Dash Rattle. HELP! - Chevy Colorado & GMC Canyon
post #1 of 7 (permalink) Old 05-23-2008, 01:11 PM Thread Starter
Dash Rattle. HELP!
Hey guys - recently my truck has developed a rattle behind the dash on the passenger side. Ive emptied out the glove box so I know its not my junk in there causing it. It sounds like a metal-on-metal sound. I have an aftermarket Sirius unit above the glove box; but Ive checked it twice and its strapped in there good & snug so I know thats not it either. I only hear on roads that have pressure cracks in it; making it hard to reproduce in the driveway. I know its not an exterior sound - its pretty clear that its coming from inside and its really annoying.
Ive had the glove box right out, as well as the patch-panel on the side of the dash but I cant find anything. Does anyone have any guesses to what it could be? All that I see back there is the HVAC, and thats all plastic so I dont think that would make the sound Im hearing.
What would be metal-on-metal on the passenger side behind the dash that could work its way loose? Anyone?
Thanks guys.
burn is offline
post #2 of 7 (permalink) Old 05-23-2008, 02:38 PM
Re: Dash Rattle. HELP!
Put a piece of foam between your dash and the bottom of the side pillar. Basicly right inbetween both where you really cant see.
Thats where mine was.
brewer15650 is offline
post #3 of 7 (permalink) Old 05-23-2008, 02:41 PM
Canyon08Z71's Avatar
Just a suggestion from my 2004 Canyon.
I had a metal sounding squeak in the passenger side a-pillar to dash area... Took a boat load of time to locate it because it was only at highway speeds and when it was cold out... Ended up being a grille mount was loose (the metal push in type) on the passenger side. It resonated all the way into the cab.
Canyon08Z71 is offline
post #4 of 7 (permalink) Old 05-26-2008, 11:25 PM Thread Starter
whelp - I checked those both out and no luck. Its deffinately coming from under / inside the passenger side dash. any idea if the air bag cover comes off?
burn is offline
post #5 of 7 (permalink) Old 05-27-2008, 09:45 AM
Send a message via AIM to *!*Zero*!* Send a message via MSN to *!*Zero*!*
i had the same rattle and i think it comes from the metal latch on the glove box. take ur box off and drive and see if the sound goes away
They call me Zero!!
http://www.starweardesigns.com
http://www.gtac-club.com - a Ontario bassed club for colorado/canyon's
*!*Zero*!* is offline
post #6 of 7 (permalink) Old 05-29-2008, 12:03 AM Thread Starter
WOOO!!!! I think I found it. I took my glove box off again for like the 4th time and low-and-behold there are 2 screws missing behind the dash. I suspect the kind folks at GM forgot to put them back in after they had to remove my dash to replace the trim against the windshield.
burn is offline
post #7 of 7 (permalink) Old 08-24-2008, 03:26 PM
I'm experiencing a similiar very annoying squeak on the driver side underneath the dash somewhere. I only get it when I am not accelerating (pushing gas pedal) usually coasting or braking at 40mph and less.
It seems to do it most when the vehicle is warm. I was thinking it was something in the brake pedal but I've heard it doing it when I wasnt braking. Driving my friggen nuts, any ideas?
Teapotter is offline
