plug location - Chevy Colorado & GMC Canyon
post #1 of 11 (permalink) Old 04-21-2011, 11:43 AM Thread Starter
plug location
Can someone tell were the spark plugs are located for a 2006 colorado, 5 cyl inline. I have had two mechanics tell me 2 different thing things.
Better yet tell me were I can find a engine diagram.
lgmixsub is offline
post #2 of 11 (permalink) Old 04-21-2011, 04:35 PM
2004CrewCab's Avatar
Re: plug location
The plugs are located at the top of the motor under the 5 coil packs.
Just remove the Vortec air cleaner and you will see them. If you are looking to change the plugs you will need an ext. for your rachet.
2004 CrewCab purchased 07/19/04, sold 04/21/12.
Now down to one 355. The 07 Regular Cab.
2004CrewCab is offline
post #3 of 11 (permalink) Old 04-21-2011, 05:28 PM
Re: plug location
Yup that's right! Just take off the resonator and you'll see the coils right along the top of the head. One bolt takes those off and the plug is underneath.
2007 GMC Canyon Z85 4x4 SLE
Bike - 102 CID v-twin. 120 hp/115ft lbs.
Colorado & Canyon Club of Canada member #4
coyote14 is offline
post #4 of 11 (permalink) Old 04-22-2011, 07:34 AM Thread Starter
Re: plug location
Thanks
lgmixsub is offline
post #5 of 11 (permalink) Old 04-22-2011, 12:26 PM
Re: plug location
post #6 of 11 (permalink) Old 04-22-2011, 10:30 PM
marc-andre's Avatar
Re: plug location
I think you will like this link :
http://www.youtube.com/watch?v=V0pZXt8pXGc
marc-andre is offline
post #7 of 11 (permalink) Old 04-24-2011, 10:28 PM
Re: plug location
It's super easy. Second-easiest spark plug change ever (wife's Toyota Matrix was a little easier). The biggest pain is a wiring harness that makes getting one of the coil packs off. After that, use a ratchet, spark plug wrench and extension to remove the stock plugs. Then, apply anti-seize gently (light amount) on each of the THREADS (don't get it on the electrode) and using the extension and the socket, HAND THREAD the spark plug into the hole. Once you can no longer turn it by hand (several turns), then attach the ratchet and tighten to " firm hand-tight." Do not use brute force. ALWAYS THREAD THEM IN BY HAND. Do not just slap a wrench on there and start cranking.
Other than that, easy as pie. 30-45 minute job, including disassembly/reassembly and going slow.
2004 Colorado Crew Cab Z85 LS, 5spd, 2.8L (daily driver)
2001 Mustang GT Coupe, Auto (weekend)
2005 Toyota Matrix Xr (wife's)
grendal is offline
post #8 of 11 (permalink) Old 04-25-2011, 07:49 AM Thread Starter
Re: plug location
thanks for your help. Anyone know were the fuel filter is?
lgmixsub is offline
post #9 of 11 (permalink) Old 04-25-2011, 11:14 AM
Re: plug location
On the 06s and up the fuel filter is inside the gas tank. If you have the skills to drop the tank feel free to do it, but otherwise let a mechanic with the proper tools and shop do it.
post #10 of 11 (permalink) Old 04-25-2011, 02:00 PM
marc-andre's Avatar
Re: plug location
you do not have to change the fuel filter on 06 and newer
post #11 of 11 (permalink) Old 04-25-2011, 03:12 PM
Re: plug location
I thought that might be the case, but was not sure.
