Door Ajar warning - Chevy Colorado & GMC Canyon
post #1 of 16 (permalink) Old 10-17-2006, 01:30 AM Thread Starter
Door Ajar warning
now it wont go out....any suggestions or ideas why its doing this? and im pretty sure its isolated to my driver side door
Gun Toting American Club Member #5
2007 TOTW Winner Week #21
LongBow986 is offline
post #2 of 16 (permalink) Old 10-17-2006, 01:38 AM
Canyon08Z71's Avatar
Check the door indicator switch. Push button thingy that tells the BCM when it is open or closed (black rubber thing). <--- very technical
Canyon08Z71 is offline
post #3 of 16 (permalink) Old 10-17-2006, 03:07 AM Thread Starter
i have a feeling you said something very simple, yet somehow it went over my head...i'll let it sink in :P
post #4 of 16 (permalink) Old 10-17-2006, 05:01 AM
Theres a little rubber black button in the door jam.
You cant miss it. Just push it and see if the indicator goes away. If not then the switch might be bad.
If it goes away your not closing your door good or the door isn't pushing the switch when its closed.
Dillusion is offline
post #5 of 16 (permalink) Old 10-17-2006, 02:03 PM Thread Starter
i'll give it some tests later today, since today it seems to be working properly lol
post #6 of 16 (permalink) Old 10-17-2006, 02:07 PM
I know that on my truck you really need to slam the doors or our thick as sh$t door seals won't allow it to close all the way and the door ajar light comes on.
rangerbob is offline
post #7 of 16 (permalink) Old 10-17-2006, 03:32 PM
Yeah, yeah, yeah. I am with this guy. ^
post #8 of 16 (permalink) Old 10-18-2006, 09:57 PM
My passenger side door is a pain to shut. Most people have to shut it twice. It's mainly due to vacuum pressure I guess, if I roll down a window it'll shut easy. Most Chevy's do that it seems, got the same problem with the Trailblazer occasionally, and on my buddy's 91 GMC K2500.
Ranger is offline
post #9 of 16 (permalink) Old 10-18-2006, 10:11 PM
You ever look to see if the vents on the back of the cab are opening and letting the pressure out?
I know its prolly not it but just a suggestion.
post #10 of 16 (permalink) Old 10-20-2006, 02:33 PM Thread Starter
taking my truck to the collision center after class this afternoon, they had a new switch handy and told me to get the door adjusted, im gonna ask the tech over at the col. center if i can watch since he said it wouldnt take too long :D
post #11 of 16 (permalink) Old 10-20-2006, 03:00 PM
I know my vents work. The seals are just awesome and that makes it hard to shut.
post #12 of 16 (permalink) Old 04-05-2007, 02:31 PM
Send a message via MSN to praetorian2851 Send a message via Yahoo to praetorian2851
mine just started intermittantly doing this. Driving over bumpy road it will flicker on and off. Wiggled the drivers door switch prior to closing and that seems to correct the issue until a bump or next time I close the door. Guess I need to purchase a new one.
2005 Z85 Colorado 2wd crew cab
praetorian2851 is offline
post #13 of 16 (permalink) Old 04-13-2007, 01:48 PM
I had this problem awhile back. Isolated it to the back drivers side door of my crew cab. I ended up taking a piece of the rubber insulation left over from installing the tonneau cover and sticking it on to the door at the spot that the rubber sensor contacts when the door is shut. This just ensures that the rubber door closed sensor get pushed completely in. Haven't had a problem since.
2004 Canyon 4x4 Crew Cab Black
hskrvet is offline
post #14 of 16 (permalink) Old 04-15-2007, 12:17 PM
I have also isolated to that door, how thick was the rubber peice that you put in there?
post #15 of 16 (permalink) Old 05-14-2007, 01:45 PM
I have put so much material on the door and it went away for awhile but is back, added more but still comes and goes. Next I am just going to soldier the switch to the closed position.
post #16 of 16 (permalink) Old 05-14-2007, 11:45 PM
Door switches are a common failing part. I replace many on microwaves and laundry products. Even with a continuity meter they may show good, but the actual contact throw inside switch has changed causing the switch to become intermittant before failing. I would recommend replacing switch.
2006 Canyon crew cab true red
I-5 Z-71 4wd auto
factory side tubes,splash guards and tailgate cap. after market brush guard, Hellwig 550's
2003 Tracker Pro-Guide Deep V-16
40 hp4st. Mercury.
2009 KLX250s Sunbeam Red
http://s207.photobucket.com/albums/bb205/randylo/
Randy is offline
