will silverado rims fit? - Chevy Colorado & GMC Canyon
post #1 of 12 (permalink) Old 01-19-2016, 06:22 PM Thread Starter
i just lifted my colorado 1.75" in rear and 2,25" up front and im wondering if silverado rims from an 05 silverado Z71 will fit. they have the same bolt pattern but a buddy of mine said the hub hole is different. any help? thanks!
07streetqueen is offline
post #2 of 12 (permalink) Old 01-19-2016, 06:23 PM Thread Starter
my truck is an 07 colorado, no z71 package
post #3 of 12 (permalink) Old 01-19-2016, 06:37 PM
Your buddy is correct. They will need to be bored out to 101mm(I think) in order to fit
GregDAP is offline
post #4 of 12 (permalink) Old 03-04-2016, 09:13 PM
the Colorado and the Silverado do not share the same bolt patern. yes both are 6lug but the distance between the studs is smaller on your truck. however, hummer h3, trailblazer, saab 9/3 and a couple other vehicles used the same chassis. those rims will fit.
2010 5.3 is offline
post #5 of 12 (permalink) Old 03-23-2016, 10:17 PM
Tweek's Avatar
If your talking 355... Yes they will fit... Center must be bored as GreDap stated... I think to 100 mm
" Diamond"
2015 Chevrolet Colorado LT , Ext. Cab
Silver Ice Metallic
3.6 V6 DOHC 6 Speed Auto.
17" Blade Silver Metallic Aluminum Wheels
3:42 Gear G80 Auto. Locking Rear with Tow Package
8" Mylink Entertainment Center
GM Performance Exhaust
Tweek is offline
post #6 of 12 (permalink) Old 03-23-2016, 10:30 PM
Just one more reply, why not.
Yes the bolt pattern is in fact the same. Just to clear that up. But as others have stated, the hub bore is too small and will require a larger diameter, or wheel spacers but I can't remember the minimum thickness.
I do not believe a trailblazer wheel will fit and I am clueless about the H3, although they share many components. I'm sure you won't be installing a SAAB wheel so I won't go there.
post #7 of 12 (permalink) Old 03-28-2016, 10:39 PM
Tweek's Avatar
H3 will fit... Direct bolt...
" Diamond"
Silver Ice Metallic
Tweek is offline
post #8 of 12 (permalink) Old 04-18-2016, 05:18 PM
CanyonDreamer's Avatar
Can someone photoshop this?
Dreaming for now, but will realize the dream shortly.
CanyonDreamer is offline
post #9 of 12 (permalink) Old 04-18-2016, 07:24 PM
post #10 of 12 (permalink) Old 04-18-2016, 07:31 PM
ADMIN
Blue15ColoradoLT's Avatar
no need to photoshop, its really been done:
2015 Laser Blue Colorado LT
CC, 4X4, V6, SB
LED light bar - 32"
HID headlights
LED fog lights
LED high beams
LED reverse lights
LED license plate lights
LED visor lights
LED dome lights
LED bed lights
LED tail lights
LED sidemarkers
Canyon swapped tail lights
Red painted calipers
Supermod ported throttle body
Silver metallic rally stripes
Super Skidz skid plate
Volant CAI
***NOTE***
SITE RULES
Blue15ColoradoLT is offline
post #11 of 12 (permalink) Old 04-29-2016, 02:38 PM
There was one on clist that had Silverado rims on it. No lift I think he said he got some rub but nothing too crazy.
pwoller is offline
post #12 of 12 (permalink) Old 12-08-2016, 06:09 PM
vezpa's Avatar
Rims off many Toyotas and Lexus will fit because of their large hub openings and same bolt patterns.
Mine are off a 2010 Lexus GX60.
vezpa is offline
