Wiring trouble, aftermarket HU won't turn on - Chevy Colorado & GMC Canyon
post #1 of 4 (permalink) Old 01-13-2016, 01:16 PM Thread Starter
Akaeda's Avatar
First, to get this out of the way, I have a Scosche GM2000 harness, which I know is a sin, but it was bought by my girlfriend, and I would rather tear it apart trying to get it to work than telling her it's junk (hurt feelings avoided).
That being said, I've also never tried anything like this before, so I'm more apt to think that I'm screwing something up before blaming the wiring.
I've got a 2005 Colorado and I am trying to replace the factory 6 CD radio with a double din BOSS BV9364B touchscreen radio. From what I seen, all the wires matched color-for-color between the radio harness and the Scosche harness. I have several wires that did not have pairs, but these wires aren't used from what I seen. With the harness came the chime box, which is connected, and dinged a couple times when I cycled the key, but the radio itself wouldn't power up.
I've got all the diagrams for everything, assuming that colors match colors, what am I missing? I heard there's a wire that's supposed to run to the fuse box? If so, I don't have one...
Here's what I've got.
(Radio harness wire connected to aftermarket harness)
1. Black ground connected to black "Chassis ground"
2. Yellow battery connected to 12V battery constant
3. Red acc switch connected to 12V Ignition Switch wire
4. Pink parking brake (actually light green, not sure what happened there, but it's not connected to anything yet)
5. NC (not used)
6. Orange Rearview camera (not used)
7. Blue antenna (not used)
8. NC (not used)
9-16. Speaker connections
Not using the rest since it's all steering wheel controls, bluetooth speaker and backup camera.
On the aftermarket harness, that leaves me with the following:
Orange illumination wire coming off the chime box
I'm sorry if this comes of as a jumbled random mess, but I've attached a single screenshot showing all three diagrams, left is factory, middle is Scosche, right is the radio. If anyone has any kind of advice (aside from throwing the Scosche harness), I'll definitely give it a try!
2005 Colorado
WIP, engine troubles...
Summer fun: 1993 Yamaha XJ600
Akaeda is offline
post #2 of 4 (permalink) Old 02-09-2016, 06:24 PM
Try connecting both the RED wire for the radio power AND the RED wire for the accessory power. That is how I was able to get mine to work.
clarenceray is offline
post #3 of 4 (permalink) Old 04-29-2016, 10:48 PM
I installed my radio and everything was fine then the chimes stopped and next day nothing, I pulled it out and the factory unit worked . So I knew there was power because I could hear the CD player motor, probing the red wire showed no power and it came from the Scosche chime unit hmm. I called the Scosche support line and he said I had to reset the chime module, that was unplugging the chime then plug it in turn the key on and off and wait 10 minutes without opening the doors. It then worked for another day and I called back he said to cut the red and feed it to the ignition on power. The Colorado is a 2010 and the only switch aux power I found was the empty sunroof socket I ran a lead to the red and everything worked. But every once in awhile when turning the radio cuts out and comes back on, I think I need to find another aux switch power tap
srp204 is offline
post #4 of 4 (permalink) Old 04-29-2016, 11:14 PM
Nobody has had good luck with the Scosche wire harness for the Colorado/Canyon computer system.
