4L60-E Mod/Upgrade Info (with Pics) - Page 2 - Chevy Colorado & GMC Canyon
post #21 of 66 (permalink) Old 04-29-2009, 08:47 AM
Re: 4L60-E Mod/Upgrade Info (with Pics)
Originally Posted by S.C. Colorado
would anyone recommend installing a cooler if i don't tow anything but instead just do alot of stop and go traffic??
Yes. Make sure you get a bypass on the cooler to help the fluid warm up to operating temps faster. So far I have noticed a 20-25 degree drop in ATF temps in stop and go traffic. And it is not even the dead of summer yet. Outside temps have been in the 90s already and without the cooler the tranny temps were rising over 200F!!!!
Steve
jackedupcanyon is offline
post #22 of 66 (permalink) Old 04-30-2009, 07:15 AM
most def. guys. it's on my upgrade list asap. bad thing and good thing is that i'm stationed in germany, so there will not be any 90 degree temps....maybe 80 at the highest. and bad thing, warming up is going to be a bitch on the transmission if it's not done.......wonder which is a the most harmful? high temps of summer or improper warming up in winter?
Metallic Orange, 2005 Colorado LS Z71
-Debadged (except for Z71 decal)
-2 Front 6 3/4" Kicker 07DS400
-2 Rear Pioneer Premier TS A643P
-Pioneer DEH-P5100UB CD player W/Ipod port
-Truxedo Tonneau Cover
-Brush/Hand painted interior trim peices/color matched to body and clear coated
-All outside plastic peices painted gloss black/clear coated
-Bowtie and Grill painted black/clear coated
-30% all around tinted windows
-Granite Alloy Rims covered in General Grabber AT2's
-FIPK GEN 2 K&N Cold Air Intake
-PCMforless Tune
-MBRP Dual Rear Exit Exhaust
S.C. Colorado is offline
post #23 of 66 (permalink) Old 04-30-2009, 09:06 AM
It will by-pass fluid at start-up and in the winter so you should see very little difference between having a cooler and not till fluid gets warm enough. If stop and go traffic is bad enough, you could still break 200F in 80F weather. I did anyway.
Steve
post #24 of 66 (permalink) Old 04-30-2009, 07:44 PM
Cooler would be nice but a six speed would be super cool!!
wpage505 is offline
post #25 of 66 (permalink) Old 04-30-2009, 07:53 PM
holy fack. i started reading the post - then decided to scroll to see what i was getting myself into. ended up just looking at the pictures. good resource tho. great job.
burn is offline
post #26 of 66 (permalink) Old 05-01-2009, 04:10 PM
BahamaTodd's Avatar
If anyone's interested, for those in colder climates it might be a good idea to install a thermostat to bypass the cooler until operating temp is reached.
http://static.summitracing.com/global/i ... _15719.pdf
My trans cooler + thermostat installation:
viewtopic.php?f=1&t=51229
2004 GMC Canyon SLE Ext Cab Z71 4x4
Site Rules
BahamaTodd is offline
post #27 of 66 (permalink) Old 05-01-2009, 05:25 PM
Or buy a cooler with a bypass integral to the unit although they might be limited in size based on manufacturer. External thermostat has more cost involved and more potential for leaks with all the extra clamps and fittings but you are also more assured that temp will not drop any till the fluid is warmer and starts moving thru the cooler.
Steve
post #28 of 66 (permalink) Old 05-01-2009, 09:31 PM Thread Starter
I had kicked around the idea of using the thermostat and then discovered the cooler with a bypass built in. Unless you live in the deep South, it's good to have one or the other.
BTW: Nice looking install, Todd. :D
post #29 of 66 (permalink) Old 05-04-2009, 02:48 AM
Send a message via Yahoo to dirtydawg
Hey sarge, do you know what kind of fittings are on the cooler lines at the tranny? I'm planning a remote cooler install and need to have the hoses made up. I'm looking at going with the AN fittings at the cooler for a cleaner install. I'd like to stay away from barbs and clamps -- just my hangup. Thanks for the help.
2007 TOTW #33 - LIFTED CLUB #24 - CONSERVATIVE CLUB #43
Rancho 4" / Skyjacker Softride / PA 3" - ProComp Xterrain 305/70R16 - 16x8 Eagle 1378
Smittybilt XRC-8 Winch - Optima Red - Hella 4000 Compact Fogs - AEM / PCMForLess - E-fan - Hard Cover
dirtydawg is offline
post #30 of 66 (permalink) Old 05-06-2009, 01:52 AM Thread Starter
^^^^^^Let me get back to you.
post #31 of 66 (permalink) Old 06-06-2009, 12:52 AM
Send a message via Yahoo to breaker104
Originally Posted by ssgjurista
I'm in the same situation and I installed one. Certainly can't hurt.
What exact model tranny cooler did ya use, like part # wise?
"If it ain't Metal, it ain't music!"
And yes, I AM a black dude!
K&N Drop in Filter Flowmaster 40 series Muffler Hp Tuners (Loving it!!!) 'Vette Servo
Coloradofans.com member 12345! My Vin # ends in 666!
breaker104 is offline
post #32 of 66 (permalink) Old 06-07-2009, 11:05 AM Thread Starter
B & M part number 70264.
post #33 of 66 (permalink) Old 06-07-2009, 11:20 AM
Thank you, sir!
post #34 of 66 (permalink) Old 06-07-2009, 01:06 PM Thread Starter
You're welcome. :D 'Sir' isn't necessary.
post #35 of 66 (permalink) Old 06-07-2009, 01:16 PM
That's a good cooler. I have the same one.
Steve
post #36 of 66 (permalink) Old 06-07-2009, 01:48 PM Thread Starter
Yep. And the reason I chose it over the others is because it has the internal bypass feature.
post #37 of 66 (permalink) Old 06-07-2009, 04:08 PM
Yep. Me too!
Steve
post #38 of 66 (permalink) Old 08-15-2009, 08:54 PM
so after reading till my head hurt.... the best thing to do is servo and cooler?? or did i miss something... 06 i5 2wd crew
Huvster is offline
post #39 of 66 (permalink) Old 08-22-2009, 07:51 PM Thread Starter
Install the cooler first, then the servos.
post #40 of 66 (permalink) Old 08-22-2009, 08:13 PM
Since I already have the vette servo, anything I should be on the lookout for when I get around to the cooler?
