Audio Indexes, How-To's, and Tutorials - Chevy Colorado & GMC Canyon
 5Likes
  • 1 Post By Carbuster
  • 2 Post By TexasXtreme
  • 1 Post By TexasXtreme
post #1 of 19 (permalink) Old 08-13-2005, 05:06 PM Thread Starter
With all the current installation tips and how to's, this should help make things easier to find and help reduce the clutter.
Radio Wiring Connectors - Pin out and Color Code - kdeatrick
How to install an amp READ and MOVIE!!! - 1badcolo
Fiberglassing 101 - Hiker9
How to: Door Panels and Radio bezel removal - jax
TIP: How to install a Head Unit - Halonix
Tutorial: Installing AVIC-D1 System in a Colorado / Canyon - useridzero
Fiberglass dash Screen How-To - scott011422
How to: Window Crank Removal - 91CavGT
How to run new speaker wires into front doors with pics - Hiker9
How-To Add Power Door Locks *PIX* - burn
How To: Aux Power RAP Control Mod (Members Mod Project) *PIX* - supermodulation
How To: Ground Effects LED Strip *PIX* - tjm276
How To: Make that ugly after market XM / Sirius antenna go away *PIX* - The Factory
PleaseAdvise likes this.
Carbuster is offline
post #2 of 19 (permalink) Old 08-21-2006, 04:50 AM Thread Starter
post #3 of 19 (permalink) Old 02-09-2008, 06:44 PM
Thought this might help some as well. Pretty much explains everything.
Wiring Schematics
Click on Chevrolet on the left hand side and scroll down till you see Colorado.
Dune is offline
post #4 of 19 (permalink) Old 07-06-2008, 09:25 PM
Re: Audio Indexes, How-To's, and Tutorials
It's been ask a million times so here is where to run power cables through firewall....
Old Salt 53 and SeanAA like this.
06 Ext Cab Xtreme. 3.5 Auto. 200 Amp Alternator With 1/0 Big Three Wiring Upgrade.
Four Way Active Audio System. Alpine CDA-9887 HU. Alpine H701 Processor and C701 Controller.
Hybrid Audio L1 Tweeters. Hybrid Audio L3 Midrange. Hybrid Audio L6 Midbass, Two TC Sounds 12" Subs.
Sundown Audio 100.2, Sundown Audio 100.4, Sundown Audio 1200D Amps.
TexasXtreme is offline
post #5 of 19 (permalink) Old 08-04-2008, 09:19 PM
A lot of you have been asking about the Big Three so hopefully this will help answer some questions.
It is important to know that all the existing wiring should stay in place. You will only be adding to the factory wires.
Shown here you can see that I dressed up the old wiring but it is still in place.
I used 1/0 gauge but depending on your needs 4 gauge could be used instead. I HIGHLY recommend using a inline fuse to protect the new positive wire.
It should be placed as close to the Battery as possible. The fuse is there to protect the wire in case of a short.
Most 1/0 wire is rated to carry a 350 amp load so I would fuse 1/0 at around 200 to 250 amps just to be safe.
4 gauge wire is rated at 150 amps so fuse it at around 125 amps. After the fuse the new wire will connect to the Alternator using a ring terminal.
There are many different ways to do the grounding but this is how I did mine.
From the Battery run the new wire to a single point on the body. This will be the point all the ground wires meet.
I picked this spot because I could easily drill a hole (without damage) for a 5/16 bolt to attach my wiring.
Here's a close up showing the paint has been removed for the best possible contact.
Also note that all the wiring is protect with Techflex and/or wire loom to prevent any damage to the wires.
Use a Star Washer to dig into the body for even better contact. Again note all 3 ground wires intersect here.
This one is a little hard to see but here is where you ground to the engine.
Remove one of the top alternator mounting bolts and again use a Star Washer between the Alt housing and ring terminal.
The last one goes to the frame. This spot is a little tough to get to. I went through the left wheel well.
This is a spot that the brake line is secured. The ring terminal needs to go under the bracket so it is against the frame.
Removing paint here can be down right impossible so here is where that little Star Washer really shines.
I strongly recommend soldering all the ring terminals using a mini torch for a strong, long lasting connection.
Take your time and plan everything out in advance. The results will reflect on your efforts to spend the time to do it right.
Old Salt 53 likes this.
post #6 of 19 (permalink) Old 11-28-2008, 12:10 AM
Very Nice write up!! Thanks for all the links.
Purkle1 is offline
post #7 of 19 (permalink) Old 03-15-2009, 09:56 AM
Speaker Wire Color Codes Made Simple...
