Make low beams stay on with high beams. - Page 2 - Chevy Colorado & GMC Canyon
post #21 of 26 (permalink) Old 04-25-2007, 03:05 AM
Send a message via MSN to bigredz71
lisening
_______________________________
GM Parts Soft Tonneau Cover
Westin Bull Bar
Westin Tube Steps
Euro Headlights and Fog Light Bulbs
Rockford 10" P3 Sub
PG 400watt amp
2" shackle and TB lift
CARR Light Bar Deluxe
6- 6" Eagle Eye Lights
31x11.50x15 Tera Trac
MUD CLUB #18
bigredz71 is offline
post #22 of 26 (permalink) Old 04-25-2007, 01:12 PM
Originally Posted by Danny45
Originally Posted by Cobra4B
Hmmm... I might just do the jumper mod so that when the highs are on the 4 lights are on, but then when the lows are on I have normal function.
I would check that mod again. I seemed to remember that it only affected the high beams and low beams, not the fog lights.
I could be wrong though.
You are correct. The relay mod does not affect the function of the fog lights. The only thing that changes is your low beams will stay on with the high beams. The fog lights will NOT come on with the high beams. The fog lights will come on with the low beams only.
06 CC ZQ8
Dropped 1.5/2
Stocker2 HP tuned
Jet Servo
Concept CD-810 Class D Amp
10" Kicker Solobaric L7
Infinity Reference 7541a Amp
Infinity KAPPA 60.7cs components
18" Titan Wheels
245/45 Michelin Pilot Sports
JustinS is offline
post #23 of 26 (permalink) Old 07-24-2007, 01:16 AM
so where is the relay located?
Brisco007 is offline
post #24 of 26 (permalink) Old 07-24-2007, 03:16 AM
#47 (beam select). There are 3 relays on the edge closest to the cab of the truck. The beam select relay and two square relays.
The jumper is soldered between the top of the frame and the 87a contact.
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does an oil change. It's a pity the ECU is so damn temperamental. -- Author Unknown
Sarge is offline
post #25 of 26 (permalink) Old 11-19-2007, 02:04 PM
Just did it, thanks Sarge! Worked like a charm
06 Xtreme EC | Tint | Walker exhaust | AEM intake | -1 rear drop | ICE | 8000K HID's
02 VW GTI turbo | Brullen downpipe | supersprint | EVOMS CAI | 007 DV | Upsolute 94 ECU | Short shift | 2" drop | 19" Privat
00 GSXR750 | Hindle Race system | Telefonica Replica | K&N intake | Race ECU
Aleks is offline
post #26 of 26 (permalink) Old 11-26-2007, 03:32 PM
Glad it worked for you. I've been running mine for over 2 years now. No blown fuses, melted wires, melted relays, or unusually often blowing headlight bulbs
Sarge is offline
