got a P0787 trouble code - Chevy Colorado & GMC Canyon
post #1 of 3 (permalink) Old 07-17-2016, 10:16 PM Thread Starter
Chevyman0714's Avatar
i got a P0787 trouble code transmission will shift to 3 gear but wount go into over drive any help on this please
Chevyman0714 is offline
post #2 of 3 (permalink) Old 07-17-2016, 11:03 PM
to C'Fans.
It would help if we knew what model year and what engine you have.
P0787: 3-2 shift solenoid control circuit low voltage.
Could be a defective solenoid (located inside the transmission), a wiring problem, or (rarely) a defective TCM or PCM depending on the year of your truck.
Check the wiring/connectors for the transmission. Look for a round 20 pin connector. Some guys have had problems cause by rodents chewing on the wiring.
post #3 of 3 (permalink) Old 07-18-2016, 03:42 PM Thread Starter
I have a 04 with the 3.5l 5cyl 4wd
