LinkBack | Thread Tools |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
The extended cab of these trucks is equipped to hold a baby seat...as far as restraint strap hookups or whatever. However, nobody on here has mentioned putting one back there as of yet.
And when I mentioned it to my GF, she said it would NOT be a good idea. As a child and family services graduate, she knows about babys and kids and all that crap. But ****, I think it'd be fine. ;)
04 Victory Red Colorado LS Ex. Cab Z-71 4x4 3.5L I5 Auto @ ~245 HP & 3.73 Gears 31x10.5" BFG ATs, Line-X, Access Cover, K&N FIPK, Hoens ~80000 Mi. |
#3 (permalink) |
I wouldn't see why not either.
If anything, strap the baby seat in the bed... (Just kidding!) Page 1-40 of the owner's manual states: Where to Put the Restraint Accident statistics show that children are safer if they are restrained in the rear rather than the front seat. General Motors recommends that child restraints be secured in a rear seat including an infant riding in a rear-facing infant seat, a child riding in a forward-facing child seat and an older child riding in a booster seat. Never put a child in a rear-facing child restraint in the right front passenger seat unless your vehicle has an air bag off switch and the air bag off light shows off. Never put a rear-facing child restraint in the right front passenger seat unless the air bag is off. Here is why: If you need to secure a rear-facing child restraint in the right front passenger’s position, the right front passenger’s frontal air bag must be off. See Securing a Child Restraint in the Right Front Seat Position (Models with an Air Bag Off Switch) and Securing a Child Restraint Designed for the LATCH System (Models with an Air Bag Off Switch) in the Index, and Air Bag Off Switch on page 1-70 for more on this including important safety information. Wherever you install it, be sure to secure the child restraint properly. Keep in mind that an unsecured child restraint can move around in a collision or sudden stop and injure people in the vehicle. Be sure to properly secure any child restraint in your vehicle – even when no child is in it. Ending page, 1-41 HERE IS A CAUTION DIALOG FROM THE SAME PAGES CAUTION: A child in a rear-facing child restraint can be seriously injured or killed if the right front passenger’s frontal air bag inflates. This is because the back of the rear-facing child restraint would be very close to the inflating air bag. Be sure to turn off the air bag before using a rear-facing child restraint in the right front seat position. CAUTION: Even though the air bag off switch is designed to turn off the right front passenger’s frontal air bag, no system is fail-safe, and no one can guarantee that an air bag will not deploy under some unusual circumstance, even though it is turned off. We recommend that rear-facing child restraints be transported in vehicles with a rear seat that will accommodate a rear-facing child restraint, whenever possible. If you secure a forward-facing child restraint in the right front seat, always move the right front passenger seat as far back as it will go. It is better to secure the child restraint in a rear seat. I hope this helps. The manual states to USE the rear seats, when available. I'd assume this means the extended cab models because the crew cab models have no airbag off switch.
'04 GMC CC 4WD Z71 (Black) -I5, Leather, XM, Sirius, PIONEER Premier AVIC-F90BT, K&N FIPK, BedRug, 15% Tint ~88000 miles Conservative Club Member #26.
#4 (permalink) |
I would be impressed if a child's seat
would fit in back of an extended cab. Does anyone have any pics/proof? :)
http://www.TheHEMI.com/ |
#6 (permalink) |
I actually tried it when I was shopping. I have a newborn. Even though the Colorado comes with Car seat anchors, the rear facing seats will not fit in the back. The forward facing ones would be very tight (I don't have one yet), I suspect you would have to move the passangers seat very far forward. The extened cab only apears to have enough room for a booster seat. I have chosen the crew cab for the above reasons. I hope this helps.
#7 (permalink) |
I have an extended cab and can fit a forward facing child seat in the back. It's really tight though and I wouldn't do it regularly. The passenger seat needs to be moved way forward. I took off the back cushion too for about 1.5 inches more room. The "latch" points work ok and the tether strap goes through the loop at the top of the seat cushion and attaches in the center over the jack storage compartment.
#8 (permalink) |
For those of you who have doubts, see my pics (you need to scroll to the bottom of the page). I've added a pic with the child seat installed in my extended cab.
This is an older child seat, and due to design, other seats may or may not fit quite as well. Note that the rear seatback has been removed for the installation. There is approx. 8" of clearance between the back of the front seat, and the leading edge of the child seat. Front seat is not slid front, as others have suggested, and in fact is about 3/4 of the way back. Front passenger should have plenty of leg room at this position, and clearance in back of the seat should allow for plenty of leg room for even the heftiest child Also, note in the same pic, the booster seat on the opposite rear seat. Works for me. :) Admin edit:
Steve Member: NWTF, NRA, USGA, AARP |
#10 (permalink) | |
Ken Deatrick CT15653 - 2004 COLORADO 4WD LS EXT CAB Z85 My CarDomain Gallery Mods: Silver GM Hood Protector, Silver GM Small Flares, Factory Style Fog Lamps added Rhino Liner, Fold-A-Cover, Carriage Works Billet Grille, Silverstar Bulbs |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
