Engine Missing - Chevy Colorado & GMC Canyon
post #1 of 8 (permalink) Old 04-20-2008, 12:00 PM Thread Starter
bln
Engine Missing
My 05 recently has been shuddering in 2nd and 3rd around 2000-2500rpm but stops at higher rpms . Yesterday, I was driving on highway about 70 mph and shuddered in 5th. The check engine light came on briefly. The plugs olny have about 5000miles, oil & filter changed last month, and changed fuel filter. I use middle grade gas. I don't think it is fuel pump. Anyone have any ideas. Gotta visit shop I guess
bln is offline
post #2 of 8 (permalink) Old 04-20-2008, 09:59 PM
Send a message via AIM to xkmacx86 Send a message via Yahoo to xkmacx86
Re: Engine Missing
check your vaccum lines, there might be a small leak only exaggeated at those rpm's.
xkmacx86 is offline
post #3 of 8 (permalink) Old 04-21-2008, 09:27 AM
Re: Engine Missing
Don't use higher than 87 octane unless you have a tune. You'll cause a carbon buildup and problems with your engine.
rangerbob is offline
post #4 of 8 (permalink) Old 04-21-2008, 12:02 PM
Send a message via AIM to savannahcoly Send a message via Yahoo to savannahcoly
Re: Engine Missing
Thats not necessarily true. I've used 93 octane for nearly 60k miles and haven't had a single problem. And my plugs didn't show any signs of any problems when I swapped them at 30k miles (even though I need to check them again when I go to Iridium plugs).
180 RWHP 2.8 and still needing to dyno and tune for the custom cams.
Georgia Chapter Co-Founder
savannahcoly is offline
post #5 of 8 (permalink) Old 04-21-2008, 12:27 PM
Re: Engine Missing
The carbon doesn't build up on the plugs. And it is true - plenty of folks here have had this problem when running higher octane. Go do some research about it.
post #6 of 8 (permalink) Old 04-21-2008, 04:42 PM
Re: Engine Missing
I've read about the cons, but I've also read that some people haven't had a carbon buildup problem with the higher octane (even though those that have had problems outnumber those who haven't by a large margin). It can still be cleaned using a high-end fuel system cleaner. I've read articles written by people who don't believe it makes a difference in performance or efficiency (I do know that I went from regularly getting 20 mpg to 22 mpg; can't speak numerically for performance). I know that the vehicle manual also says to use low grade octane (preferably 87 octane). And I know the carbon wouldn't necessarily build up on the plugs themselves (mostly on the back side of the valves), but the plugs wouldn't wear right or leave a good burn pattern either.
I am going to be tuning for the higher octane here within the next month or so anyway. I've got the HPTuners software and finally starting to get the hang of tuning (very slowly and not a master by any means, but coming along nonetheless).
(Off topic rangerbob, but PM me if you're still making wiring harnesses. I have a question or two for you.)
post #7 of 8 (permalink) Old 04-21-2008, 07:50 PM
Canyon08Z71's Avatar
Re: Engine Missing
Get the CEL light code retrieved @ AutoZone for free. Report back.
Canyon08Z71 is offline
post #8 of 8 (permalink) Old 05-05-2008, 06:13 PM
Re: Engine Missing
Not trying to cause panic but you may want to read my post. http://www.coloradofans.com/forums/v...hp?f=8&t=60296
I just posted a thread with similar symptoms of which I called a 'fluttering' or a 'feathered' feeling in the acceleration and major loss of acceleration power. I have an 05 I5 Coly with 100k and have had it to the dealership many times about this problem of which they have replaced several things from a gas cap to a new cylinder head. I thought it was fuel/air related as well. I'm not saying this isn't but it happened again last weekend and at the same time I lost 3rd and 4rth gears. It's at the dealership now and if the 'fluttering' is related (i.e. trans slipping or voltage loss) they better cover the tranny rebuild under warranty!
Your shuddering description sounds all too close to mine. I hope in your case it is not.
-= 05 Z85 LS =-
Debadged, Volant CAI, Flowmaster 50 Series
Redline Hood Lifts, Jet Servo, 17X8 Wheels
Iridium Plugs, Tint, Line-X w/ Tri-Folder
p_ingram3541 is offline
