Need some opinions on towing - Chevy Colorado & GMC Canyon
 11Likes
  • 1 Post By Duken4evr
  • 1 Post By naskie18
  • 2 Post By CaryBosse
  • 1 Post By Toughsox
  • 1 Post By cesharp3
  • 1 Post By CaryBosse
  • 1 Post By zazu87usf
  • 2 Post By rookie145
  • 1 Post By Dayton
post #1 of 18 (permalink) Old 03-27-2017, 06:21 PM Thread Starter
Just signed up today and look forward to learning more about my new 2017 Colorado LT Crew Cab 4x4 3.6L V6. I'm driving to Vegas next month to pick up a boat and tow it 1800 miles. I've attached a pic of the boat and trailer. Will my new truck handle this thing? Boat weighs about 4500lbs and I'm guessing trailer is around 800-1000lbs. I know towing capacity is 7,000 but am I pushing it? Need your opinions. Thank you!
File Type: jpg 14859354_10211444294806850_763205583_o.jpg (266.3 KB, 69 views)
rookie145 is offline
post #2 of 18 (permalink) Old 03-27-2017, 06:31 PM
That boat looks a lot heavier than 4500 pounds. I would guess closer to 6.5K for the combo of that boat and trailer. I would not want to do that to my new mid size truck.
Toughsox likes this.
Duken4evr is offline
post #3 of 18 (permalink) Old 03-27-2017, 08:28 PM
naskie18's Avatar
How "new" is your truck - how many miles? I wouldn't tow anything that heavy or that far in the first couple thousand miles.
Also, do the V6s come with a transmission cooler like the Duramaxes? I don't think so, but I'm not positive, I haven't paid much attention to the V6. If not, I'd definitely add one before towing in the desert.
[EDIT]
I might be concerned about the trailer as well....are you buying this from someone you know/trust? Do the brakes work? How old are the tires? Does it have a spare? Lots of potential issues here that are worth looking into before you make the trip.
naskie18 is offline
post #4 of 18 (permalink) Old 03-27-2017, 08:44 PM
caseih's Avatar
I tow my dad's 21 ft. fiberglass run-a-bout on a single axle trailer with with his Ford F150 with the 5.0 V-8 and that truck is just about right on hills. With two axles probably rated at 3500# each minimum guessing by tire size so I agree that you are probably pushing well over 7000 Lbs. That looks like fiberglass and not aluminum. An then there is the extra wind resistance. Plus I agree that the engine & transmission should have at least 1000 miles on it before towing. I would also like to add wheel bearings to Naskie18's concerns. Wheel bearings are often ignored on utility trailers with boat trailers often failing due to exposure to water at the ramps. Does this trailer have electric brakes?
I just noticed that you are also in Wisconsin. That means hauling it through the Rockies? Like the hills west of Denver? Been up and down those hills a few times. Yikes.
caseih is offline
post #5 of 18 (permalink) Old 03-27-2017, 09:51 PM Thread Starter
Thanks for all the info and advice so far. Right now the truck has only 315 miles on it. After driving to Vegas it will have just over 2000. So as far as the "break-in" it should be okay. I haven't weighed the boat and trailer together yet. NADA guide says the boat weight 4550lbs without fuel and gear. I plan on servicing the trailer when I get there i.e...bearings, lights, tires, etc. The truck as a tow mode on it which should help with the shifting and right gears. No transmission cooler on it though. Should I get one prior to trip? Really nervous about this trip...don't want to damage my new truck. I'm in no hurry so plan on taking it nice and slow. Pretty flat land except about a 2000-3000 ft elevation change thru parts of Utah and Wyoming.
post #6 of 18 (permalink) Old 03-27-2017, 10:25 PM
I wouldn't be concerned for transmission cooler. Braking capabilities and hauling up hills or into a wind worry me more.
Your commitment to not being in a hurry is also important.
I wouldn't want to tow that on a regular basis but for a one time easy does it, probably ok.
Would it make more sense to hitch a ride on a bus and rent a truck to tow it home and save the wear and tear?
Toughsox and ferg Z71 like this.
post #7 of 18 (permalink) Old 03-27-2017, 10:59 PM
Everything that was said so far is spot on. That boat looks more than what the NADA guide states and Id want someone to weigh it beforehand just to make sure. State Police may be able to help you with that or at least guide you to where a weigh station is.
Also, if that is loaded up with fuel you can easily add another 500-1000 pounds without realizing it.
Even with all that being said, Id ask a friend to borrow a bigger truck before I broke in my new truck on a drive like that. You will need more than a few hours behind the wheel of your new truck to really get a feel for how it handles with such a weight on the tail end of it.
Just my 2 cents. Either way, best of luck with it.
Which brings me another point.....you showed the boat, WHERE IS YOUR TRUCK??? We demand pix around this neck of the woods.
Duken4evr likes this.
Toughsox is offline
post #8 of 18 (permalink) Old 03-27-2017, 11:00 PM
cesharp3's Avatar
As a person that deals a lot with boats, that thing weighs over 4500. But even if it does somehow only weigh 4500 I still wouldn't do that to your truck. Since you're only doing it one time, I would hitch a ride or flight then rent a Uhaul pickup for the trip. The pickups start at $19 / day plus mileage. Since your truck is brand new, I would not do that to it. The sheer size of that boat alone makes me nervous for you with any kind of wind.
Long story short I personally would not do it. But hey, it's your $35,000 investment so do what you want.
