4x4 not engaging - Chevy Colorado & GMC Canyon
post #1 of 20 (permalink) Old 01-27-2011, 08:24 PM Thread Starter
4x4 not engaging
im in Wisconsin and recently we have gotten a nice snow fall and while trying to leave work today i was stuck because my four wheel wont engage. (im parked on a hill for those wondering) now ive tried reading the manual and doing the press the button while in neutral and shifting to park and wait for the light to illuminate, after about 5 minutes the 4hi continues to blink. i checked all the fuses all good to go, i can hear the mechanism moving but it doesnt sound like 4hi shifts, and it continues to blink and it only runs in 2hi
i think it might be ice buildup around the transfer case maybe??
something with the switch in the trans case??
idk, lol any help appreciated
OutDoorDawg is offline
post #2 of 20 (permalink) Old 01-27-2011, 08:26 PM
Send a message via AIM to BADLANDER Send a message via Yahoo to BADLANDER
Re: 4x4 not engaging
search actuator. many of them have gone out
BADLANDER is offline
post #3 of 20 (permalink) Old 01-27-2011, 08:31 PM Thread Starter
the actuator itself?
post #4 of 20 (permalink) Old 01-27-2011, 08:36 PM
barrera82's Avatar
I think if you can hear it, its working. the blinking is just to let you know that it has not enguaged. And I have read in the manuel that you have to be moving to enguage 4-HI but no faster than 10mph. Getting in to 4-Low is tricky. You have to be pretty much be moving just below 2 mph or idle or be in nuetral. One of those 3 but like I said its tricky getting in to 4L. Even going by the manuals instruction.
2012 - 4x4, Reg cab, Automatic, Z85 , 3.73 gears, I-5, 4 inch Rancho Suspension Lift, 285x75 R16BFG KO tires, 058 American Alloy Rims, Aries Off Road Grille Guard, Weather Tech Digi Fit Black Floor Mats, K&N Air Filter, Rancho 5000 shocks, Home Made Reflective Stickers, Horn Blaster Train Horns, 35% Tint, Line-X over the rails, Flowmaster 50 muffler. San Antonio, Texas 78259.
barrera82 is offline
post #5 of 20 (permalink) Old 01-27-2011, 08:39 PM Thread Starter
no i tried even with it blinking, only rears are spinning even though i heard it, ifound some old threads on the actuators and what not, anyone have any diagrams/pics of where all this is at???
post #6 of 20 (permalink) Old 02-05-2011, 11:23 PM
Have you been activating the 4 wheel drive every month or so? It helps alot to do so, as its alot like the muscles we have in our body...if they arent used now and again, ya cant count on em if and when ya need em...
Oregon Colorado is offline
post #7 of 20 (permalink) Old 02-05-2011, 11:25 PM
You should be able to shift into 4 Hi at any speed, but should need to be at a stop and in neutral to engage 4 Lo...
post #8 of 20 (permalink) Old 02-06-2011, 12:07 AM
Yup, you can go into 4Hi at any time.
I think they recommend a very slow speed for shifting into 4Lo. I find it can be finiky at best to get into 4Lo, but have had luck with the truck at a very slow roll with the tranny in neutral.
Also, if you don't use 4Hi or Lo that much it seems to make it worse, at least up here in Canada where it gets cold.
2007 GMC Canyon Z85 4x4 SLE
Bike - 102 CID v-twin. 120 hp/115ft lbs.
Colorado & Canyon Club of Canada member #4
coyote14 is offline
post #9 of 20 (permalink) Old 02-06-2011, 09:25 AM
I never use my 4 wheel drive in the summer and never had a problem.
05 Chevy Colorado
Z71 4x4 Ext cab
I5 3.73 Ratio
FIPK 57 K&N Intake
Flowmaster 40 muffler
Bridgestone A/T
PCMforless Tune
Tranny Cooler
red12 is offline
post #10 of 20 (permalink) Old 02-06-2011, 11:46 AM
Not YET....lol....It's just a good idea to activate it every month or so...The old mechanical transfer cases werent so finicky, but also werent quite as handy...The new units, either a solenoid or a switch can become unreliable without usage...
post #11 of 20 (permalink) Old 02-06-2011, 03:42 PM
Well ill have to keep it in mind. But my 4wd did a good workout this winter.
