Sub Box Showcase - Chevy Colorado & GMC Canyon
post #1 of 4 (permalink) Old 11-12-2008, 09:20 PM Thread Starter
Sub Box Showcase
Here are just some of the sub enclosures posted by our members. Some of the post have links to the original build thread.
This showcase is for viewing only so any questions or comments can be done by clicking on the members name to PM the owner.
If you would like to enter your set-up you can do so by posting it here...Sub Box Entries
06 Ext Cab Xtreme. 3.5 Auto. 200 Amp Alternator With 1/0 Big Three Wiring Upgrade.
Four Way Active Audio System. Alpine CDA-9887 HU. Alpine H701 Processor and C701 Controller.
Hybrid Audio L1 Tweeters. Hybrid Audio L3 Midrange. Hybrid Audio L6 Midbass, Two TC Sounds 12" Subs.
Sundown Audio 100.2, Sundown Audio 100.4, Sundown Audio 1200D Amps.
TexasXtreme is offline
post #2 of 4 (permalink) Old 11-12-2008, 09:30 PM Thread Starter
Re: Sub Box Showcase
Regular Cab Showcase
This Post Is Courtesy Of...
ZR2003
Reg Cab Z-71
Image Dynamics IDQ10V3 D2
1.3cft. NET Ported Enclosure tuned to 28hz (self built)
Power comes via PG Xenon 600.1 (847watts according to the birthsheet)
This is my first set-up in this truck. I have big plans for a major change in the spring.
See more of my truck here... viewtopic.php?f=7&t=61323
rrcn
2006 Chevy Colorado - reg. cab
Sealed box.
Two 12" MA Audio 1200XL's wired down to 1Ohm
MA Audio SY7011DX amp. 1500W RMS.
Built by me. Trim rings fabbed by Hannibal.
Build thread: viewtopic.php?f=7&t=61657
regal89cdk
1. 2006 Regular Cab
3. Sealed enclosure 3/4'' mdf
5. Pioneer shallow 12''
6. JL Audio 300/4 amp
7. Designed/built by me
8. There are 2 Kenwood 6x9s on either side, all 3 sections share common back and bottom like an L from the side.
Then tops fronts and sides were assembled and mounted on the common pieces.
Some have said it was dumb to put the 6x9s back there with the sub, but it sounds excellent- come by and listen if you want.
Have only carpeted the fronts/sides as of now, eventually I'll finish the carpet, but it is a heavy heavy piece.
Amp is under the passenger seat and have Sirius unit under driver seat.
(I know, lots of screws, oh well with them and the glue and silicon)
WTRacing
Built by me
2 Ecplise 10's
Directed 500w amp
Covered (by me) in black suede
solem38
2006 Chevy Colorado Reg Cab
JL 12"
Pioneer 300 watt amp
Pro wedge case cut to fit a 12" with a spacer
Pioneer Avic d2
post #3 of 4 (permalink) Old 11-12-2008, 09:53 PM Thread Starter
Extended Cab Showcase
Colacanyon
2005 GMC Canyon Ext. Cab
4- Kicker 10L5
2- Kicker ZX1000.1 (ran at 2 ohms)
Sealed box, not sure on volume
Built by Ultimate Audio- Lexington SC
TexasXtreme
This was the first box I built for my Colly.
It housed two 8" Rockford Fosgate P1's.
For such a small enclosure it sounded great.
It was sold the another member so I'm not sure if it is still in use.
Here's the original build link....
viewtopic.php?f=7&t=37344&st=0&sk=t&sd=a
TexasXtreme
06 Colorado Extended Cab.
Two .9 cubic foot sealed enclosures.
Total displacement = 1.8
Two 12" TC Sounds TC-9 Subs.
Sundown Audio SAE 1200D Amp wired at 1 ohm.
Custom built and installed by myself.
Notes:
Subs are down fire and required the removal of both jump seats, jack and rear console.
Box is finished with roll on bedliner and carpet across the top.
More info or questions on the complete build can be found here...
viewtopic.php?f=7&t=42957
Or here.... viewtopic.php?f=7&t=60794&st=0&sk=t&sd=a
braindead1684
2007 EXT Cab
1 RockFord Fostgate Punch 10"
460w Jenson AMP underpassenger Seat.
3/4" MDF The Sub BARELY Fits but it can't be any wider to fit between the rear seats and the toolboxes.
Retains Complete funtionality in the rear as well as centerconsole access.
