Make low beams stay on with high beams. - Chevy Colorado & GMC Canyon
post #1 of 26 (permalink) Old 01-21-2007, 03:53 PM Thread Starter
Haven't seen any threads about this so I thought I would throw in my two cents. Some years ago, GM engineers decided to wire Chevy pickups so when the driver turned on the high beams, the low beams go off. This doesn't make sense to me so I came up with a fix.
I started by calling Painless wiring. I asked if they made anything for the Colly with 4 headlights that would make the low beams stay on with the high beams. The tech rep talked to his engineers and was told that the kit for late model Silverados would work.
So I bought the kit (high beam relay) from Jegs, installed it and it didn't work. The low beams still turned off when the highs came on. I called Painless back; I told the tech rep what happened and got him to email a wiring schematic for the front headlights on the 05 Colorado.
After looking at the schematic, I came up with a fix. All four headlights have power to them all the time. A relay controls the ground circuits. When the lows are on, the ground is taken away from the high beams and vice versa.
I didn't post pictures because the fix is simple.
Remove the grille and unbolt the headlight assemblies. The headlights use two 10mm bolts.
Remove the wiring harnesses from the back of the headlights and set them out of the way.
Do one side a a time.
Take the harness for the low beam and unwrap the factory electrical tape so you can see the two wires. On my 05 Colorado Z71, the "hot" wire is "orange" and the "ground" wire is "dark blue".
Splice into the dark blue wire using a Quick connector and 12 - 18 inches of wire (use 18 ga or heavier wire).
Attach the other end of the wire to a good ground, (I drilled a small hole in the sheet metal behaind where the headlight assembly mounts).
I used an electrical connector, sheet metal screw, and two star washers.
The hardware store calls them "shakeproof" washers. They keep the screw tight and help make a good ground.
Wrap some new tape around the wires where they come out of the plastic loom.
Add a ground wire to the other low beam harness in the same way.
Reinstall the headlights, don't forget to plug the harnesses in (I did this, LOL).
Reinstall the grille and you are done!
Now the low beams will stay on when the high beams are turned on. It makes a big difference when driving backroads in deer country.
I also replaced the headlight bulbs with Silverstars. I get flashed alot at night because other drivers think my high beams are on. Then I turn on the high beams and give em all four lights. (I know, I know, but it's fun).
post #2 of 26 (permalink) Old 01-21-2007, 03:57 PM
Global Moderator
Danny45's Avatar
Uh, if you'll look in the Aftermarket Accessories section, you'll see a couple of threads about MrTaillights.com that has had a kit out for some time. Several of us have done the mod, it only takes a few minutes to do, and it's pretty cheap.
See this thread.
http://coloradofans.com/viewtopic.php?t=21184
Danny
10,000 Posts Club Member #1
Conservative Club Member #2
Danny45 is offline
post #3 of 26 (permalink) Old 01-21-2007, 03:59 PM
Send a message via AIM to Rsquires67
See this thread.
x2
VOTE for me please in TOTY!!!! viewtopic.php?f=24&t=67915
Rsquires67 is offline
post #4 of 26 (permalink) Old 01-21-2007, 04:48 PM
Send a message via AIM to sillyoldtayo
See this thread.
x2
x3 ya before i do anything, i always check the forum
TOTW #25...SWEEEEETRUCK!
sillyoldtayo is offline
post #5 of 26 (permalink) Old 01-21-2007, 06:27 PM Thread Starter
See this thread.
x2
x3 ya before i do anything, i always check the forum[/quote
Uh, like I said, I HADN't SEEN anything before on this subject. If I always checked the forum/quote before I did any mods to my Colly, I'd never have time to do a mod.
post #6 of 26 (permalink) Old 01-21-2007, 07:24 PM
Of course then again, if you spent 5 minutes on a search to check the forum you'd probably spend half the time completing certain mods.