2015 Silver Colorado Z71
-Blacked out bowties -Air-dam delete
-Front light bar in grill -Red Tow Hooks
-1.25" front level -265/70/17 BFG KO2s
-Husky Mudflaps -Bedrug
-VHF Antenna Install -USB/12v bed plugs
-LED Interior -LED reverse, cargo
-Tekonsha P3 TBC
cesharp3 is offline
post #9 of 18 (permalink) Old 03-27-2017, 11:51 PM
Not sure this link to Bayliner is the same boat, but it shows weight as 5,685 lb.
http://bayliner.com/wp-content/uploa...Spec-Sheet.pdf
Here is link to app that has scale locations, https://catscale.com/
Maybe good idea to have it weighted before you decide if you can tow it or call bayliner and trailer manufacture to see what spec says for weight. Some trailers have placards with trailer weight and gross capacity.
Dayton is offline
post #10 of 18 (permalink) Old 03-27-2017, 11:55 PM
ferg Z71's Avatar
keep in mind, there are a lot of mountain ranges to cross in that area, depending on which way you go
ferg Z71 is offline
post #11 of 18 (permalink) Old 03-28-2017, 12:47 AM
kaiser67's Avatar
Even if the weight is under the 7k max rating, it's not as much as a "Can it do it?" as a "Should you do it?"
If weight is lower than 6500, it could do it but that thing is pretty big and has A LOT of cross section to catch wind. That's a pretty long trip through some windy areas with something like that. Like someone said, if you're not in any hurry it would be better but doing anything close to the max isn't necessarily a good idea even though it technically can do it.
Also the v6 has a built in trans cooler iirc. Forgot if its separate or built into the radiator.
2016 Red Rock LT CC SB v6 4x4
My build thread
Front bumper removal How-To
Rear Shock/lift Blocks How-To
kaiser67 is offline
post #12 of 18 (permalink) Old 03-28-2017, 09:54 AM
Lot of good points:
- The CAN IT versus SHOULD IT.
- Cross sectional wind.
The transmission cooler is built in to radiator, but I think it is pretty effective on the V6, at least for the 2015/2016 models. Actually, can anyone confirm same on 2017? I asked the question a while back about transmission temps on the 2017 when towing, but never got any good responses.
Once you get the boat "home" to Wisconsin, are you:
1. Going to put it in the water and leave it? (doubt it in Wisconsin.)
2. Pull it out every winter and relaunch every spring?
3. Launch it on a boat ramp or using a crane?
4. Tow it every weekend from home to lake, 10 miles? 50 miles? 150 miles?
If you are going to be launching it off a ramp, towing it every week a fair distance, etc., I would get a bigger truck. If you are just transporting it from Vegas to Wisconsin, I would rent a truck, probably even something heavier duty than that 1/2 ton Silverado that U-Haul offers.
kaiser67 likes this.
post #13 of 18 (permalink) Old 03-28-2017, 10:19 AM
Lot of good points:
The truck should have a transmission cooler. Also another thing, you don't want to "break in" your truck on the highway. So a 2000 mile trip is not the way to go.
CaryBosse likes this.
zazu87usf is offline
post #14 of 18 (permalink) Old 03-28-2017, 01:30 PM Thread Starter
You guys are rocking the advice...thanks again! One of my biggest reasons for towing it myself is the cost, of course. I looked on Enterprise website and a 1/2 ton truck one way rental was (no kidding) $13,000! I can get a 15ft U-haul truck for about $1200 and not tell them I hauling my own trailer. I'll be honest, this decision is keeping me up at night. I'm getting about half telling me it should be okay as long as I take it easy and not rush things and others say it's not worth the risk at all. I am seeing about getting everything weighed before I make my decision. I will let you guys know what the final weight is when I find out. Again, thank you for all the info and advice. Sweet forum site you have here.
cesharp3 and Duken4evr like this.
post #15 of 18 (permalink) Old 03-28-2017, 02:14 PM
Just noticed you are from Superior we live across the Bay. A good local source of info is Eric at Barkers Island. He likely knows weight of typical trailers and what your boat may weigh. This time of year best to stop in at their boat repair area to talk with him as they are likely getting busy finishing up winter projects and getting ready for spring.
We tow a travel trailer with dry weight of 5245 lb which likely has more wind area than your boat. We have a diesel Canyon but know that someone on this list tows identical travel trailer with a V6. We usually only travel 60mph when towing
rookie145 likes this.
Dayton is offline
post #16 of 18 (permalink) Old 03-28-2017, 08:59 PM
Pontiyaker's Avatar
Red face
Reminds me of the time I sold a 26' Sea Ray sundancer, the buyer came with a dodge minivan. He had a 250 mile drive, I told him he wouldn't make it. Sure enough about halfway the tranny went. Sure wish I had taken a picture. My friends and I still laugh about it.
My suggestion is to get a bigger truck or find another boat local to you.
2017 Z71 4x4 CCSB Cyber Grey
Pontiyaker is offline
post #17 of 18 (permalink) Old 04-23-2017, 09:59 AM
You should be able to hire someone to tow it for around $1 per mile. That saves the wear and tear on your truck and your time as well.
SOTA is offline
post #18 of 18 (permalink) Old 04-23-2017, 10:10 AM
I agree with the others, your estimation of that rigs weight is way low. While I would not hesitate to do local hauls of it with a Colorado, even with my Minimax I would hook it to one of the Silverado HD's for a freeway run of more than a few miles. Running that heavy and wind resistant for hours at a time can be done, but you will be sucking the life out of that truck, especially with the gasser.
'16 Z71 CC/SB Minimax. Brownstone. 5" SS boards, Quad fold tonneau, Wheel well flares. Spray in liner, swing out tool boxes, Bose & Nav. Weathertech vent shades, floor liners and mud flaps.
Esoxchaser is offline