SeanAA likes this.
post #8 of 19 (permalink) Old 04-14-2009, 04:35 PM
anything special if I want to change factory tweeters? certain size or anything?
04 Silver birch Canyon Z71 SLE 4x4
Auto; I-5; 31x10.50x15 on stock rims; Canyon Grille Guard
2" torsion bar crank; 2" SuspensionMAXX shackles;
5% tint; Flowmaster 50 series; K&N Air Filter
Custom tune by Stocker2!!!
100,000 miles and counting
Lifted Club Member # 277
rtmsu_02 is offline
post #9 of 19 (permalink) Old 06-07-2009, 12:06 AM
I could not find any place to run the 4ga power wire for my new amp. It seems the usual spot used by most (see the other picture in this thread) is occupied by the clutch assembly for my manual transmission. I have seen 2 different pictures of people using the boot for the steering wheel. Seems my steering wheel doesn't have a boot - it runs thru a steel plate. Sigh.
After asking on 3 different sites and spending 20 min with a flashlight, I gave up and purchased a unibit from Home Depot, plugged in the old-skool drill (my cordless is 12V, not nearly enough to get thru the metal firewall of the truck), and drilled a hole.
I put the hole in a nice clear spot to the lower right of my steering wheel column. There was ample clear space in the engine bay, making it a safe spot to drill. I put a red circle around the hole. The unibit was expensive ($33.99). I filled the area around the hole with some silicone RTV.
kingpinofdisks is offline
post #10 of 19 (permalink) Old 09-04-2009, 01:24 PM
Can i use juper cables as my wires. Cutting them up of course, but would that kind of wiring be fine. the ones i have are rated for 200amps but is only a 6 gauge. as long as i use an inline fuse is this fine?
06 Canyon 4x4 Z85
K&N drop-in with custom intake
Helper coil springs
Custom Gauges
Pioneer DEH-P7900UB
Exhaust Cut-out
Custom fogs with raptor HIDs 8000k
Ported Throttle body
CCFL Halo projectors with raptor HIDs 6000k
20' Vagre V-15 Smack 6 with Nitto 275/45R20's
ichbeincanadian is offline
post #11 of 19 (permalink) Old 12-08-2011, 03:59 AM
Thanks for this info,i purchase a head unit speaks from 12vcity,there are some power wire confused me .
silverdew is offline
post #12 of 19 (permalink) Old 07-16-2012, 09:47 PM
apmurphy317's Avatar
every link i click takes me back to the homepage..
apmurphy317 is offline
post #13 of 19 (permalink) Old 12-28-2012, 12:15 PM
mlee's Avatar
True... none of the links in the OP work
mlee is offline
post #14 of 19 (permalink) Old 01-10-2013, 04:15 PM
I need to upgrade my big three; what is our current amperage of the original alternator? I've heard that the Sierra altenator bolts right into ours and puts out at least twice the amperag, is this true?
mspilmanjr is offline
post #15 of 19 (permalink) Old 03-31-2013, 07:43 AM
Can someone explain why you do the "Big three"? I mean, extra/better grounding i understand, but the fat wire from the alternator, guess its for the charging current? sorry if it sounds dump...i'm about to upgrade my soundsystem so i checked this thread out..and oh yes the links at the top just takes me back to homepage as mentioned above..
Mr Medjetskin is offline
post #16 of 19 (permalink) Old 09-08-2013, 12:30 PM
links still dont work, can someone fix them
grandcanyon90 is offline
post #17 of 19 (permalink) Old 05-31-2014, 04:15 PM
AnimalJim's Avatar
Would like to ask a question about the big 3 upgrade, can i go from the negative terminal on the battery to the frame at the brake line holder, and from there to the engine, and does it have to be on the alternator bolt, can i use the factory grounding point, also the body dont have to be grounded does it
AnimalJim is offline
post #18 of 19 (permalink) Old 07-13-2015, 06:44 PM
kirkc's Avatar
If you are wiring up an amp, the best way for a ground is to ground at the frame directly. However, you need to make sure that wherever you're grounding to is directly off the battery with no splices or taps. So what many car audio professionals do is go straight from the battery to either the frame or to where you want to ground the amp. That's basically what he did and it's awesome work...love it. :)
kirkc is offline
post #19 of 19 (permalink) Old 01-21-2016, 09:55 PM
2005 GMC Canyon.Transfer case ignition for 4wd works but it's not making the Pop you usually hear when the gears go in and the light is flashing.it worked fine last winter I used it.the only thing I did was take out the abs fuse.any ideas
Ronan 116 is offline
