Rear axle end play/popping/knocking/noise from inside cab - Chevy Colorado & GMC Canyon
post #1 of 8 (permalink) Old 09-10-2007, 08:08 PM Thread Starter
2005 Canyon/2WD/Offroad/26k miles
I can hear knocking coming from the rear-end axle from INSIDE the cab.
It is quite loud.
It occurs while:
Pulling in and out of the drive way.
Driving slow down a dirt road.
'Rocking' the truck while driving 20mph or so on pavement from moving the steering wheel back and forth.
While rear end is jacked up off the ground, the axles have an end-to-end play but not alot. But they do make the same contact noise which is from the brake drum area.
Does anyone else have the same issues?
2005 Canyon Crew, 3.5L, Chrome Hummer H3 wheels and tires, Street Scene grill, K&N breather, Cold air intake, SnugTop bed cover.
tzsv4k is offline
post #2 of 8 (permalink) Old 09-11-2007, 01:39 AM
possible bed mounting bolts. There has been mention of similar noises relating to this. Try search on bed mounts. Welcome aboard!
2006 Canyon crew cab true red
I-5 Z-71 4wd auto
factory side tubes,splash guards and tailgate cap. after market brush guard, Hellwig 550's
2003 Tracker Pro-Guide Deep V-16
40 hp4st. Mercury.
2009 KLX250s Sunbeam Red
http://s207.photobucket.com/albums/bb205/randylo/
Randy is offline
post #3 of 8 (permalink) Old 09-11-2007, 01:46 AM
Is it a high pitched pinging noise? Or like a hammer hitting metal?
Conservative Club Member #35
My Gallery
jlong is offline
post #4 of 8 (permalink) Old 09-12-2007, 03:43 AM Thread Starter
It is a brake drum noise. Like the drums are hitting the backing plate. If this was the case, it would rub while driving I would think. There is a bulletine out on the rear brake drums rubbing - #1556523.
I will try to paste it in here tomorrow.
Seems mine would be rubbing not banging like a hammer.
When rear wheels are jacked off the ground, you can push/pull the wheels in and out and make the same exact noise it makes when in a driving situation.
It's not so much the amount of end to end axle play as it is something contacting the drums.
tzsv4k is offline
post #5 of 8 (permalink) Old 10-09-2014, 11:56 AM
Did you find out where the noise was coming from? I have the same problem. I love the truck but it is annoying.
Fidencio74 is offline
post #6 of 8 (permalink) Old 10-20-2014, 10:48 PM
Similar issue. Anyone?
myevilmonkeys is offline
post #7 of 8 (permalink) Old 12-15-2014, 03:29 PM
Just another "normal" problem with these trucks. "Normal"..
Except we didnt complain with our s10s and 1500s did we?
It has more slack than it should and bottoms out hard and loud. The c-clips shoulde been 1/32-1/16" thicker. I just put on steels with GTs and its so loud when you rock it and you occasionally feel it when driving.
ZQ-8 with Colormatched parts, chrome center grille bar, back blocked an extra inch, on 17x8 std Mclean K/O's.
Stock engine/drive train, stock interior besides audio.
AndrewH is offline
post #8 of 8 (permalink) Old 02-14-2015, 04:29 AM
did you find out about the noise?
