2005 Canyon Electrical Issues - Chevy Colorado & GMC Canyon
post #1 of 9 (permalink) Old 02-23-2017, 12:06 PM Thread Starter
This one is strange. Sometimes all my exterior lights except for my headlights won't work. Some interior lights won't work either. But as I drive sometimes they'll just pop on. It seems like there's a grounding issue, but I have no idea where to start. Has anyone experienced this? Thank you.
sweetlou36 is offline
post #2 of 9 (permalink) Old 02-25-2017, 08:24 PM
Send a message via MSN to braindead1684
Do you loose the cluster or anything else like that.
Have autozone or someone do a load test on the battery and check the connections.
My 07 had an issue when the battery was going out where I lost my cluster, power windows, wipers and some lights i believe. Truck ran fine and I was perplexed as to what was wrong. Battery was starting the truck ok but swelled and went out one day without warning, the issues described never came back after that.
Current
2016 CC LB 2.8L Duramax Diesel
GMC Canyon.
The Original (Sold June 2016)
2007 4x4 Z71 3.7 I-5
Hunter Brush Guard
Access Lorado Rollup Tonneau
Window In-Channel Vents
DDM Tuning 55w 5000k HID
Fosgate Punch 10" Sub w. Custom Box.
braindead1684 is offline
post #3 of 9 (permalink) Old 02-28-2017, 01:01 PM Thread Starter
Thank you for the reply and info. I took your advice and went to autozone and had my battery tested. Unfortunately it turns out that isn't the issue. Back to the drawing board I guess.
post #4 of 9 (permalink) Old 02-28-2017, 08:18 PM
Check/clean the ground points under the hood
GregDAP is offline
post #5 of 9 (permalink) Old 02-28-2017, 08:26 PM
Probably the first place to try would be the ground point. Most of the lights, internal and external, ground at G105, which is in the engine compartment, on the left fender wall, aft of the battery. The ground point is a small black plastic box that is mounted by a single bolt. Remove the bolt and clean the mating surfaces of the fender wall and the box tab. Pull LIGHTLY on the wires, where they go into the box, to check for broken ones.
The problem could also be located in the light switch module.
G105:
post #6 of 9 (permalink) Old 03-01-2017, 09:05 PM
GM Customer Service's Avatar
Hi sweetlou36,
We're sorry to learn of the recent electric concern you’re experiencing with your truck. Our team noticed that you are looking for some input from other forum members, so we would like to offer our assistance to you. If you would like, we could take a further look on our end and contact a GM Certified dealership on your behalf. Please send us a private message that includes your VIN, mileage, full contact information, and preferred dealer if this is of interest to you.
To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html
Thanks,
Bret B.
GM Customer Care
post #7 of 9 (permalink) Old 03-02-2017, 06:10 AM
G105:
IF that does not fix your problem, remove the box again and pry it open. Check the connections inside for burning or discoloration.
post #8 of 9 (permalink) Old 03-08-2017, 08:40 PM Thread Starter
G105:
So far so good!!! I removed the box, cleaned the connection, and it's been working the past couple days. Thank you for the info.
post #9 of 9 (permalink) Old 04-21-2017, 06:18 PM Thread Starter
Update: so it turns out that I had to replace my fuse block that's under the hood. So far so good.
