2004 Colorado rough idle - Chevy Colorado & GMC Canyon
post #1 of 30 (permalink) Old 12-21-2010, 03:50 PM Thread Starter
I have a 2004 5 cyl Colorado that starts and run fine but after short warm up perdiod when I come to a stop the idle drops down and is rough for a few seconds then comes back up and is fine. Once in a while when the idle drops it feels like it's going to die but doesn't, pops back up to normal idle and is fine, anybody out there with suggestions? I did see a service notice a long time ago but was not a recall and referenced the potential for the engine to die on quick stops, related possibly? A few things I've already found is the throttle actuator assembly or update PCM.
jmeyer22 is offline
post #2 of 30 (permalink) Old 12-21-2010, 04:03 PM
2004CrewCab's Avatar
Re: 2004 Colorado rough idle
I would have the pcm updated. When I had mine replaced there were over 170 updates. Also, I cured that very same problem when I had the truck tuned the first time by Canyon08Z71.
That should solve the problem.
2004 CrewCab purchased 07/19/04, sold 04/21/12.
Now down to one 355. The 07 Regular Cab.
2004CrewCab is offline
post #3 of 30 (permalink) Old 12-21-2010, 04:07 PM
Your gas filter should be replaced every 30k miles and the throttle body should be cleaned on around the same mileage, or as needed.
Both are part of the normal maintenance routine for these trucks.
Good Luck...
Joe
2005 ZQ8
Hawkeye is offline
post #4 of 30 (permalink) Old 12-21-2010, 04:11 PM
Good Luck...
Joe
Thanks Joe :D I always forget the simple maintenance in posts like the one I made.
post #5 of 30 (permalink) Old 12-21-2010, 04:14 PM Thread Starter
Thanks for both the tips, will replace fuel filter ASAP as it has quick disconnects and is an easy replacement. Is the dealer the only place to get PCM updates?
jmeyer22 is offline
post #6 of 30 (permalink) Old 12-21-2010, 04:55 PM
:( Sorry to say yes. What you tell them is you found out that GM has updates for your pcm. The service manager will look it up in the system and see you are correct. Then tell the service manager you would like to get your pcm updated. It should cost no more than $150.00 to do it.
post #7 of 30 (permalink) Old 12-28-2010, 01:04 PM
Depending on your mileage, you should think about changing the plugs. My 2005 started having rough idle last year, so I did the normal maintenace and replaced the plugs -- they were nasty at 87k miles.
05 Colorado Z85 LS Ext Cab (I5 M5) in Sunburst Orange :)
02 Honda VTX 1800C
Puzzel is offline
post #8 of 30 (permalink) Old 01-04-2011, 03:29 PM Thread Starter
Based on the replies I have received sounds like a good maintenance overhaul is due, plugs, filters etc.
Thanks
jmeyer22 is offline
post #9 of 30 (permalink) Old 01-04-2011, 04:39 PM
Thanks
That would be a good place to start. And Your .
post #10 of 30 (permalink) Old 01-05-2011, 11:09 PM
clean your throttle body. i have a 04 5cyl it had a rough idle and it would cut off when i came to a stop. take it to a shop and tell them clean the throttle body i had mine cleaned last week and it made a big difference.
cheddabob85 is offline
post #11 of 30 (permalink) Old 01-06-2011, 11:16 AM Thread Starter
Thanks, your the 2nd person to make that suggestion. So guess what I'm doing this weekend!!!!
jmeyer22 is offline
post #12 of 30 (permalink) Old 01-06-2011, 11:31 AM
The TB is not that hard to get to on our trucks. All you need is a standard head screw driver and a 10mm or 13mm socket, and pick up some TB and map sensor cleaner from your local auto parts store. If you do this make sure to get the 2 cleaners. This will save you some bucks and time at the shop.
post #13 of 30 (permalink) Old 01-06-2011, 11:45 AM Thread Starter
Thanks!! Yes, had it apart before so should not be a big deal.
jmeyer22 is offline
post #14 of 30 (permalink) Old 01-06-2011, 12:02 PM
water in the engine? just a suggestion
2008 colorado LS Z71 2wd
K&n Performance intake
magnaflow exhaust
Jet performance module stage 1 tune up
2" Tb crank
springtech 2" rear shackles
31" futura scrambler A/P
mud club member #31
wkrdrd is offline
post #15 of 30 (permalink) Old 01-06-2011, 12:45 PM Thread Starter
I don't see any water signs in oil nor do I get excessive smoke in exhaust. Once I come to a complete stop for a few seconds the idkle is fine, it's just when I first stop that it's rough. Don't even know if rough is the right word, idle drops below normal but then bumps back to normal after a moment of being stopped.
jmeyer22 is offline
post #16 of 30 (permalink) Old 01-07-2011, 12:54 AM
mine seems like it pulses...up down up down up down...not always..but alot and often.....first thought would be plugs...fuel filter...lookin for a for sure..even tho this maintenance needs to be done either way
Raytio32 is offline
post #17 of 30 (permalink) Old 01-07-2011, 12:56 PM
I agree that staying on top of maintenance will prevent a ton of problems.
post #18 of 30 (permalink) Old 01-11-2011, 10:52 PM
Send a message via AIM to cheezheadfan80
I had the same problem with my 04 a couple months ago. I replaced the spark plugs and cleaned the TB and haven't had a problem since.
cheezheadfan80 is offline
post #19 of 30 (permalink) Old 01-12-2011, 12:35 PM
Yes sir The engine loves those new plugs and a clean TB to boot. Nice going
post #20 of 30 (permalink) Old 01-13-2011, 08:55 AM
Mines been doing this for 2 years now, but only in the winter time and if I don't let it warm up good. I'm sure it would go away if I could get up off my lazy butt and do the spark plugs and clean the TB!
Yellow 04 Colorado Z71 3.5L 104,000 mi
Sillver Birch 04 Suburban Z71 5.3L 29,000 mi (Totaled 6/1/07)
White 04 GMC Yukon Denali 67,000 mi
75 Camaro, under construction
Red and White 79 K5 Blazer 131,000 mi
yellow z is offline
