ABS problem - Chevy Colorado & GMC Canyon
post #1 of 16 (permalink) Old 05-17-2011, 06:24 PM Thread Starter
ABS problem
I have a 04 I5 4x4 ext. cab. It has a abs light that come on for a few minute and then goes off and repeat. I plug in my code reader and tell me it's the front right side sensor. First thing I check was the wheel bearing, ball joint, and tie rod and everything is solid. Tire do need replacing. Is it possible the worn out tire is kick a abs code? Could a rusty disc brake be the problem? I check the wire that goes to the sensor and all is good.
Let me know
Thanks
bandit77 is offline
post #2 of 16 (permalink) Old 05-25-2011, 12:17 PM
Re: ABS problem
sounds like you need a new wheel hub with new abs speed sensor
SnoX440RaceR is offline
post #3 of 16 (permalink) Old 06-05-2011, 12:23 PM
Re: ABS problem
i had the same problem and i just had to replace the abs sensor.
kiefter is offline
post #4 of 16 (permalink) Old 06-05-2011, 12:30 PM
BahamaTodd's Avatar
Re: ABS problem
The way our hub is designed it almost impossible to take the sensor off without damaging it. You will most likely need a new hub.
2004 GMC Canyon SLE Ext Cab Z71 4x4
Site Rules
BahamaTodd is offline
post #5 of 16 (permalink) Old 06-07-2011, 04:17 PM
Re: ABS problem
My 07 2wd ext cab I4, is flashing ABS fault along with traction control. Haven't scanned for codes yet, but i have less than 34,000 miles on it. Is it possible I have a bad hub/sensor allready?
Also, does anybody know how the traction control detects the rear wheels spinning. As far as I know there are no wheel speed sensors on the rear?
rkross54 is offline
post #6 of 16 (permalink) Old 06-07-2011, 05:32 PM
Send a message via Yahoo to GeorgiaZ
Re: ABS problem
i have the same problem in my 05. needs a new right sensor. chevy wants 600 to replace it. Ive been running with the bad one now for 6 months. your ABS and traction control will not work but other than that it does no harm
05 Z71 CC
8000k HID's
K&N Drop in
Flowmaster 40
2" Bubaloo Shackles / 2" Tbar
Rancho 5000's
33X10.5 BFG AT's
GeorgiaZ is offline
post #7 of 16 (permalink) Old 06-07-2011, 05:35 PM
Re: ABS problem
i think there is a sensor at all wheels. i know the speedo works off the rear wheel, so there has to be somthing back there
05 Z71 CC
8000k HID's
K&N Drop in
Flowmaster 40
Rancho 5000's
33X10.5 BFG AT's
GeorgiaZ is offline
post #8 of 16 (permalink) Old 06-08-2011, 07:03 PM
Re: ABS problem
THERE IS ONLY ABS ON THE FRONT. you will have to jack up the front end and push and pull on the wheel if there is no movement then you can either tap the sensor lightly in so that there is no gap. other wise replace the sensor they are not hard to do. i have replaced both hubs, sensors ,calipers, rotors, and brakes pads. 318km / 05so i needed it.
swayzy1 is offline
post #9 of 16 (permalink) Old 06-08-2011, 11:25 PM
Re: ABS problem
Thanks for your replies. I'm gonna check for play in the hubs, and also scan for any dtc's. I will do the job myself, done plenty GM front hubs on cars. Just pissed I only have 34,000mi., but over the three year warranty. The 5yr/100,000 will only cover a bad hub, not sensor. Stupid since one needs the other. I was checking rockauto.com but it seemed a little confusing. Does any body know the part number for a hub with sensor. 2wd with street pack Z85 suspention. Thanks again.
rkross54 is offline
post #10 of 16 (permalink) Old 06-09-2011, 02:43 AM
Re: ABS problem
Your looking at about $83 bucks from your local autozone or equivalent parts supply folks. They are'nt that difficult to change especially if you have done front brake replacement before.
http://www.autozone.com/autozone/parts/ ... ing=search
2008 Chevy Colorado Z71 Crew Cab Off-Road Z71 Off-Road 4x4, 3.7I. 31 Firestone M/T Rhino Liner
2005 GMC Canyon Z71 Off-Road 4x4, 3.5I. 31 Nitto Terra Grappler AT. 3in. SuspensionMax Torsion Keys, Rhino LinerTRADED IN
armyofdux is offline
post #11 of 16 (permalink) Old 06-09-2011, 04:17 PM
Re: ABS problem
they are almost 400 each canadian for the hub itself
swayzy1 is offline
post #12 of 16 (permalink) Old 06-12-2011, 10:30 AM
Re: ABS problem
Just replaced both wheel hubs each 190$ on internet
post #13 of 16 (permalink) Old 06-13-2011, 07:54 PM Thread Starter
Re: ABS problem
Yeah first thing I check was if their was any play in the hub. I think I'm going to try to tap the sensor in and see what happen if it don't work I hate to replace a hub for just a speed sensor. Is their a way to cancel the abs? I'm thinking pulling the fuses will that work?
bandit77 is offline
post #14 of 16 (permalink) Old 06-14-2011, 07:56 PM
Re: ABS problem
Your willing to compromise an industry proven safety feature over the matter of about 80bucks and about 45mins of your time? Not trying to harp on you and I realize times can be tough but I would never compromise my safety knowing that I could have fixed my issue for relatively cheap especially since your going to have the whole thing disassembled when you are going to "tap the sensor".
To answer your question yea pulling the fuse will probably work for the ABS light but should you get into an accident it might be the difference of your life, your passengers, and possibly someone else's.
post #15 of 16 (permalink) Old 06-15-2011, 08:22 AM
Re: ABS problem
Odds are the hub assembly is bad and he is looking at a couple hundred more to get the job done IF he fixes it himself. Both my hubs were bad from this same ABS light issue BTW. While he is riding around waiting on parts to arrive the ABS could activate leaving him unable to stop at an intersection. Been there and done that. He will be a ton safer with the fuse pulled until he can get the hub assembly properly fixed IMO.
05 Z71 I4 Rado /w 4:10 gearing
garyc660r is offline
post #16 of 16 (permalink) Old 06-16-2011, 09:41 AM
Re: ABS problem
These three codes came up. C0035 LF sensor, C0220 LF antilock brake system in release to long, and here is the best one ; U1064 Lost communication with BCM/DIM
rkross54 is offline