IPAINTM
06 canyon EC
2 15" Kicker solo-baric L5
2 hypnotic 600w amps
MDF sealed box w/ glass top
self built and hated every minute of it!!
isht4r
Here is my cheap looking system
weddlz
Similar to others with EC trucks. Image Dynamics 10" pushed by Alpine M500. Amps are under the seats.
burn
PPi PC2100.1 amp. Blaupunkt ODw1000 sub. 0.75cuft.
2006 Colly Z85 ext cab. built / installed everything myself. 100% stealth.
Both seats fold down and are still functional (ppl sit on them all the time) and no problems - I just turn the amp / sub off
More info can be found here...Original Build Thread
jheffley
Here is a couple of my store bought one, it works great, espicially since it cost me under $100
GLN305
In progress pics of mine: 3 x Dayton Audio Reference 15's. 2000 watts RMS
More Info Can Be Found Here...Orginal Build Thread
Deep Ruby Red 07
2007 Colorado Z85 Extended Cab
Sealed enclosure
2-12" Rockford Fosgate Punch
1200W Sony Xplod amp
Custom built
byamaha
05 Red Rado 4x4 z71
2 JL 13W3's
4 Memphis 6x9s
JL 500/1
JL 300/4
Its a ported enclosure. Im not sure the airspace. Plexiglass over the 500/1 with a custom cut JL out of it.
Led's that light up the amps. Built by RD Audio and Security New Orleans, LA.
Most I've hit was 145db.
Sonoma825
Here is my Setup
1] 2005 Chevy Colorado Z71 Ext Cab
2] viewtopi ... =7&t=67269
3] Sealed
4] .36 cu in
5] 2 PIONEER TS-SW251 Shallow Mount 10"
6] Tsunami Wiring, Reg Battery Infinity Reference 7451a 4-channel amp 111x4 watts
7] Built by ME!!!!!!!!!!
8] I didnt lose any space in the design of this setup, it took about 1 month to complete
csharp
ok heres my ext cab with two kicker comp 12 pushed by a kenwood 1000 wat amp and a 2.0 fared capacitor
post #4 of 4 (permalink) Old 11-12-2008, 10:04 PM Thread Starter
Crew Cab Showcase
Angren8
kicker 10" l7, kicker zx750.1, dont remember the box specs, built by me!
DBNissan
2005 Chevrolet Colorado ZQ8 Xtreme Crew Cab
Sealed
JL Audio Stealthbox
Single down-firing 10w3
Purchased from local audio shop
Powered by JL Audio 500/5
Current Stealthbox incorporates a 10w3v3 capable of handling 500w
Belizeanlow
this is mine jl audio stealthbox with jl audio 300/4 and 250/1 and soon to come jl audio 500/1 because the sub can take 500 rms.
Kranz38
2005 Colorado Xtreme CC
Site is down for a build thread, will post @ a later date.
Ported
12.4-5 Cubes @ 32hz after Displ.
2 18" Fi Bl's
3000 wrms Massive P3000.1
Built with a friend, and a beer or 10.
HighzerOfLife
only have my S*%tty camera here so here are a couple bad pics for now. post better ones later
SuperEco06
Two Versions, First is three Subs
Second is Two Subs
Truck: 2006 Chevy Colorado Crew Cab
Subs: 2 or 3 10" Pioneer Shallows or Comparably Sized Woofer
Manufacturer: Yours Truly
izzkidioto
Here is a photo of my stolen box....BOOOOOO!
JustinS
1] 2006 Colorado CC
2] Ported Fiberglass
3] ~1.75 cuft with 555 cuin port volume.
4] 10in Kicker L7
5] Concept CD-810 Class D Amp
6] Built by me!
Here are a few others I have built:
Trojanroever
heres mine
2005 CC Ls 4x4
boston acoustics G5 10" with .5 ft
kenwood amp ran @ 500rms
and no those are not rhinestones those are stainless steel tacks.
GregW
I bought the crew cab 10" downfire sub box from SubThump.com and I am very pleased with it.
I have one Fosgate Audiophile sub powered by a Punch 3002 - bridged to 300 watt x 1 @ 4ohms.
Wrayzor
Box built by Canyon41. Measures approx .47 to .5 cubic ft airspace.
Pioneer TS-SW2514D Sub. 250 to 1000 Watts
Powered by Pioneer GM-5100T at 380 x 1 at 4 ohms (Bridged)
Closed Thread
