Need some engine block heater info please - Chevy Colorado & GMC Canyon
post #1 of 8 (permalink) Old 12-09-2012, 09:51 PM Thread Starter
2011 Colorado 3.7.
The older gen motors use a Kats screw-in engine block heater. I installed one in my 2.8 Canyon. The 3.7 is different. According to my service manual, this engine uses a heater that snaps into a bore just below the thermostat housing. Kats website still lists the old style as fitting the new engines. I checked it out and indeed it does use something different than the old style. My problem is that I can not find the correct Kats number or GM number for the 3.7. Can anyone help?
Thanks, James
James1549 is offline
post #2 of 8 (permalink) Old 12-10-2012, 05:58 AM
post #3 of 8 (permalink) Old 12-10-2012, 08:26 AM
I have the factory engine block heater I ordered with my truck new in 2007. The thing I don't like about it (and most on vehicles are this way now) is it has to get to zero degrees before it works even if you have it plugged in. I had one on my Dakota R/T that was factory installed and any time you plugged it in it heated the block. When its 19 degrees like right now I'd sure liked to have it where it worked so my heater would already be warm when I turned it on.
johnny1 is offline
post #4 of 8 (permalink) Old 12-10-2012, 09:14 AM Thread Starter
Thanks Cart. The Amazon item is incorrect. I just returned that item. It will fit the 2.8 and 3.5, but not the newer engines. The newer engines use a heater that snaps in the motor, not threaded. I will research the NI heater more. Thanks, James
post #5 of 8 (permalink) Old 12-10-2012, 09:40 AM
So the link to Nalley was also incorrect, I assume. It appears similar to the Amazon one.
post #6 of 8 (permalink) Old 12-10-2012, 03:42 PM
Yesterday I looked at the Nalley link that you provided and it was correct. It shows 2007 and later. If you look on the Nalley site for a 2005 you will see that it is a different part number.
post #7 of 8 (permalink) Old 12-10-2012, 04:44 PM Thread Starter
Yes I believe the N1 part number is correct. But it takes a 2 pin cord that costs $150 to power it. Is it made of gold wire?
Thanks for your help guys. James
post #8 of 8 (permalink) Old 12-10-2012, 09:18 PM
I haven't seen one but $150 you ought to be able to make your own cord if necessary.
