Can i siphon gas out of my 2010 5.3? - Chevy Colorado & GMC Canyon
post #1 of 26 (permalink) Old 01-01-2010, 01:19 PM Thread Starter
Just wanted to know if there is a way to siphon gas out of my 2010 5.3 Colorado?
I know years back on older cars and trucks you just jammed a hose in and sucked away.
I will need to remove most all of my 87 when i get a 93 tune done.
CHASLS2 is offline
post #2 of 26 (permalink) Old 01-01-2010, 01:50 PM
Global Moderator
Danny45's Avatar
Re: Can i siphon gas out of my 2010 5.3?
Why not put some octane booster in it until your next fill-up?
Danny
10,000 Posts Club Member #1
Conservative Club Member #2
Danny45 is offline
post #3 of 26 (permalink) Old 01-01-2010, 01:56 PM
why not just run it low then fill it up with 93 run through that tank and then again with 93 then tune.
to answer your question i think that ball thing in there is made to not let you syphon.
LIFTED TRUCK #244, back to stock height
2006 chevy colorado
4 cyl
2wd (1wd)
red
bedliner
toolbox
borla muffler stock pipe
gutted cat
china intake with k & n
aal in rear, also 2 inch block to get near stock height
SUSPENSION MAXX rear 1.5 inch shock extenders
SUSPENSION MAXX Front lift spacer now taken off for now
1 inch body lift, removed
now zq8's with 235/50/17
rear air shocks
bobandcar is offline
post #4 of 26 (permalink) Old 01-01-2010, 02:42 PM
Curt's Avatar
With what software are you doing the tune? I was not aware anybody offered software support yet for the 2010's, only the 2009's with the 5.3's.?
2009 3LT with 5.3, Trueflow intake, Magnaflow exhaust.
2012 3LT Stock.
Curt is offline
post #5 of 26 (permalink) Old 01-01-2010, 03:03 PM
Lot's of cars mfg. recommended for 93 run just fine on 87. Just avoid running the newly tuned 5.3 hard until you fill up with 93.
Just listen for ping and back off if you hear it.
BedRug
Catch-All Xtreme Floor Guards
ZQ8 tailgate decal
Factory foglights added
upflying is offline
post #6 of 26 (permalink) Old 01-02-2010, 04:55 AM
Send a message via AIM to XJDesertFox
i'd make sure youve got 93 in there before you tune it
DDMTuning 55w 5000k lows
Luminics 65w 5000k highs
Luminics 55w Extreme Yellow H3's in Hella 500s
XJDesertFox is offline
post #7 of 26 (permalink) Old 01-02-2010, 05:30 AM
Send a message via AIM to FixxxerKH202
not sure why you just don't drive until the gas is gone then fill up with 93 and then get the tune. Your looking at more trouble than its worth to get the gas out. if you must un-hook your gas line from the fuel pump hook up a new piece it to your gas jug then jumper 12v to the pump or turn the key on(not sure if accessory powers the pump so this might not be an option)
FixxxerKH202 is offline
post #8 of 26 (permalink) Old 01-02-2010, 05:37 AM
just run it really low, then fill with 93
or you could run it really low, put octane booster in, then fill with 93
or if you want to be really cautious do what I said above twice
10 Cobalt SS 2.0 Black T/C
08 Trailblazer SS 6.0 Black AWD
09 Silverado 5.3 Street suspension 4x4 White Regular Cab---Traded In
08 Canyon 3.7 Z71 4X4 Black Crew Cab---Traded In
DavidW is offline
post #9 of 26 (permalink) Old 01-02-2010, 08:19 AM Thread Starter
Here is the problem.
The company i work for buys my gas every week but will only pay for 87 no if ands or butts.
I would sell the reg to a friend for cheaper and replace the gas with 91 or better.
CHASLS2 is offline
post #10 of 26 (permalink) Old 01-02-2010, 09:30 AM
Are you saying that you want to pump it dry weekly? If so, it sounds like you are going to have to mod the gas lines and fuel pump relay circuit. I'd also be worried about wearing out a fuel pump. I have never worked on a Collie fuel pump but if it is like other GM in the tank pumps, it does not like to be pumped dry. The pump uses the gasoline it sits in for cooling. I know in the Chevy Blazer there is a check valve (big ball) in the main filler line making it impossible to run a hose through the filler and into the tank.
post #11 of 26 (permalink) Old 01-02-2010, 12:56 PM
So you drive the Colorado on someone else's dime? In that case, they have a right to tell you what to pump since they are paying for it. How about filling up with 93 but only submitting reimbursement for the cost of 87? You pay the difference?
