How to: Remove shifter knob - Chevy Colorado & GMC Canyon
Old 02-25-2007, 04:43 PM   #1 (permalink)
Default How to: Remove shifter knob
This is a how to remove shifter knob. As seen in the pictures my shifter knob is not attached to the boot. Keep in mind yours will. The reason mine is, I sold my console and shifter snap ring that attaches to the console, the buyer did not want the shift lever or knob so I cut the boot and removed the lever. You can still do this with the boot attached.
1. First with a dremel tool with the cut off wheel make one cut down the side and continue to the top and down the other side. Pull with pliers to remove the outer plastic that covers the knob.
2. Then make a cut with the same cut off wheel on the inner harder plastic interior knob.
3. Put a regular screwdriver end into the cut and twist to spread the cut open, once it cracks enough you can pull the knob right off.
4. Knob should pull off and you should have a shaft to insert into a new knob. Keep in mind the end is pretty wide and the new knob might need to be drilled out to fit. Since the new knob will be threaded and your lever is not just drill out the knob and glue it on to the shaft using some epoxy mix you can buy at autozone. Once I buy a knob I will finish this thread,
2006 TOTW Winner #45 l 2007 TOTW Winner #18 l 2008 TOTW Winner #27
Mods Click Here
dlucas is offline   Reply With Quote
Old 07-25-2007, 08:41 PM   #2 (permalink)
Default
lol so you buy a new knob yet haha??
(ps pics arent working for me)
gremblam is offline   Reply With Quote
Old 07-26-2007, 01:36 AM   #3 (permalink)
Default
pics aint working for me either
Gun Toting American Club Member #5
2007 TOTW Winner Week #21
LongBow986 is offline   Reply With Quote
Old 07-30-2007, 12:04 PM   #4 (permalink)
Default
i need to do something asap about my shifter, i dont get how gm could put that pos in there.
got those pics by chance?
Old 07-30-2007, 04:26 PM   #5 (permalink)
Send a message via ICQ to coyote Send a message via AIM to coyote Send a message via Yahoo to coyote
Default
You think this is a POS? You should try the shifter on my 97 Grand Am. The throw is worse than the Rado, it's long and loose.
RIP Spike 9-25-2007
coyote is offline   Reply With Quote
You may not post new threads
You may not post replies
