CEL P0449 --RESOLVED-- - Chevy Colorado & GMC Canyon
post #1 of 28 (permalink) Old 10-24-2007, 07:40 PM Thread Starter
So I currently have a CEL and the code is P0449, Evaporative Emission Control System Vent Valve/Solenoid Circuit.
Some background, while I was en route to WI 2 weeks ago my gas cap went bad. I bought one at an auto zone along the way for $12. All seemed well until last week when I got a CEL. I checked the gas cap and it was loose so I tightened it and the light reset itself shortly thereafter. I got another CEL yesterday on the way to work so I checked the gas cap and it was tight. I had Supermodulation clear the light and pull the code with his scanguage. P0449. Today the light is on again and the gas cap is still tight.
So, where is the vent valve? I want to take a quick peek before I take a trip to the dealer on this one (I am still under factory warranty). If it is something simple I will take care of it myself. Also, could the gas cap be the culprit here? If it is then why isn't the code a P0457 for a loose/missing gas cap? Anyway, thanks for the help!
05 SB Orange 4x4 Z71 LS I5 atx 3.73 CC
LIFTED CLUB MEMBER #67
2008 TOTW #9
tjm276 is offline
post #2 of 28 (permalink) Old 10-24-2007, 07:47 PM
orangez71 is online now
post #3 of 28 (permalink) Old 10-24-2007, 09:47 PM Thread Starter
So the "electrical integrity" of my fuel tank vent circuit is at fault. So what does that mean? Could it be as simple as a harness came unplugged or is corroded? Where do I go about looking for this vent/solenoid?
2008 TOTW #9
tjm276 is offline
post #4 of 28 (permalink) Old 10-25-2007, 01:25 AM
Still have warranty, take it to the dealer.
2006 Canyon crew cab true red
I-5 Z-71 4wd auto
factory side tubes,splash guards and tailgate cap. after market brush guard, Hellwig 550's
2003 Tracker Pro-Guide Deep V-16
40 hp4st. Mercury.
2009 KLX250s Sunbeam Red
http://s207.photobucket.com/albums/bb205/randylo/
Randy is offline
post #5 of 28 (permalink) Old 10-25-2007, 03:56 AM
Yea do ya?
Vent Control Valve is the valve that closes amostpheric air from entering the normally open vented charcoal canister for a brief time while the PCM checks the evap pressure sensor to ensure proper vapor pressure exists in the evaporative emissions system. If the vent control valve is sticking mechanically or has an open or short electrically it will tell the PCM and will set a CEL.
However if you take it to the dealer most likely they will notice an aftermarket fuel cap and could deny you warranty work if they find the cause of the CEL is due to an evap leak. However that code is for an electrical issue in the vent control valve itself so technically it doesn't care if the evap system is leaking it just wants the vent valve replaced.
Usually vent valves are bolted to the charcoal canister.
turbizzy is offline
post #6 of 28 (permalink) Old 10-25-2007, 08:11 AM Thread Starter
Yea do ya?
To the dealer I go then. I still have my original fuel cap so I can throw that back on and have the dealer replace that under warranty, too.
2008 TOTW #9
tjm276 is offline
post #7 of 28 (permalink) Old 10-27-2007, 08:51 AM Thread Starter
SO I made an appointment to go to the dealer on Monday so, of course, the CEL cleared itself. WTF!?!?! I will still go to the dealer to have them check everything out/replace the fuel cap.
Anyone have an idea on why the CEL comes on randomly and then turns off after a day or so of use? This is wierd. I am starting to wonder if there is a loose wire or a loose connector plug on a harness somewhere.
2008 TOTW #9
tjm276 is offline
post #8 of 28 (permalink) Old 10-28-2007, 01:57 AM
After the dealer visit it should go away. These systems are picky. I always give my cap extra spins to make sure after reading issues on here.
Keep us posted.
I-5 Z-71 4wd auto
40 hp4st. Mercury.
Randy is offline
post #9 of 28 (permalink) Old 10-30-2007, 10:10 AM Thread Starter
UPDATE:
I dropped the truck at the dealer yesterday morning and they called me yesterday to inform me of the problem. The gas cap is bad, as I suspected, and the vent valve solonoid is bad. It is kind of strange to have 2 failures on the same system of the truck at the same time but I am not complaining. One trip to the dealer is better than 2. Anyway, they didn't have the vent valve soloniod in stock so I had to leave the truck overnight. It should be all fixed up today.
The technition told me that it is not uncommon for the CEL to come on and then turn itself off after a bit of driving and then come on again later. I guess it is how the PCM works.
