ANTI Theft keeps activating GM Passlock?? - Chevy Colorado & GMC Canyon
post #1 of 28 (permalink) Old 08-17-2008, 05:22 PM Thread Starter
About once or twice a week my POS passlock trips me up and will not let me start my truck, the security light on dash blinks and after about 9 minutes it will come on steady and I can then crank my truck and go about my business. This happens sometimes 2 or 3 times in one day and then it may not do it for a week or so. Any ideas as to what I can do to prevent this from happening, I am not sure what I am doing wrong but everytime it happens, my truck like almost starts and I let go of key too soon. Therefore I try like hell to make sure I hold key all the way until it actually starts, even though it still happens sometimes.
KoloradoDonkey is offline
post #2 of 28 (permalink) Old 08-17-2008, 11:16 PM
Re: ANTI Theft keeps activating GM Passlock??
First step is to search the forum, since there are a ton of topics about passlock.
Next, try cleaning the key up a bit. I read that can help [and its free].
Glamdring70 is offline
post #3 of 28 (permalink) Old 09-02-2008, 10:41 PM
mine was doing the same thing, tokk it to dealer at first , left it for 3 days , they could not reproduce the problem so i picked it up and sure enough 2 days later it did it so my dealer called there tech support which told them to test the passlock sensor, they changed it and it hasent done it since, its been about a month, but considering it was doing it about twice a week , im pretty sure that was the problem
superflae2002 is offline
post #4 of 28 (permalink) Old 09-29-2008, 03:51 PM
Had the same problem with my 2004 colorado. Many trips to dealer, rental car, monitoring device.
Finally diagnosed it myself. It was the passive anti-theft device caused by a faulty ignition switch. This was after an unnecessary fuel injection clean, two separate monitoring devices.... Gm paid to replace ignition switch...even after warranty expired. FYI in the interim....wait exactly 10 seconds before trying to restart.
Colorado777 is offline
post #5 of 28 (permalink) Old 09-29-2008, 08:47 PM Thread Starter
i have to wait like 10 minutes before mine will start
post #6 of 28 (permalink) Old 10-02-2008, 08:02 AM
Send a message via Yahoo to colemanw
it is the ignition key sensor, i had the same problem on my 07... if this many people are having this problem i wonder how reliable the replacement is
colemanw has:
1987 F-150 Reg-cab, short box, 4.9l Inline-Six 4-speed
2007 GMC Canyon SLE 4x4 3.7L
1992 F-250 HD XLT Regular Cab Long Box, Heavy 3/4 Ton 4x4 5.8L 351ci. (Minty Survivor)
colemanw is offline
post #7 of 28 (permalink) Old 10-02-2008, 11:35 AM
I have the same frickin problem!!!!! I have an aftermarket (Clifford) top of the line remote start/alarm system on my truck! When I auto start with my remote and for some reason it don't start (like if I havent driven it for a few days) then it wont even start with the key!!!!!!!!! I have to wait like 10mins, and then it will fire right up! I called the audio dealer that installed it and they said to bring it in so they can look at it. But I'm wondering if that is going to be a waste of time. What do you guys think? Is this the same passlock problems that I'm incountering? It will just sit there and turn over but never start!! So frustrating exspecially when I'm late for work.
2006 Colorado Z71 4x4 I5 Crew Cab; Summit White
Purchaced 06/28/06
20% Tinted Windows
Spray-in Bed Liner
Bug Shield, Sunroof & Rain Gaurds
Aftermarket SS Nerf Bars
Billet Grille
Diamond Plate Tool Box
Clifford Auto Remote Start w/Alarm, 10" Amplified Sub Box
K&N 57 FIPK Series Cold Air Intake
Rancho 5000 Shocks, 2" Bubaloo Shackles & 2" TB Lift
SuperModulation 3/4" Diff Drop Kit
Soon to be installed: BFG 285/75/R16 AT KO's & Moto Metal 951 Rims & Westin SS Brush Gaurd
lilwranglergirl is offline
post #8 of 28 (permalink) Old 10-02-2008, 02:08 PM
Send a message via AIM to savannahcoly Send a message via Yahoo to savannahcoly
I'd take it to the dealer to get a replacement sensor. You should still be under warranty, right?
