interior heater problems - Chevy Colorado & GMC Canyon
post #1 of 4 (permalink) Old 01-28-2007, 05:46 PM Thread Starter
turned my 2005 canyon on today no heat
the fan doesn t make a sound tried checking fuse took fuse out and xcanged with a different one still nothing really need this heater going almost 30 below here im freezing
where do i start to look
cbjr61 is offline
post #2 of 4 (permalink) Old 01-29-2007, 12:10 AM
drp
four wire plug under glove box. give it a wiggle.
Black 05 Crew Cab
Tubular Steps
Trifold Soft Tonneau
Beige 04 F-350 Crew Cab Lariet
4x4 6.0 diesel
drp is offline
post #3 of 4 (permalink) Old 01-29-2007, 12:37 AM
Does the blower motor not work on any speeds at all? Check the number 4 setting, if it works on the highest one but doesn't work on any other its the blower resistor.
IF completely inop in all speeds and you already checked the fuse, try wiggling the connector to the blower motor. If that still don't work you might need a new motor. See the dealer if your still under warranty.
If not let us know, we'll help you out.
turbizzy is offline
post #4 of 4 (permalink) Old 01-29-2007, 03:07 PM Thread Starter
no it didn t work on any speed.. it started to work today when i started it up so it was either frozen or maybe loose connection ill check the connection maybe its loose
thanks for input
cbjr61 is offline