2008 TOTW #9
tjm276 is offline
post #10 of 28 (permalink) Old 10-30-2007, 07:15 PM Thread Starter
The issue is resolved. The vent valve solenoid was stuck open. The wiring was intact so the vent valve solenoid was replaced. The service adviser told me the vent valve problem could have actually caused the gas cap failure. I don't understand that but I guess I'll take his word for it. Anyway, here is the summary from my paperwork:
Job# 1 Charges--------------------------------------------------------------------
Labor---------------------------------------------------------------------------
J# 1 18CVZZ Engine Emissions Hours 0.5 Tech(s): 58 WARRANTY
Customer states: "Check Engine Light" was on/pulled code for P0449 (Evap Emission Control)/Check and report code P0449 Evap Vent System failure/Pressurize Evap system. Gas cap leaking (Refer to Job #3) System would not hold pressure/replaced cap. (Job#3)/Pressure Evap System/Check for leaks/Vent solenoid stuck open/Replaced vent solenoid/Wiring OK/Checked Vehicle/Operating as designed/Concern Corrected.
Parts-------Qty-------FP-Number-------Description-------List Price-Unit Price-
1 10386359 Hose 3.120 WARRANTY
Total - Parts 0.00
Job# 1 Totals-----------------------------------------------------------------
Job# 1 Journal Prefix CVCS Job# 1 Total 0.00
Job# 2 Charges--------------------------------------------------------------------
J# 2 01CVZZINSP Multi-Point Inspection Hours: 0.00 Tech(s) 58 0.00
Perform Multi-point Inspection
Job# 2 Totals------------------------------------------------------------------
Job# 2 Joiurnal Prefix CVCS Job# 2 Total 0.00
Job# 3 Charges--------------------------------------------------------------------
J# 3+17CVZ Engine Fuel Hours: 0.40 Tech(s): 58 WARRANTY
Add-on line: Replaced Gas Cap
(From Job #1) Gas cap replaced due to internal failure/Would not properly seal/Resulting in Evap leak/Replaced gas cap/Checked over vehicle/No Check Engine Light/Operating as designed
1 15794103 Cap 3.028 WARRANTY
Total - Parts 0.00
Job# 3 Totals------------------------------------------------------------------
Job# 3 Journal Prefix CVCS Job# 3 Total 0.00
2008 TOTW #9
tjm276 is offline
post #11 of 28 (permalink) Old 10-31-2007, 02:19 AM
Nice job. Wow 4/10ths for replacing a gas cap wowzers.
turbizzy is offline
post #12 of 28 (permalink) Old 10-31-2007, 02:24 AM
Am I reading this correctly?
.40 hours to change a gas cap?
Dillusion is offline
post #13 of 28 (permalink) Old 10-31-2007, 02:32 AM
Thats what i was sayin.
Although Kyle, you gotta understand we can't just replace the part, we also need to run a service bay test and ensure the system is working correctly so technically its not just a gascap swap. Its a replace and recheck but daym 4 tenths is quite generous for GM warranty to cover.
turbizzy is offline
post #14 of 28 (permalink) Old 10-31-2007, 08:21 AM Thread Starter
You think they are trying to milk it out to get some more $$$$ from GM for the warranty repair? .4 is 24 minutes which does seem pretty darn high to replace the cap even if it has to get hooked up to a machine or whatever to test the system.
2008 TOTW #9
tjm276 is offline
post #15 of 28 (permalink) Old 10-31-2007, 10:36 AM
We have to pay for our tools somehow. I know that i have at least 20,000 dollars in my box and tools. plus this is just one example. anytime a waranty concern comes in we automatically get .3 to look at it. so if there is a rubbed wire that is shorted under the seat or dash etc. we get 18 minutes to find that. There are times when we can milk it out and get more but every job starts at .3 of an hour no matter how hard. Now for diesel performance diagnostics i can take up to 2.0 hours.
ASE Master Techician, L1 Certified, Chevrolet Tech
GM Diesel Master Certified, GM Brakes Master Certified
2006 Colorado 4cyl 4x4 5spd Standard Cab
Pioneer HU, Polk 6 1/2's in Front Doors
Pioneer 200w Amp pushing Polk 6x9's in boxes
GM color matched, chrome grille
30% Tint on Side windows, Limo on rear
K&N Cold Air Intake
ChevTech06 is offline
post #16 of 28 (permalink) Old 10-31-2007, 03:39 PM
Reasons like this make me glad I can fix my own car.
post #17 of 28 (permalink) Old 11-01-2007, 03:51 PM
Send a message via Yahoo to Lug Nut
if it is a warranty repair then gm makes up the labor time
Lug Nut is offline
post #18 of 28 (permalink) Old 12-16-2007, 10:41 PM
Send a message via AIM to Boomer10
What would you recommend for someone who is having this same issue but who does not have a warranty anymore?
Boomer10 is offline
post #19 of 28 (permalink) Old 12-17-2007, 02:10 AM
SELL IT!
turbizzy is offline
post #20 of 28 (permalink) Old 12-17-2007, 07:50 AM
SELL IT!
Right... umm, please guys, only serious answers.
Boomer10 is offline
