Few questions about my new colorado - Chevy Colorado & GMC Canyon
Old 05-05-2012, 01:20 AM   #1 (permalink)
Default Few questions about my new colorado
Just got a few quick questions,
1 - I was wondering what the traction control button does. It seems as if it is crossed out on the button, so I have come to the following conclusion
The traction control is ALWAYS on
By pressing the button, you enable the 'traction control off' to be engaged
Does this improve economy? By default, even if I have been driving with T/C off, the T/C will automatically come on the next time I start the car.
Ive also been getting about 17-18 MPG, this is fairly shitty for the 4 cylinder. I havent been booting it and it has been mixed highway/city with a bit of hauling.
2 - Also, does anyone know where I can get a copy of the factory service manual? I am approaching 60000 miles and have a feeling a bit tuneup is coming. I have owned the truck for about a month. Any other tips are appreciated!
3 - I have an LS Colorado, and I am interested in getting some options, fog lights, bull bar, I am wondering if these are a direct bolt on (the truck is pre-fabbed) or do I have to do my own fabrication. I am from the honda world so non-ac cars have a/c delete harnesses that just need to be plugged in.
4 - How hard is it to add the towing package to a LS that didn't come with it?
THANKS guys :)
GMT355 is offline   Reply With Quote
Old 05-05-2012, 04:07 AM   #2 (permalink)
Default
Traction control is always on. You have to push the button to turn if off. Every time you start the truck it comes on automatically. It had no effect on fuel economy as far as I know.
A tune up will help your MPG. 17-18 is pretty bad. What year is the truck? After 60,000 miles the tranny(auto) should be serviced. Plugs, radiator flush maybe also. You should clean the throttle body and MAF sensor. Each takes a different kind of cleaner. Those should be cleaned every 10,000-15,000 miles. Also clean/replace air filter while your at it.
Bull bars bolt right on. Are you putting the fog lights on the bull bar?
Curt, Reese, ect... all make bolt on tow hitches, fairly easy to install. You will need a wiring harness for trailer lights, also easy to install. Just look on eBay.
You try the dealership for the service manual? Or do a Google search? Maybe some websites like gmpartsdirect.com.
GregDAP is offline   Reply With Quote
Old 05-05-2012, 10:04 AM   #3 (permalink)
Default
Go to Helm for the "Official" Service Manual. Be prepared for sticker shock. You can get a subscription to Alldata relatively cheap and they also have all the Service Bulletins. Check Ebay. I recently got a CD that the seller listed for a 1998 Blazer. When I got it I found out that it is a GM disc and covers most GM vehicles from the early 1990s to 2009 including all the Colorados.
cart7881 is offline   Reply With Quote
Old 05-05-2012, 10:08 AM   #4 (permalink)
uncle sauce's Avatar
Default
i have an 05 pdf manual i can email to you...
someone posted a 2010 manual in the programming key fob thread right next to this one....
2005 Colorado Z71 LS 2WD
3.5L I5
1.75" TB Lift
Rancho RS5000 x4
Homemade Intake
31x10.5R15 Goodyear Wrangler Duratrac
95K mi.
Lifted member #435
never argue with stupid people, they will drag you down to their level and then beat you with experience. - Mark Twain
uncle sauce is offline   Reply With Quote
Old 05-05-2012, 11:33 AM   #5 (permalink)
naskie18's Avatar
Send a message via AIM to naskie18
Default
That's the owners manual, not the service manual.
The service manual tells you how to perform service and remove/replace everything on your truck. It's significantly more in depth, doesn't come with the truck, and costs about $300 from Helm, if I remember right. Think of a Chilton/Haynes manual, except it's actually helpful, it's easily 4 times as thick, and it isn't wrong nearly as frequently.
naskie18 is offline   Reply With Quote
Old 05-05-2012, 11:51 AM   #6 (permalink)
Default
gothca, apparently i overlooked the word service
3.5L I5
1.75" TB Lift
Rancho RS5000 x4
Homemade Intake
95K mi.
Lifted member #435
Old 05-06-2012, 02:41 AM   #7 (permalink)
Default
Also, I have nowhere to put my wallet and phone. I have been putting my phonein the doorjam and my wallet in the glovebox. I have the lining in the door but I don't like putting things in there, since I don't want them to fall out when I open my door. Also, my wallet is fairly fat so I cant fit it in the door *Not as bad as George from seinfeld....*
My friend owns a 2001 sonoma, and he has an overhead compartment where he can put his wallet and keys, sort of a slotted section. I looked at the roof of mine at it has 2 delete plugs, possibly for the same compartment. Was this an option? I want to go to the junkyard and see (if it is) and how hard it would be to install.
Thanks for all the tips guys!
Old 05-06-2012, 02:44 AM   #8 (permalink)
Default
The truck is
2005 Colorado
STD Cab, White
86000 Kilometers (Roughly 55k Miles)
Bought at a dealership, they did a major service (still waiting for detailed service record)
Automatic, 4cylinder (2800 I believe is 4cyl?)
I will take a look at the service record before I do anything. I think they did a huge tuneup, but I have basically spent all my kilometers hauling couches/furniture since I have been moving non-stop since I have owned it, so I'm hoping 18mpg is normal :(
Old 05-06-2012, 09:04 AM   #9 (permalink)
Default
there's been a few overhead consoles installed, i don't know if there's an actual how-to but this may give you a few good ideas.
Another overhead console install - Chevrolet Colorado & GMC Canyon Forum
3.5L I5
1.75" TB Lift
Rancho RS5000 x4
Homemade Intake
95K mi.
Lifted member #435
Old 05-06-2012, 12:14 PM   #10 (permalink)
Default
So the Colorado didn't come with a little one like the sonoma I guess. I'll run to the yard and find one from a Silverado or a Tahoe or something.
Anyone know if they all have to be fabbed? I was reading some threads and it seems like the same year (2005) Silverado should bolt right up.
I don't want the long crazy one, I just want the mini one for wallet/phone, nothing fancy :)
You may not post new threads
You may not post replies
