Keyless fob - Chevy Colorado & GMC Canyon
post #1 of 10 (permalink) Old 05-08-2016, 06:52 PM Thread Starter
Keyless fob
Can someone please tell me where to find out where the receiver for the keyless entry is located on a 06 Colorado thank you
eandm1123 is offline
post #2 of 10 (permalink) Old 05-08-2016, 08:31 PM
to C'Fans.
The "receiver' for the Remote Keyless Entry fob is the BCM (Body Control Module). It is located behind the right kick panel. If you are not sure where the right kick panel is, sit in the passenger seat with your legs out and move your right leg to the right until it contacts the "wall". That is the right kick panel.
post #3 of 10 (permalink) Old 05-08-2016, 10:19 PM Thread Starter
Thanks for the welcome and answer!! I just bought it yesterday and it didn't come with a fob so I wanted to see if it had one it
post #4 of 10 (permalink) Old 05-08-2016, 11:12 PM
If it has power door locks it should have Remote Keyless Entry (RKE) It would be part of the Power Convenience Package option, ZQ6. If you want to know if the truck was produced with the remote option, look on the inside if the glove box door. There should be a decal there with a lot of three digit codes for the installed equipment. Look for the code "ZQ6".
You can purchase the key fobs from many sources, but if you want to buy them from someplace, other than a Dealer, make sure that they are compatible with your truck. It will require a trip to a Dealer to program any remotes to your truck.
post #5 of 10 (permalink) Old 05-09-2016, 11:42 PM Thread Starter
I will check for that code tomorrow thanks again for the answer helped a lot
post #6 of 10 (permalink) Old 05-10-2016, 07:10 AM
Okay, let us know what you find.
post #7 of 10 (permalink) Old 05-10-2016, 08:04 AM
Denthevetteman78's Avatar
If you call your local dealer with your serial number they will tell you. I know i've done it for my 05'Canyon. I bought it used without remote and after the dealer told me it came with remote, I bought remote online and had it programmed at the dealer. They need to be program at the dealer.
2016 Colorado Z71, Lazer Blue,
Factory fender flare
Factory mud flap
Sprayed box liner
Truxedo toneau cover
Vent shade
Hood deflector
All weather floor mat
MotoMetal Mo970 17 x 8 with 0 offset
Zone 1.25 leveling kit
Denthevetteman78 is offline
post #8 of 10 (permalink) Old 05-11-2016, 01:40 PM
I ordered two from amazon for $13 shipped and paid $50 to have them both programmed at a local locksmith. Stealership was charging me $75 per remote.
asalinasz39 is offline
post #9 of 10 (permalink) Old 05-11-2016, 10:40 PM Thread Starter
Ok so good news I found the code zq6
post #10 of 10 (permalink) Old 01-09-2017, 07:05 PM
I found this on YouTube to program your key fobs yourself without going to the dealer. I tried it on my 05 Canyon but I have a bad BCM. If this does work, let the rest of us know.
Bob T
RLTherio is offline