Or tell the company you will take a pay cut if they let you use 93.
BedRug
ZQ8 tailgate decal
upflying is offline
post #12 of 26 (permalink) Old 01-02-2010, 02:54 PM Thread Starter
It's 87 or nothing. No way around it or paying the diff. I was hoping i suck out most of the gas at home and refill up with 93.
CHASLS2 is offline
post #13 of 26 (permalink) Old 01-02-2010, 04:50 PM
Just get a empty gas tank or buy some empty gas cans, put them in the back of your truck, then fill them up with the 87 octane. Fill your truck up with the 93 octane, then go home and sell the 87 out of the extra gas tank / cans.
2006 Black ZQ8 3.5L LT CC
K&N air & oil filters
PowerAid throttle body spacer
MBRP single side exit stainless cat-back exhaust
Jagsthatrun transmission crossmember
Kenwood KDC-X990 Headunit
Kenwood KAC-X501F - 4 Ch. Amp
Kenwood KAC-X401M - 1 Ch. Amp
Polk DB650 2-way coaxials in front and rear doors
PowerAcoustik Tweeters in front doors
Two 10" Pioneer Premier shallow sub
Custom downfire dual 10" sub box (under rear seat)
Radioshack mini mobile CB hidden in center console
Mobile phone type CB antenna (on back glass)
ScanGuage II
Debadged tailgate
50% tint on front doors and 20% strip on windshield.
SolowCustoms is offline
post #14 of 26 (permalink) Old 01-02-2010, 05:48 PM
This will get "old" pretty fast, Best idea I see is to add octane booster, you can actually make your own if you wish , do a search on the web for a how to..... but your on your own..... I do not endorse ,
100,000 miles on 01/28/13
110,000 miles on 10/22/13
120.000 miles on 07/08/14
130,000 miles on 03/19/15
140,000 miles on 11/19/15
davn is offline
post #15 of 26 (permalink) Old 01-02-2010, 06:38 PM Thread Starter
I would be fired on the spot if i did that. My tuner says he can do a two phase tune that will run on 87 and 93.
I will figure something out.
CHASLS2 is offline
post #16 of 26 (permalink) Old 01-03-2010, 12:58 AM
Fired on the spot? I'm assuming now that you fuel up on company property. If that's the case, I wouldn't have made the suggestion. I just figured they gave you a company fuel card with a P.I.N. / password and tracked your mileage per tank like most other companies.
ScanGuage II
Debadged tailgate
post #17 of 26 (permalink) Old 01-03-2010, 08:13 AM Thread Starter
The company i work for has a account for just one Shell gas station, i am given a sheet of paper with my name and my truck info on it i had over to the clerk. I am allowed a max of 25 gals per week only one fill up per week. I only use around 15 gals a week.
We are not allowed to fill extra gas cans, anyway someone at the station or at work would see the gas cans sitting in the back of the truck. Wished i would install a hidden tank under the truck some how.
CHASLS2 is offline
post #18 of 26 (permalink) Old 01-03-2010, 12:55 PM
Sorry but that is most dumiest thing I have ever heard of.
05 Chevy Colorado
Z71 4x4 Ext cab
I5 3.73 Ratio
FIPK 57 K&N Intake
Flowmaster 40 muffler
Bridgestone A/T
PCMforless Tune
Tranny Cooler
red12 is offline
post #19 of 26 (permalink) Old 01-03-2010, 01:58 PM Thread Starter
I try hard buddy.
CHASLS2 is offline
post #20 of 26 (permalink) Old 01-03-2010, 02:36 PM
What you could do then is (don't know if it's worth the hassle though) relocate your spare tire to the truck bed and install a fuel cell in it's place the run your truck. Then leave your OEM fuel tank and filler neck installed to store the 87 octane, but install a drain plug at the bottom of the tank. And fill up your fuel cell with the 93 you need a different station so the clerks won't catch on. Where there's a will, there's a way.
ScanGuage II
Debadged tailgate
