Best lower cost mods for improved mileage? - Chevy Colorado & GMC Canyon
post #1 of 10 (permalink) Old 08-14-2011, 10:56 AM Thread Starter
I am looking for input on what to do to increase gase mileage on my truck. I have installed a Volant CAI Power Core and plan to get a MBRP Single outlet exhaust.
Mods I am looking into
Ported Throttle body--Does this increase gas mileage or is it purely for HP gains?
Electric Fan--Gas mileage increase or purely for releasing power
PCM reflash--What real world Gas mileage gains do you get?
US Navy active duty
2008 GMC Canyon SL EXT Cab with 3.7L upgrade
spyder79 is offline
post #2 of 10 (permalink) Old 08-18-2011, 02:50 PM
chevy_luver's Avatar
Any kind of simple bolt-on parts like will give u better mileage, more hp, and more torque. This is because these things don't change how much gas goes into the engine unlike a performance chip. the big things that really help are the ones that let the engine breathe better than stock parts. Exhaust system - yes. Cai - yes. Ported tb - yes. New headers - yes. Pcm tune - yes. E-fan - yes, not a whole lot. Maybe not even enuf to mess with, I'm not sure. Anything that will let your engine breathe better will do some good. Even getting a different grill that will let more air under the hood might do somethin for ya. A billit grill or something. I smacked into a bird a while back and put a big hole on my grill and my truck seemed like it had more get-up. Good luck with ya. O and if u get a tune make sure u do it after the bolt-ons. It just kinda finalizes everything
chevy_luver is offline
post #3 of 10 (permalink) Old 10-14-2011, 03:14 PM
res delete, remove cats, header...pretty much what was said above
2007 GMC Canyon 3.7L SLE Crew cab 4x4
K&N CAI
All-Flow cat in place of 2nd cat
Intake Resonator Delete
JTR Shorty Header
Sound Solutions muffler
31x10.5R15 Wild Country MTX
1971 Pontiac Catalina 400
1969 GMC C2500 305 V6
luraycanyon is offline
post #4 of 10 (permalink) Old 10-14-2011, 09:13 PM
ummmmm... put the 1000 bucks you want to spend into gas.
would take YEARS to recoup the modding cost
LIFTED TRUCK #244, back to stock height
2006 chevy colorado
4 cyl
2wd (1wd)
red
bedliner
toolbox
borla muffler stock pipe
gutted cat
china intake with k & n
aal in rear, also 2 inch block to get near stock height
SUSPENSION MAXX rear 1.5 inch shock extenders
SUSPENSION MAXX Front lift spacer now taken off for now
1 inch body lift, removed
now zq8's with 235/50/17
rear air shocks
bobandcar is offline
post #5 of 10 (permalink) Old 10-17-2011, 10:00 PM
NewColy's Avatar
i'd look at tires and pcm tune first. what size 15's and brand? i'd skip the e-fan considering it gets so hot down here.
NewColy is offline
post #6 of 10 (permalink) Old 10-18-2011, 11:29 AM
Our e-fans and tune should pick you up a couple MPGs as well as 20-30 horsepower.
marshall@pcmofnc is offline
post #7 of 10 (permalink) Old 11-04-2011, 12:34 PM
Another cheap one, is use the gasoline with no ethanol, it costs about 6 cents more per gallon than regular, and you can pick up 1-2 mpg.
K&N CAI
JTR Shorty Header
post #8 of 10 (permalink) Old 11-04-2011, 07:50 PM
Send a message via AIM to rodhot Send a message via MSN to rodhot
for sure DO NOT put oversize overweight tires on you will KILL performance MPG and suspension parts$$$$$$
rodhot is offline
post #9 of 10 (permalink) Old 12-01-2011, 09:28 AM
well i don't think it would hurt to put on a couple of tire sizes bigger. it depends on what he mostly drives - city or interstate. if u are looking for mileage in town then go with smaller tires. interstate- go with 1-2 sizes bigger.....let me try to explain it the best i can..... the speed goes by how fast the axle turns with stock tires and if u put bigger tires on then u cover more area per axle revolution and also go faster. so if u r cruising at 2000rpm u might be at 70mph. with slightly bigger tires u will be showing 70 on the speedo but actually running about 73-74. so u can drop your speed to about 67 - and rpm to about 1800 to 1900 - and get better mileage. i hope this makes sense. sorry if it don't
post #10 of 10 (permalink) Old 12-01-2011, 01:32 PM
The biggest thing affecting gas mileage is drag. The biggest drag component is wind resistance followed by tire (rolling) resistance. The next major gain can be had by modifying driver behavior.
The only thing I know to do for wind resistance is install a Tonneau cover or topper/cap. You can also run with the tailgate down. Some people claim lifting raising a truck negatively affects mileage. I have not bee able to quantify that. I can not prove or disprove that statement. I'm thinking when people lift their truck that they also install larger (wider) tires. More tread on the pavement usually means more drag and poorer mileage. Also larger diameter tires reduce the recorded miles (odometer reading) and people may be looking at incorrect data.
Low rolling resistance tires can be had. The original Generals that we all hate were low rolling resistance tires. Moving less weight helps marginally with rolling resistance. Of course correct tire inflation helps on rolling resistance.
The last drag component is speed. Slow down and you have less total drag per mile.
That leaves driver behavior.
I once built a small electronic stop watch (timer) and wired it to the brake light switch. I had my daughter drive using it and showed her the amount of time she used the brakes vs. the miles she drove. After collecting data for a month she had almost 5 times the braking time per hundred miles on her Blazer that I had driving my truck. She learned to look ahead, coast to stop lights, plan for things a block ahead of time and stop tailgating. She improved her mileage by almost 4 mpg. That is 20%.
Anytime you use the brakes, Kinetic (motion) energy is lost and converted to heat. You then use more gas to get the vehicle moving again.
Some additional minor gains can be had by tuning, air intakes, etc. but addressing the above three will give you the most gain.
