LinkBack | Thread Tools |
#41 (permalink) |
Well i love older cars, and i love my rado. so i put them together. yes theres ALOT of work in chopping. the h3 front would relatively bolt right on, with mods to the back of the fenders and the hood with 2'' wheel spacers. Did all the work to put the h3 front on but ran across this first. At least i have a truck to drive again instead of my 68 olds w31 which gets 3 miles per gallon.... I just couldn get rid of her after she got hit so she on her second life. haha
Lee Summers Owner of Summers Show and Go http:www.summersshowandgo.com I can get you anything thats in summit and jegs, cheaper too. Just PM me AWS Certified welder I-CAR Certified welder/Platinum tech ASE Master Body Tech Custom Fab. Airbrushing |
| Sponsored Links | |||
Advertisement | |||
#42 (permalink) |
I've seen something similar on ecomodder.com:
http://ecomodder.com/forum/showthread.p ... 11611.html http://ecomodder.com/forum/showthread.p ... p-583.html The first one might help on the "how to build a frame" part. The second one is where a guy built one and is trying to get a business going. Hopefully this helps out.
Canyon & Colorado Club of Canada! #8 06 Canyon WT (plain as plain gets - even has roll-up windows) Sunburst-Orange (funky colour) I4 with auto (3.73 axle) 18" Extreme wheels with 235/50R18 Yokohama ENVigor ScanGauge II, Sirius, Spray-in liner, Truxedo LoPro Tonneau cover Debadged, Front Logo painted black, 3rd brake-light flipped, Steel Roll-pan, RedLine hood struts KRFabs low-profile transmission cross-member (2011 project: 2/3 drop from Belltech-12001s/blocks) |
#44 (permalink) | |
The one I've got coaxed up is gonna be 10x's nicer looking than those...
2006 Chevy Colorado Z71 Crew Cab 3LT - Magnaflow Cat-Back Stainless Steel Dual Exhaust ( Part # 15847 ) - K&N F.I.P.K. - 2 Cold Air Intake System - 31" Maxxis Bighorn Mud Terrains - AVS Ventshade ( 4 Windows / Sunroof / Bugshield / Back Window ) Visors - Access Soft Tonneau Cover - 9 Light L.E.D. Tailight Bulbs - L.E.D. Tailgate Light Bar The famous "Trivium" Decal... ![]() YELLOW TRUX RULE!!! Facebook - http://www.facebook.com/DemonicSoulRakouDaimo MySpace - http://www.myspace.com/holydemonrakou YouTube - http://www.youtube.com/user/DemonicSoulRD |
#46 (permalink) | |
#48 (permalink) | |
#49 (permalink) |
Could you start with a colorado hard top tonneau cover and frame up the front sides to fit it up to cab height? That way you would have all of the lift/door bracketry in place.
http://www.andysautosport.com/chevrolet ... 79811.html Or you could morph the hard tonneau cover to a cap(topper) cut down at a slant and for sure utilize the front window behind the cab and then probably some side windows with some retrofitting. It would be more expensive (unless you can find a used cover and cap) but it would give you a lot to work with. Or cut down a cap/topper at the slant you like and put a soft tonneau cover on it...same look but a little different way to get there. Sorry if these ideas are dumb...
2004 Black Chevy Colorado Z71 Crew Cab 4x4 |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
