Review of syncron's HID's **Big Pics 56k Stay Away** - Page 2 - Chevy Colorado & GMC Canyon
post #21 of 157 (permalink) Old 02-28-2008, 03:57 AM
Thanks DB...i'll try to remove grille and re-install o-rings tonight.
2004 Colorado Crew Cab I5
bman4926 is offline
post #22 of 157 (permalink) Old 02-28-2008, 04:01 AM
CALI-BOSS
DBNissan's Avatar
No prob paré!
I'd hate to have those new HIDs blow prematurely from too much moisture.
DBNissan is offline
post #23 of 157 (permalink) Old 02-28-2008, 07:34 AM
Send a message via MSN to syncron
Originally Posted by bman4926
Received my hid's yesterday and it was a pain to install! Very tight squeeze trying to get the driver side bulb in. I did remove the red o-rings to install. They went in a lot easier w/o them. It probably took me a total of 3 hrs. I had problems with the plug going back to the ballast also. I had to reverse the plugs in order for them to work. I also mounted the ballasts like the pics above, no problems with that. The lights though are VERY bright and i'm glad I got the 6000k, with just a hint of blue. When I completed install, I tried to adjust the headlight leveler on the drivers side so I won't blind people but broke the adjuster in the process, so that sucks. Thought it was metal but it must be plastic.
All in all I hope these bulbs last a while because of the clearance issue on the driver side installation. Took a while for them to get here (shipping problems with UPS not syncron). I am satisfied with the brightness and plug-n-play factor of the bulbs but not with GM's drivers side clearance issue.
glad to hear you like to kits. I am glad i mentioned the reverse polarity thing i have no idea why but every aftermarket HID kit i have used has always had that problem anyway everything should last a while
Hella Ballast
Philips Bulbs
Bosch Relays/cables
With those brands backing the kits up i doubt u will have a problem. ANYWAY ENJOY and thanks for the positive review.
syncron is offline
post #24 of 157 (permalink) Old 02-28-2008, 11:04 AM
Originally Posted by DBNissan
No prob paré!
Have you seen pics of the HID bulb being submersed in a cup of water? HID's take moisture quite well. I have had a set on my Avalanche now for 3 years with no problems.
Dune is offline
post #25 of 157 (permalink) Old 02-28-2008, 11:44 AM
Well I was the firsto to recive my HIDS and Like Dillusion stated mine had the polarity issue
buy syncron called me right away the same night and I got it fixed :D here are some pics :D
I took a while because I did the high beam kit as well
stock lows
8000K lows
high beam kit doing what it dose best
holy brightness batman!!
lows w/ fogs
relaays for high beam kit :D
ballast on truck
high beam kit on during the day!!
high beam kit on daytime!!
ballast location (yay H-E-B doubble stick tape )
first time taking grill off!!
HIDS!!!
HIDS!!
8000K bulbs in plastic container!
not bad for a cell phone right guys
2005 Colorado Crew-Cab ZQ8 White I5
lots of mods!!
UNDER 21 CLUB MEMBER #6
TOTW #14 Winner 2007 :D
Got a Colorado? Live in South Texas? Check this out :D
http://www.rgv355.com
ColoradoKid121205 is offline
post #26 of 157 (permalink) Old 02-28-2008, 02:16 PM
Banned
i have a question about the bulb itself...if the bulb goes out on these hid's, can you just buy a new bulb or do you have to get a whole new setup? and what kinda bulb would you be buying if it was just a bulb to replace?
chnky18 is offline
post #27 of 157 (permalink) Old 02-28-2008, 02:26 PM
Hella Ballast
Philips Bulbs
Bosch Relays/cables
the reason for the reverse polarity issue is due to having a BCM. Older vehicles are (+) switched. Newer BCM vehicles are (-) switched.
Also for anyone wondering - here is a video of my HIDs warming up. http://home.cogeco.ca/~pteahan2/Colorado/HID_warmup.avi (right-click, save-as).
Mine arent the same as the ones syncron is selling but its the same color change effect as they warm up. mine are 6000K. they change from blue to white once they are completely warmed up.
burn is offline
post #28 of 157 (permalink) Old 02-28-2008, 04:45 PM
glad to hear everything turned out well bro and remember IF THERE IS A PROBLEM REVERSE THE POLARITY LOL
syncron is offline
post #29 of 157 (permalink) Old 02-28-2008, 04:50 PM
you would have to buy a new HID bulb. i sell replacement bulbs if required.
syncron is offline
post #30 of 157 (permalink) Old 02-28-2008, 05:01 PM
How does one go about using the 14 month warranty ( if needed of course ).
rangerbob is offline
post #31 of 157 (permalink) Old 02-28-2008, 06:17 PM
well you need to make sure that the you keep your receipt( Shipment insert & paypal reciept)
then if lets say 12months down the line your bulb blows then u just email me with the problem i will ask for a copy of the shipment insert(includes what u purchase i.e 9006 6000k etc) and a copy of the paypal reciept and if it is still in warranty which after 12months it would be then i would contact my manufacture and have them ship out a replacement bulb etc to you but all shipping costs are on you. So if it costs $30 or so to send out a replacement kit etc you pay the cost and a new one will be sent.
Like i mentioned the warranty is handled by the manufacture not me or my company, and they require shipping etc to be paid for.
hope that helps.
syncron is offline
post #32 of 157 (permalink) Old 02-28-2008, 07:00 PM
naskie18's Avatar
So, as far as warranty is concerned, do we have to send back the bad bulb(s)?
If so, would we have to do it before the manufacturer will ship us a replacement bulb?
If we needed to purchase a replacement bulb, would you ship those, or do those ship from the manufacturer as well?
naskie18 is offline
post #33 of 157 (permalink) Old 02-28-2008, 07:07 PM
the manufacture has 2 options with shipping warranty stuff. For example **not exact numbers** if you want to ship the item back it may cost you $20 and they will send a new one to you when they receive the money and the product OR if you don't want to send it back then it may cost $40 and when they receive the money they will ship out a new one to you etc. but these kits are built well so i doubt there will be a problem.
If you need to purchase replacement bulbs then you can order them through me. They will be shipped direct from the manufacture but it will not take as long as they did last time.
My manufacture has never taken this long to ship stuff out they said it was because of Chinese new year and some issues involving UPS down there. But everything is resolved and new orders should be delivered within 10-14 days of placing the order.
syncron is offline
post #34 of 157 (permalink) Old 02-28-2008, 07:10 PM
Hey pat i tryed watching the video but it only comes up as audio...
golfsk8er is offline
post #35 of 157 (permalink) Old 02-28-2008, 07:15 PM
works fine for me :->
syncron is offline
post #36 of 157 (permalink) Old 02-29-2008, 12:49 AM
Banned
and how much would replacement bulbs be?
chnky18 is offline
post #37 of 157 (permalink) Old 02-29-2008, 01:24 AM
around $55 for single beam bulbs shipped.
syncron is offline
post #38 of 157 (permalink) Old 02-29-2008, 08:31 AM
you need a DivX codec installed.
burn is offline
post #39 of 157 (permalink) Old 02-29-2008, 09:19 AM
Is that two bulbs?
post #40 of 157 (permalink) Old 02-29-2008, 09:54 AM
Is that two bulbs?
yes of course comes in a pair.
Single beam bulb= only hi or only low filiment on a bulb
dual beam bulb = high and low on filiment on the same physical bulb.
syncron is offline