05 Chevy Colorado
Z71 4x4 Ext cab
I5 3.73 Ratio
FIPK 57 K&N Intake
Bridgestone A/T
PCMforless Tune
Tranny Cooler
red12 is offline
post #12 of 20 (permalink) Old 02-06-2011, 10:30 PM
This winter mine hasnt seen any action, other than once a month, I activated it...Last two winters, it saw alot....I love to use it....Exspecially if its during playtime and not work related....
post #13 of 20 (permalink) Old 02-06-2011, 11:04 PM
ON mine - 2 to 4hi... 4hi to 2 at any speed. For 4lo, I stop, put the trans in neutral and hit the button. No problems. Just a habit I forced my self into so I don't get too impatient to get into 4lo and risk tearing anything up.
"05 Victory Red Z71 Crew Cab
Line X spray in bed liner
15% front side window tint
custom hard Tonneau cover
Westin Nerf bars
Alpine 6 disk changer
Custom dash extension - CD changer control, 5 12v aux ports, light switches
Rear low, mounted work light
1.5" TB crank - To level the truck
MORE TO COME...
glforeman is offline
post #14 of 20 (permalink) Old 02-08-2011, 04:06 PM
[quote=Oregon Colorado]
Not YET....lol....It's just a good idea to activate it every month or so...The old mechanical transfer cases werent so finicky, but also werent quite as handy...The new units, either a solenoid or a switch can become unreliable without usage...[/quote:23z15xci]
Good advise. I always make sure my 4wd is operable every so often, even in good weather. The last thing a guy wants to deal with is an inoperable 4wd when he needs it the most.
05 Z71 I4 Rado /w 4:10 gearing
garyc660r is offline
post #15 of 20 (permalink) Old 02-15-2011, 05:22 PM
I havent had trouble in the 4whi engaging but when i put in in 4wlo it slams into sounds like someone hit the hub with a hammer! any ideas?
maverickdave is offline
post #16 of 20 (permalink) Old 02-20-2011, 05:52 PM
Mine is a bit loud also, going into 4 Lo...I just figure it as being normal.....
post #17 of 20 (permalink) Old 03-25-2011, 11:07 PM
Mine had prob when reelly cold I wasn't stuck. After 5 miles or so started workin but right now I can't shift while moving more than a few mph
04 colo z71 4x4 reg cab i5 5 speed 3 1/4" tb lift shackles 15x10 center offset? Rims 232000 miles. Have replaced 2 front axles 4 seals starter clutch abs comp 4x4 comp thermostat frontaxle bearings univesals front wheel bearings broke helper springs clutch master and slave cylinder radio. Batt. Custom fog lamp covers fan switch probably more?
kantkeepkleen is offline
post #18 of 20 (permalink) Old 03-25-2011, 11:17 PM
Oh yea I forgot wire going to sillanoid thing loose so light blinks whenever and had to replace 4wd computer cause of water from brake light and truck has spent time in water and stuff
post #19 of 20 (permalink) Old 04-19-2011, 09:53 AM Thread Starter
well, needless to say i replaced my actuator, nothing, took it to the dealer, encoder was bad, new encoder, nothing, new dash switch, nothing, new switch on trans case, shifts but flashes, all this has been done by the dealer, ive paid out the you know where, i think GM needs to have a better diagnosis of their vehicles instead of parts changers, called Chevy and was told that is how they recommend the dealer to do so, WTF as much as i like Chevy i might have to back to Dodge
post #20 of 20 (permalink) Old 08-14-2012, 08:24 AM
Every figure out the issue? I'm dealing with blinking lights as well and have already replaced the actuator with no success.
Pringles1973 is offline
