how much does paint cost? - Chevy Colorado & GMC Canyon
post #1 of 5 (permalink) Old 06-03-2009, 06:11 PM Thread Starter
Send a message via AIM to iigw Send a message via Yahoo to iigw
This is in my eyes a general step by step list of “how” to paint a bumper. (this can be used as a general guide for painting other parts also, such as a hood/fender/roof, but does not take in the event of adjacent panels where blends need to be added in, blends require more labor and work.)
I do paint, so let me try to break this down a bit so there is more understanding of paint pricing..
I figure depending on the color it would be about ½ pint to 1 quart of color needed. (Some colors are opaque and you need either an under coat, think painting the part white if it’s a yellow color)
So let’s just say you have a black truck.
Ok in this instance were painting a bumper cover, the 2nd gen SS.
1. The part is “ready to paint” right out of the box. Never. Never is anything ready to paint out of the box. It must be inspected for any problems, deep scratches, or any “dents” that will need to be repaired (yes it’s a plastic, but they can have big warps that look like poop when painted)
2. once inspected, and lets say our bumper cover is 100% perfect no flaws it has to be moved into the paint booth and placed on a bumper stand.
3. the part has to be wiped down/cleaned with solvents, to remove any traces of mold release agents, and those dirty greasy paws you used to move the cover in the booth.
4. get the paint code from the truck and mix the paint.
5. spray a test panel and see how much tinting has to be done to match the paint to the black truck (black is not black)
6. get your gear on and pour the paint into the gun and step into the booth.
7. use a tack rag and wipe off any dust or lint left behind from wiping the bumper off with cleaning solvents.
8. spray on adhesion promoter, and let dry for the 20-30 mins recommended.
9. spray on a first coat of paint. Since this is black, it covers really fast, and in 3 medium wet coats the bumper is fully “covered”.
10. leave booth, and start mixing the clear coat. Get out the clear gun and fill it up with the new nice mixed up clear, go back in booth.
11. spray 2-3 wet coats of clear on bumper. Oooh shiny.. let dry over night, or leave booth and turn to bake for the recommended times/heat range.
12. remove “dry” bumper from booth. Take to prepping station.
13. place bumper on stand and wet sand with 1000, 1200, 1500, 2000 grit sand paper.
14. get out your trusty buffer and compound and get to buffing…
15. remove cutting buffing pad and replace with polishing pad, get out your finer grade (finesse) compound and start buffing…
16. remove the polishing pad, and get out the foam pad, switch the compound to swirl remover, and get to buffing…
17. when all steps of buffing are done, get out the hose and soap and water and start washing that bad boy..
18. dry and use a glaze (not wax, wax seals and is not breathable, your paint is “dry” but not cured, needs air and time to cure) to get that super deep wet look we all long for.
19. tell higher ups bumper is done. Higher ups (management) comes out to inspect bumper. Gets the “OK” and calls customer/owner to come pay and take it away.
Now this simple out line of work is pretty straight forward, and should be completed on pretty much any paint job, fender, or bumper repair.
There are steps left out, as this bumper did not need any repairs, or primering, or even a two-tone paint job (think racing stripes, or the cool little silver addition around the “fog light” holes)
So for a break down
I see about:
3 hrs from start to clear drying.
2 hrs for sanding and buffing
5 hrs at $65 dollars per hour is $325
Approximately $150 dollars in materials
Grand total of $475
So if you’re getting less then this price, or if you ask the shop about any of these steps and they aren’t performing them, you might think twice about that deal your getting.
I am also not saying you won’t find a friend or know someone who will get you a cheaper price, but when it comes to paint just be careful….
www.ifitsgotwheels.com
Orado build thread http://ifitsgotwheels.com/phpBB/viewtopic.php?f=25&t=63
iigw is offline
post #2 of 5 (permalink) Old 06-03-2009, 08:54 PM
Re: how much does paint cost?
An auto body shop owner/friend told me each panel on a car costs $500 to paint. If the car has 9 panels (hood, doors, roof, trunk, fenders, quarter panels) the squirt costs $4500..just to apply the paint on a properly prepped surface.
Your explanation makes perfect sense and accurate for the auto body industry. Thanks for the valuable education on the steps involved.
BedRug
Catch-All Xtreme Floor Guards
ZQ8 tailgate decal
Factory foglights added
upflying is offline
post #3 of 5 (permalink) Old 11-04-2009, 04:14 PM Thread Starter
:BUMP:
iigw is offline
post #4 of 5 (permalink) Old 11-05-2009, 08:16 AM
Send a message via AIM to FixxxerKH202
yup any respectable guys i talk to are about $500 a panel
good info for the inexperienced modders
I got another little tip for you guys DONT BUY EBAY PAINT most of it is garbage unless you are paying maybe $5 less for a major manufacturers paint i purchased some corvette red and got a real deal on it about $50 for enough to paint an entire s-10 well needless to say in about 6 months that corvette red was a pale orange disaster not to mention it had no flex and cracked off every plastic part that was painted with it, it was definitely deterioration from U.V. light so someone forgot one of the components of this paint as it was premixed and ready to spray as i got it
Like iigw said you never get a deal on body work its a very respectable trade in which everything has a set price just pay it if you want to be happy with the job done
FixxxerKH202 is offline
post #5 of 5 (permalink) Old 11-05-2009, 01:19 PM
Thanks for the info...Body work is something I'd like to learn to do.
2009 Colorado Z85 Standard Cab, WT1, Summit White, I4, Automatic, 2 Wheel drive.
Call me Mr. Vanilla!!!
Unfettered is offline
