light blinking in 4x4 and 2x4... - Chevy Colorado & GMC Canyon
post #1 of 12 (permalink) Old 01-30-2008, 01:13 AM Thread Starter
Send a message via MSN to Shorty2301
hey guys, was a bit chilly today (-40*C before the wind chill) and i went to change it from 4wd to 2wd and the light just keeps blinking, then click it back to 4wd, and it keeps blinking there too(blinks in either 4 hi or 2 hi, scared to try 4 low with the problem lol). i know it's in 4wd (hops when turning tight, good traction) is this an actual issue or just due to the cold?
oh its an 08' btw.
Thanks guys!
2008 GMC Canyon CC SLE Offroad, 4x4, Tow Package, Sunroof, XM, Onstar
- Elemental Designs 13Ov.2 powered by a NINe.2x
- Elemental Designs UP6's powered by a NINe.2
- Kenwood DNX7100
- Bluetooth kit, Boyo VTL300 reverse camera, ipod video cable
- eDead v1SE^2
Shorty2301 is offline
post #2 of 12 (permalink) Old 01-30-2008, 04:55 AM
Send a message via Yahoo to mike xlb
mine did that on occasion, the transfer case works with the ECU to determine the right driving conditions, what gear the truck is in, if you have traction and all that jazz. My guess is to prevent damage it's forcing the truck to stay in the mode it was last left in due to the extreme cold your in right now.
2008 GMC Canyon 4x4 SLE-1 Z85
2005 Chevy Cobalt SS/SC
mike xlb is offline
post #3 of 12 (permalink) Old 01-30-2008, 09:56 AM
Just creep the truck forward a few inches and try again. It does that because the gears are not aligned.
I have to stirring my manual sometimes to get the transfer case to shift.
rangerbob is offline
post #4 of 12 (permalink) Old 01-30-2008, 01:50 PM Thread Starter
i tried going slow, creeping, going regular speeds, and stopped in neutral. it keeps blinking. we'll see how it is today its warmer now, only -30*C :p
- Kenwood DNX7100
- eDead v1SE^2
post #5 of 12 (permalink) Old 01-30-2008, 04:52 PM
Canyon08Z71's Avatar
Try switching the transfer case to N and then to 2HI.
Canyon08Z71 is offline
post #6 of 12 (permalink) Old 01-30-2008, 10:54 PM
i had this problem too. if the already mentioned ideas don't work, it may be a bent connector down by the 4x4 system. before i bought my 07, it did this on the test drive, and before i agreed to any deal, the dealership took it into service and fixed it up.
kevinz is offline
post #7 of 12 (permalink) Old 01-31-2008, 12:59 AM Thread Starter
was the same again today. maybe ill have a look under neath and look for a potential bent connector. but it started happening after me and my buddy when to the gym. before, it went in and out fine. we came out after it had warmed up (it was -43*C or so) and i went to switch from 2wd to 4 hi and it took longer than normal, about 10 seconds or so. but later when i went to put it in 2wd. it wouldnt move from 4hi to 2. is locked in 4, i know that, but the lights blink no matter what you press. tomorrow i will try putting it in neutral and then 2wd and see what happens.
Thanks guys! if this keeps up, a call to the dealer will be in order.
- Kenwood DNX7100
- eDead v1SE^2
post #8 of 12 (permalink) Old 01-31-2008, 03:15 AM
I would have been there already. 4x4 mode for an extended time can hurt your powertrain if the conditions are normal driving.
mike xlb is offline
post #9 of 12 (permalink) Old 02-01-2008, 02:15 PM Thread Starter
hmm, crawled under and seen that there is a small shaft seal leak on the front diff. i didn't check fluid level, could low fluid be the problem?
- Kenwood DNX7100
- eDead v1SE^2
post #10 of 12 (permalink) Old 02-01-2008, 08:22 PM
dude... get out of Saskatchewan.
Saskatchewan is the problem!!
'04 GMC Canyon Xtra Cab Z71 SL 3.5L I5 4.10
2.0" TB/Shackle lift, 1/2" dif drop, Rancho 5000 shocks
Leer 100XL with bed/storage conversion, Thule racks
justplanecrazy is offline
post #11 of 12 (permalink) Old 02-01-2008, 09:49 PM
Best Response Ever
Weston is offline
post #12 of 12 (permalink) Old 02-02-2008, 12:44 AM Thread Starter
haha! hottest place in canada to buy a home is saskatoon apparently, i have no idea why!
i love it here tho!
- Kenwood DNX7100
- eDead v1SE^2
