORMAL. WTF? anyone have insight?
06 EC WT 2.8L I4 3.73
Tint
Sony CDX-GT300 HU
BAJA foglamps
Deezee toolbox
Hunter Grillgaurd (now removed)
GM bedmat
Billet Grill overlay
Z71 rims w/ BFG 31x10.5 All Terrains
Pioneer TS-G671M speakers
Silverado Overhead console
My Cardomain
superbeast is offline
post #2 of 16 (permalink) Old 10-07-2009, 12:24 PM
CanyonAB's Avatar
Re: rubbing/grinding noise on startup, chevy says its NORMAL!?!?
Could it be a loose heat shield?
1964 Chevy Impala Convertible, mostly stock, 90,000 miles
2005 GMC Canyon CC 3.5L Offroad 4x4, lots of mods
http://canada355.com
-Branden
"Stupidity is like nuclear power...it can be used for good or evil...and you don't want to get any on you"
CanyonAB is offline
post #3 of 16 (permalink) Old 10-08-2009, 09:40 AM
i have the same problem my truck is dual catted and they say the the cat right aft of the engine is causing the problem it was the heat sheild on the cat causing the proble but being that mine is welded i would have to buy a new exhaust to fix it i hope this helps but i would look at your cats
2005 chevy colorado ls
22 in matzi kraz rims
3 in drop kit
lite glow underglow and interior kit
hid headlight strobe kit
engine bay strobe kit
kenwood kvt 512 dvd player
dropped 3 in all around
3 15in american bass xo subwoofers in cab
4 6in mid speakers 4 high range tweeters 4 6.5 in mid to high speakers
custom painted interior
cold air intake
killer glass radiator tube
oogah horn mod
falken tires
x box 360 console
surferengineer is offline
post #4 of 16 (permalink) Old 10-08-2009, 12:52 PM
Can you get a sound clip?
post #5 of 16 (permalink) Old 10-08-2009, 01:02 PM
The big heat shield over the manifold itself is held on with 4 studs/nuts. For the small heat shield just below the cat where the manifold bolts to the rest of the exhaust, if the welds are broken, use a large hose clamp to fix the problem.
post #6 of 16 (permalink) Old 10-09-2009, 12:09 PM Thread Starter
it only makes noise at 2000rpm though, if it was the heat sheild, shouldn't it be rattling in general
Tint
Sony CDX-GT300 HU
BAJA foglamps
Deezee toolbox
GM bedmat
My Cardomain
post #7 of 16 (permalink) Old 10-09-2009, 02:52 PM
Not necessarily. Has to do with harmonics, only at a certain rpm you get the rattle.
post #8 of 16 (permalink) Old 10-09-2009, 10:43 PM
its could be your ABS MAKING ITS SELF ADJUSTMENT TEST.if noise goes away if you dont restart truck after driving it,it is ABS .you can pull both ABS fuses before you start truck ,then drive to your 2000 rpm,if noise goes away, its YOUR ABS TESTING ITSELF.
the 2 fuses are on drivers side of engine near battery,1 is 30 amp other 40 amp.
i would bet that is what you are hearing.i had dodge dynasty that did this also,just before it shifted to 2nd you would hear, SNAP/CLICK.my new 2009 colorado does it too at about 8 mph after STARTING only.any other time its quiet as mouse.
isnt it great that our dealerships cant find this.my mechanics said, NOTHING WRONG,CANT FIND IT.today i took my info down and said, ITS THE ABS DOING IT.
sproulman is offline
post #9 of 16 (permalink) Old 04-02-2010, 09:03 PM Thread Starter
ill have to check the abs, ive noticed the noise occasionally while driving, but its so slight, its hard to hear it at speeds above 20mph,
Tint
Sony CDX-GT300 HU
BAJA foglamps
Deezee toolbox
GM bedmat
My Cardomain
post #10 of 16 (permalink) Old 04-02-2010, 10:13 PM
As it's passing 2000rpm, your heatshield would start to vibrate. This has been an issue several members have noticed before. Let me find another thread on it for you.
Sparky87 is offline
post #11 of 16 (permalink) Old 04-03-2010, 07:55 AM
My 2004 C/C canyon 4x4 does the same thing ! It's a heat sheild vibration caused by harmonics at certain speeds /rpms. I've talked to a bunch of owners of all years 355's and alot of them do it. As said above some good hose clamps in the right places should fix this. Good luck!
2004 GMC CANYON Z71 4x4 CREWCAB
canyondave 57 is offline
post #12 of 16 (permalink) Old 04-03-2010, 08:17 AM
linky linky!
http://coloradofans.com/forums/viewt...rattle&start=0
Sparky87 is offline
post #13 of 16 (permalink) Old 04-03-2010, 09:27 AM
its annoying, but found my cause. as said check each shield.. only 2 corners of mine was rotten so it wouldn't rattle till 2000 rpm..
mine was right on the front pipe in the curve from the manifold to the cat.. behind the front cross member..3 inch hose clamp solved mine...hope you find yours...
05 offroad/31's/airlift/custom slidein camper/k&n filter/custom 5 leaf spring pack.
2 1/2 yrs of owning and still enjoying it..
mazdab2600 is offline
post #14 of 16 (permalink) Old 04-14-2010, 08:45 PM Thread Starter
so, check the heatsheild along the exhaust?
Tint
Sony CDX-GT300 HU
BAJA foglamps
Deezee toolbox
GM bedmat
My Cardomain
post #15 of 16 (permalink) Old 04-14-2010, 09:19 PM
yup!
Sparky87 is offline
post #16 of 16 (permalink) Old 04-19-2010, 06:18 PM
Xwd
This is not to be confused with the grind on startup, right? The grind that sounds like the engine is starved of oil? My 3.7 has done this on cold starts since new, and I've been told it's normal (something about a tensioner going back into place?). It sounds awful, but GM claims it's not an item of concern or causing any undue wear on the engine.
2009 Chevrolet Colorado Z71 Crew Cab 4x4
Xwd is offline
