cb antenna mount with tonneau cover - Chevy Colorado & GMC Canyon
Old 07-26-2012, 07:12 PM   #1 (permalink)
Default cb antenna mount with tonneau cover
i need help finding a place to mount a 3 foot whip for my cb. i just installed the radio itself now i need to find a mounting spot while keeping my tonneau cover. any ideas?
2004 z71 colly
31 inch bfgs
k&n
rest stock
more to come.
Austin148 is offline   Reply With Quote
Old 07-26-2012, 08:08 PM   #2 (permalink)
Default
I have the bigger fender flares on my truck and mounted my antenna on the front left flare. only draw back is there is no good ground so eather you need a NGP (no ground plane) mount, or run a wire from the mounting bolts on the inside of the flare to a ground on the truck frame.
aviationmechanic is offline   Reply With Quote
Old 07-26-2012, 08:21 PM   #3 (permalink)
Default
i was hoping to keep the antenna behind the rear winshield to keep the best signal.
2004 z71 colly
31 inch bfgs
k&n
rest stock
more to come.
Old 07-26-2012, 08:51 PM   #4 (permalink)
Default
I mounted mine in the rear bumper... but you'll need a longer whip. Mines a 5' and i also use a 7' when i need a little more distance.
Look on eBay there are lots of mounting brackets available. Maybe you can find one that will work. Or make your own.
I saw one setup where a guy punched a hole In his soft cover for his whip, LOL.
GregDAP is offline   Reply With Quote
Old 07-26-2012, 09:08 PM   #5 (permalink)
Default
I ALMOST thought about that but then was like wait.. that wont work lol. my cover is plastic im almost thinking about removing it. the only thing keeping it on is the idea that it saves mpg. i like the look of the wire being hidden. so its either mount the antenna to the bumper, or remove that ridiculous tonneau cover and mount it simply there.
2004 z71 colly
31 inch bfgs
k&n
rest stock
more to come.
Old 07-26-2012, 11:50 PM   #6 (permalink)
Default
Mine's not in back of the cab, but it's good for 5 miles line-of-sight communication.
Off the wall CB Radio Questions
2008 Chevy Colorado 4x4 standard cab
31x10.50 Goodyear Wrangler Authority
Midland 1001WX CB w/ 3' Wilson antenna on driver's side fender
60/40 split bench converted to 40/40 buckets
Console from 1992 Jeep Wrangler
smokeybear is offline   Reply With Quote
Old 07-27-2012, 12:03 AM   #7 (permalink)
Default
this is how I mounted my antenna you can put your on the rear fenders (if you have any feders)
Old 07-27-2012, 08:53 AM   #8 (permalink)
fitsector's Avatar
Default
Oh, thatīs new, you mounted your antenna in the front fender flare, is that stiff enough? I mean the fender flare is plastic...
Proud owner of American Pickup trucks since 2006
2009 1LT Crewcab Z85 2.9 L4 2WD Deep Red
Magnaflow performance catback exhaust
Underground hard tonneau Cover
2012 2LT Crewcab Z71 3.7 L5 4x4 Navy Blue
Still stock, mods about to come!
fitsector is offline   Reply With Quote
Old 07-27-2012, 09:41 AM   #9 (permalink)
Default
Not cb but if you look just above the gas cap you will see the base. All it is is a flat piece of metal bent 90 degrees and clamped in place by the tonneau cover. I do have it bolted inside the bed to provide better grounding. The cable drops between the cab and bed and enters the cab through the rubber air vent and then to the radio..
Reached 100,000 miles on 1/28/13
davn is offline   Reply With Quote
Old 07-27-2012, 07:59 PM   #10 (permalink)
Default
I have had the antenna mounted there for about 2 years now and there is ,so far, no signs of torqing, streatching or splitting. but yes, I didn't think it would hold for vary long because it is plastic.
You may not post new threads
You may not post replies
