Spark plug Problems - Chevy Colorado & GMC Canyon
post #1 of 17 (permalink) Old 08-22-2008, 04:14 PM Thread Starter
Spark plug Problems
can anyone tell me where the spark plug is located on a colorado??
is it on the left or right side and how far down is it?
thadbilliot is offline
post #2 of 17 (permalink) Old 08-22-2008, 04:24 PM
Re: Spark plug Problems
They're on the top ( It's an Inline engine not a V ) and they are under the big black box on the top that says Vortec (2700/2900/3500/3700).
rangerbob is offline
post #3 of 17 (permalink) Old 08-22-2008, 04:26 PM Thread Starter
alright dude thanks.. would you know how much to gap them?
post #4 of 17 (permalink) Old 08-22-2008, 04:29 PM
Buy the AC Delco iridiums - they are pre-gapped. DO NOT try and gap iridium plugs - you'll screw them up.
post #5 of 17 (permalink) Old 08-22-2008, 04:56 PM Thread Starter
i dont have the pre gapped so do you know how much i need to gap them?
post #6 of 17 (permalink) Old 08-22-2008, 10:58 PM
Your truck should have come from the factory with iridium plugs. If you are going to replace the plugs, get new iridiums (AC Delco, NGK, Denso).
They are pregapped, don't mess with them.
post #7 of 17 (permalink) Old 08-23-2008, 12:44 AM
naskie18's Avatar
What the gap should be depends on the plug......but as others have said, the iridiums should come pregapped regardless of manufacturer, and if you didn't buy iridiums, take them back and get iridiums.
Question: If you haven't pulled the spark plugs, how do you know you have a spark plug problem?
naskie18 is offline
post #8 of 17 (permalink) Old 08-23-2008, 05:43 AM
If you have to gap your plugs chances are your puttin in cheap copper plugs or somethin. Get Iridiums or Platinums and be done with it.
Gap is .042 - .044"
turbizzy is offline
post #9 of 17 (permalink) Old 08-25-2008, 12:05 AM Thread Starter
well i changed my spark plug out and thats not the problem.. i know its not the coil cause that was changed out too so i wonder what else it could be??
if anyone knows let me know
post #10 of 17 (permalink) Old 08-25-2008, 02:52 AM
Well that the feezy are your symptoms? Did i miss that somewhere or what? All you asked for was spark plug info.
turbizzy is offline
post #11 of 17 (permalink) Old 08-25-2008, 09:50 AM
hey guys question.. what will the new iridium's actually do? what gain will I get from them?
2005 Z85 3.5L
AEM Brute Force CAI
2" TB / AAL
33x10.5 BFG A/T
4x4 Dk. Green
Rhino Lining
chris3788 is offline
post #12 of 17 (permalink) Old 08-25-2008, 10:16 AM
Clean ignition. Better lifespan.
post #13 of 17 (permalink) Old 08-25-2008, 11:01 PM
Greaaat! I pulled mine 6K back and did just that to them. I had no idea that you are not supposed to do that to the factory iridiums.
I will be the one to ask the question. What happens if I slightly re-gapped them? A few were actually a slightly out of spec.
2004 Sunburst Orange Colorado .--. Extended Cab .--. I5 3.5L .--. Automatic .--. 2WD
Macronyx is offline
post #14 of 17 (permalink) Old 08-25-2008, 11:20 PM
Don't worry too much, i know some mechanics who do this. Technically platinums and iridiums are not supposed to be gapped because they are made or coated with that stuff which can be damaged by the gapping tool as it slides through it but if your careful enough your prob ok.
turbizzy is offline
post #15 of 17 (permalink) Old 08-25-2008, 11:23 PM
Cool. Thanks for reassuring me.
I am planning on redoing them near 70 or so for the hell of it. I did that on my S10 just for a piece of mind.
Macronyx is offline
post #16 of 17 (permalink) Old 08-25-2008, 11:36 PM
Well i prob wouldn't regap them after that many miles cuz then the coating might be close to wearing off.
turbizzy is offline
post #17 of 17 (permalink) Old 08-25-2008, 11:43 PM
I meant I would replace them at 70. Sorry for the misunderstanding. I just hit 50 so I have a while to go.
Macronyx is offline
