GM Mirror Auto dimming/compass/temp - Chevy Colorado & GMC Canyon
post #1 of 14 (permalink) Old 06-17-2007, 03:45 PM Thread Starter
Installed this morning, about 90 minutes. At the same time I wired my Whistler in as well. All turns on with the key and off with the key. :D
Yes notice that only one small thin cable coming down out of the headliner.
Looking up from the lower right side:
This one happens to be a Gentex 177. All I need now is the temp sensor and plug it in. Can't wait to find one. :) Bought on eBay from salvage yard. This one is from a wrecked Cadillac. $39.00. Retails for 250.00
2006 Canyon SL I4/5SPD
Putco Punch Grill Insert (Denali Style)
Pioneer DEH-P835R | PolkAudio DB6500 Components | 2 JVC EXAD 6" Powered Subwoofer CS-BB2
Gentex 177 - Auto Dimming/Compass Mirror
TruckBox | BedRug bedliner | GM Spoiler and bed Rails
Air Lift Helper Bags w/ Compressor | GM Fog Lights
20% Tint | 4" Nerf Bars | 2010 16" Wheels
jasonhc73 is offline
post #2 of 14 (permalink) Old 06-17-2007, 03:57 PM
Global Moderator
Danny45's Avatar
That's pretty sweet! Is the compass accurate? What about temp gauge, accurate as well?
Where do you live and do you want to install another one?? ;)
Danny
10,000 Posts Club Member #1
Conservative Club Member #2
Danny45 is offline
post #3 of 14 (permalink) Old 06-17-2007, 04:07 PM Thread Starter
The compass only read S, SE, and E. So I got online and RTFM. So I press the compass button for 8 seconds and pick my zone, hold it down for 15 seconds and get a C showing, C for calibrate, drive around in a circle 1 and 1 1/2 times and bingo, it's calibrated. Now it shows the direction I'm driving, yippie...
The install is a lot easier than you may expect. It's all about having the right tools to crimp and strip the wires and enough connectors to do it right. Our little truck has so much room inside the dash and is extremely easy to work with. I have short stubby big arms, and reach up through just about anywhere in there. The A-pilar cover has enough space to 500 wires if you wanted to.
Im in KY/TN, about to move to AL, so it might be a little challenge to "hook you up". ;)
post #4 of 14 (permalink) Old 06-17-2007, 04:50 PM
Global Moderator
Danny45's Avatar
That's ok. How in the world did you do away with that huge wiring harness for that little tiny cable???
I have those stinkin' side air bags. I'd probably set one off is I started messing around in my A pillars.
Danny
Danny45 is offline
post #5 of 14 (permalink) Old 06-17-2007, 08:48 PM Thread Starter
Well, the fact is, that only two wires is all that is needed for the mirror and compass. The wire that I have there is the cable for the radar detector, inside is the + and -.
Now if I can find a temp sensor, that will be two more wires going to the mirror. I'm not exactly sure though that this particular mirror will actually work the temperature indicator. There are two models of the GNTX-177, one like mine shown and the other has the word TEMP where the word MIRROR is located. But so far for about $30 I don't think I'll be out too much if it doesn't work it. If it does work though I think I'll just use a black RJ-11 line or some heat shrink to cover it all.
post #6 of 14 (permalink) Old 06-17-2007, 11:49 PM Thread Starter
Dimmer works exactly as expected, it is actually faster than my previous cars dimmer, I'm very happy with the install.
post #7 of 14 (permalink) Old 06-22-2007, 09:37 PM Thread Starter
Got the temp sensor today. Plugged it in, and nothing. :( Oh well. If you get a auto dimmer and want the temp, it has to have the button with TEMP on it not mirror. GNTX-177 has two models actually, one with COMPASS/MIRROR the other with COMPASS/TEMP. If you want temp don't get the COMPASS/MIRROR one.
post #8 of 14 (permalink) Old 07-01-2007, 03:52 AM
I have the exact same mirror on the compass. Wish i could get temperature too.
2005 Z-71 Colorado
LT255/75 R17 BFG M-T KM ZQ8 rims
Linear-X Bedliner
Xtreme Grille Package
2" lift w/ Full size Spare
K&N Resonator Mod
Low-Profile Toolbox
LED Turn Signal Mirrors
Color Keyed Mirrors 09 style
Illuminated Door Sills
logistixs is offline
post #9 of 14 (permalink) Old 07-01-2007, 07:20 AM
I have an 07 Canyon. It came with the map light mirror so the harness was already there. Bought a Donnelly # 19697 compass/temp/map light mirror and it was a simple plug and play. And everything works.
johnny1 is offline
post #10 of 14 (permalink) Old 07-02-2007, 06:11 PM
Since johnny1 simply did a plug and play then the compass functions are internal to the mirror and all a guy like me with the base model truck needs to do is get the mirror and run power to it? Sweet.
Did you guys also use the factory mirror mount that is glued to the windshield or did you need a new one for the new compass mirror?
2007 Canyon reg cab WT, 2.9/5 speed/G80/3.73, Wait4Me Performance tune, Stealth Gray, Lakeland fiberglass cap, BedRug, Michelin LTX M&S2's, GM Peformance Touring Exhaust, hybrid Volant/K&N intake and mostly debadged.
Visit my Canyon Bonneville Salt Flats project truck blog at http://www.myroadtobonneville.com
rfross is offline