180 RWHP 2.8 and still needing to dyno and tune for the custom cams.
Georgia Chapter Co-Founder
savannahcoly is offline
post #9 of 28 (permalink) Old 10-02-2008, 02:40 PM
Nope I think it just ended!
Purchaced 06/28/06
20% Tinted Windows
Spray-in Bed Liner
Billet Grille
post #10 of 28 (permalink) Old 10-02-2008, 03:13 PM
You can always call customer service. They might be willing to give you a discount or something. It wouldn't hurt.
post #11 of 28 (permalink) Old 10-02-2008, 08:56 PM
lilwranglergirl, it is not the aftermarket equipment causing you to wait 10 min... there is a key code sensor in your steering column, being that you have an 06 i would suspect that it is covered under warranty. take it to the dealer.
colemanw has:
colemanw is offline
post #12 of 28 (permalink) Old 10-06-2008, 04:59 PM
Okay then why does it do it only when I use my aftermarket remote? Any it never does it when I use my key, I have NO problems then, none what so ever!!!
Purchaced 06/28/06
20% Tinted Windows
Spray-in Bed Liner
Billet Grille
post #13 of 28 (permalink) Old 10-06-2008, 10:02 PM
lilwranglergirl, odd, are you saying that when the security system is activated, you can still use the truck using only your key?
colemanw has:
colemanw is offline
post #14 of 28 (permalink) Old 10-07-2008, 10:36 AM
NOPE! When I use my remote to start the truck, and it doesn't start, then the key wont work to start it. But when I use the remote to dissarm the alarm/unlock the doors and use the key it works everytime. It has nothing to do with the secuity system, just the remote starting system. Its not the stock security system anymore. I hope that makes a little sense? BTW my key doesnt have a chip in it!
Purchaced 06/28/06
20% Tinted Windows
Spray-in Bed Liner
Billet Grille
post #15 of 28 (permalink) Old 10-07-2008, 12:26 PM
CopperRedCanyon's Avatar
lilwranglergirl, it could be the passlock system in your case, but I think you have a problem with your passlock bypass module for your alarm system. Do you ever have problems when you use the key only and have not tried to remote start the truck? If you don't have problems with the key then the passlock bypass module is not telling the BCM that the key is there (basically it lies to the truck when it is working) so the truck doesn't start, it just turns over. Then, the BCM thinks the truck is being stolen so it shuts down the flow to the engine for 10 minutes.
CopperRedCanyon is offline
post #16 of 28 (permalink) Old 10-07-2008, 12:31 PM
I had this problem on my first 06 Colorado and the dealer replaced the ignition switch. I thought it was fixed at first but about a month later it started doing it again. The only reason they fixed it the first time is because I happened to be driving the truck and the passlock light came on so I went straight to the dealer and told I can't shut the truck off because the light would go off and I need them to get someone to look at it now. So a tech came up and looked at it and he shut the truck until he could take it in the shop to fix it. When he came to get the truck it would not start so he had to push it into the garage.
post #17 of 28 (permalink) Old 10-07-2008, 01:13 PM
This sounds exactly right!! I dont have problems with just the key. So do I take it to the alarm shop that installed the remote start or the GM dealer? I remember they had to install a special passlock bypass thingy for new Colly's to get this system to work. They didnt have to do this for my husbands 2000 Silverado. Thanks so much!
Purchaced 06/28/06
20% Tinted Windows
Spray-in Bed Liner
Billet Grille
post #18 of 28 (permalink) Old 10-07-2008, 02:28 PM
Actually the Silverado should have it too, but a different module. And yes I would take it back to the place you got it from and get them to change the bypass module. If they don't do it for free you could find the module on ebay for cheap.
post #19 of 28 (permalink) Old 10-07-2008, 03:23 PM
Got it thanks sooooo much collyondubs for the info on my colly issue!
Purchaced 06/28/06
20% Tinted Windows
Spray-in Bed Liner
Billet Grille
post #20 of 28 (permalink) Old 10-07-2008, 05:35 PM
No problem.
