04 Door Speaker Wire Colors - Chevy Colorado & GMC Canyon
post #1 of 8 (permalink) Old 12-20-2005, 12:51 PM Thread Starter
Send a message via AIM to rabidpanda Send a message via Yahoo to rabidpanda
I looked in the sticky and the pin-out, but I still couldn't find what I am looking for. I need to know what wires are pos and which are neg in the interior speakers. As in: what color is neg and pos for each speaker in the interior, including the tweets. If someone can point me in the right direction, I would appreciate it. Thanks...
Dan
'04 Colorado ZQ8 X-Cab
rabidpanda is offline
post #2 of 8 (permalink) Old 12-20-2005, 03:48 PM
Re: 04 Door Speaker Wire Colors
The color codes are in the post by KDEATRICK. What it doesn't show is that each tweeters is just wired parallel with the other door speaker.
That's the way it was in my ' 06 Reg. cab ZQ8.
2006 Colorado Reg. cab ZQ8, 2LT, 3.5L, 5 sp., 3.42 locking rear. Mods: DJM 3" arms & 3" steel blocks, 1.125" trim on rear jounce bumpers, JTR clearance crossmember, Cal-Max rear shocks.
Erle is offline
post #3 of 8 (permalink) Old 12-20-2005, 05:34 PM
Wrayzor's Avatar
Send a message via Yahoo to Wrayzor
In the stick, go to the How to : door panel removal. It states the colors for the individual speakers. The post is accurate, just did mine on Monday.
2006 Xtreme CC
Kenwood Excelon DNX-9140 w/iTouch
Pioneer Premier 6 1/2s in doors, Pioneer tweeters
De-Badged and Belltech 1.5"/2" Drop
If you like it Stock, you're easily amused!
Grounded 355Member #13
TOTW 2007-10
Wrayzor is offline
post #4 of 8 (permalink) Old 12-20-2005, 05:58 PM
A8 GY 118 Left Front Speaker Output (-)
A9 TN 201 Left Front Speaker Output (+)
A10 D-BU 46 Right Rear Speaker Output (+)
A11 L-BU 115 Right Rear Speaker Output (-)
B8 YE 116 Left Rear Speaker Output (-)
B9 BN 199 Left Rear Speaker Output (+)
B10 L-GN 200 Right Front Speaker Output (+)
B11 D-GN 117 Right Front Speaker Output (-)
like this?
FOR SALE - SS Gen II bumper cover - PM me
iceberg0425 is offline
post #5 of 8 (permalink) Old 12-21-2005, 04:17 AM
CALI-BOSS
DBNissan's Avatar
Audio/Mobile Video
Battery ORANGE (+) RADIO HARNESS
Accesory THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON IS CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
Ground BLACK/WHITE (-) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
This is from Audiovox TechServices.
DBNissan is offline
post #6 of 8 (permalink) Old 12-21-2005, 03:38 PM Thread Starter
Thats what I needed. Thanks guys...
Dan
post #7 of 8 (permalink) Old 12-21-2005, 05:52 PM
has anyone else had this problem? My rear right and rear left speaker wires were both the same color scheme.
post #8 of 8 (permalink) Old 12-24-2005, 04:01 PM
Syd
They were identical on mine -- yellow - /some sort of brown +
The walkthrough from Crutchfield is very accurate. You don't even need a Torx driver either, you can pull the panel away just enough so that you can get to the speaker and mount quite easily. Hardest part was just pulling the stock speaker away from the cradle.
'07 Mazdaspeed 3 Sport
(formerly '04 Colorado)
Syd is offline