04 Colorado ZQ8 I5/AT
If you can't afford to do it right, then how can you afford to do it twice?
brakenit is offline
post #7 of 26 (permalink) Old 01-21-2007, 07:29 PM Thread Starter
Nah, cause after looking at all the mods, I would be at the bank applying for a loan. :D :D
post #8 of 26 (permalink) Old 01-21-2007, 07:38 PM
I know the feeling. It's tough to decide which direction to go with things after looking at some of the trucks on this site.
edit: Why go to the bank? YOU LIVE IN FORT KNOX!
brakenit is offline
post #9 of 26 (permalink) Old 01-22-2007, 11:09 AM
Even easier is to simply modify the ground relay in your fuse box. Take the lid off the beam selector relay and solder a jumper between the master and the low-beam pin, so that even when the high-beams are selected there is still a ground to the low-beams. Took about 5 minutes, was a totally free mod, and didnt have to modify any of my factory wiring.
burn is offline
post #10 of 26 (permalink) Old 01-22-2007, 12:19 PM
x2
Same concept what I did, only instead of running the wire out of the case, I just soldered a jumper between the frame and the pin. Since pictures are worth a thousand words, it's in my gallery. :D
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does an oil change. It's a pity the ECU is so damn temperamental. -- Author Unknown
Sarge is offline
post #11 of 26 (permalink) Old 01-25-2007, 09:24 AM
Originally Posted by Sarge
x2
Thanks for the pic; for those of us that don't quite see the light (!) with wiring, your pic IS worth a 1000 words!
mark
ps I found the relay, but I'm not sure which pin to join to the frame. What about just taping up the solenoid? Or is it taping open the solenoid??
'08 4x4 regular cab, I-4, 5-speed (sold, but sort-of missed); '08 4x4 reg cab Silverado 1500
gtimark is offline
post #12 of 26 (permalink) Old 04-19-2007, 11:04 AM
Send a message via AIM to Cobra4B
So if I just modify the relay... will my lows and fogs stay on?
2004 GMC Canyon - DD/toy hauler
2001 Quicksilver Z06 - NASA TTA racecar
2003 Torch Red/Tan Corvette Convertible
Cobra4B is offline
post #13 of 26 (permalink) Old 04-19-2007, 01:34 PM
When your highs are on your fogs are off, but the fogs will still work when just your lows are on.
06 CC ZQ8
Dropped 1.5/2
Stocker2 HP tuned
Jet Servo
Concept CD-810 Class D Amp
10" Kicker Solobaric L7
Infinity Reference 7541a Amp
Infinity KAPPA 60.7cs components
18" Titan Wheels
245/45 Michelin Pilot Sports
JustinS is offline
post #14 of 26 (permalink) Old 04-19-2007, 02:47 PM
Hmmm I want all 6 on how do I do that?
Cobra4B is offline
post #15 of 26 (permalink) Old 04-19-2007, 03:00 PM
Wire your fogs with a separate circuit. The switch on your dash controls your BCM, then the BCM controls the relay for your fogs. I haven't figured a way around it with out just putting them on another circuit, but it can be done.
06 CC ZQ8
Dropped 1.5/2
Stocker2 HP tuned
Jet Servo
18" Titan Wheels
JustinS is offline
post #16 of 26 (permalink) Old 04-19-2007, 03:08 PM
Global Moderator
Danny45's Avatar
The kit includes the relay that will allow the fogs to work with the highs and lows. But, you need a switch from them to turn them off if you don't want them on all the time your lights are on.
Danny
Danny45 is offline
post #17 of 26 (permalink) Old 04-19-2007, 05:49 PM
If my highs are on... I want all 6 on... if my highs are off I want all 4 on and to retain OEM function.
Will the Mr. Tailights kit do that for me?
Cobra4B is offline
post #18 of 26 (permalink) Old 04-19-2007, 11:36 PM
Global Moderator
Danny45's Avatar
You will not retain OEM function without the extra switch from Mr. Taillights. The fogs will be on anytime your lights are on without the switch. You will not be able to shut the fogs off without it.
Danny
Danny45 is offline
post #19 of 26 (permalink) Old 04-20-2007, 10:54 AM
Hmmm... I might just do the jumper mod so that when the highs are on the 4 lights are on, but then when the lows are on I have normal function.
Cobra4B is offline
post #20 of 26 (permalink) Old 04-20-2007, 01:04 PM
Global Moderator
Danny45's Avatar
I would check that mod again. I seemed to remember that it only affected the high beams and low beams, not the fog lights.
I could be wrong though.
Danny
Danny45 is offline
