Front Brake Rotor Removal - Chevy Colorado & GMC Canyon
post #1 of 79 (permalink) Old 10-23-2008, 12:32 PM Thread Starter
Send a message via AIM to HRspiller219 Send a message via Yahoo to HRspiller219
I just replaced my front brake rotors on my 2006 Colorado Z71 2WD I5 to Powerslot rotors.
And i searched on here for a GOOD write up.. and didn't find one. so i figured i would try to help.
OH... DO NOT! USE A SLIDE HAMMER.. IT CAN DAMAGE THE BEARINGS!
Tools Required:
Lug Removal Tool
Impact Gun (Recommended)
Sockets.. Lots of metric sockets
Ratchets
Wrenches
Porta Power (hydraulic piston) --- THIS IS REALLY IMPORTANT... use to press hub off..
LOTS OF PATIENCE
Instructions:
1) Jack vehicle and support on jack stands.
2) Remove front tire.
3) Remove Front Brake caliper.. hang on frame using a bungee or other support
Important to not stress hose.
4) Remove brake pad support.
5) Remove 4 bolts from rear of hub.
6) Undo bolt for ABS sensor from frame, undo all clips holding wire.
Crawl under truck and unclip wire connector (trace wire from the ABS sensor to find it)
7) Make sure wire is unclipped from the frame and will not bind on removal of hub. (Prevents Damage of ABS sensor)
TRICKY PART: Turn the wheels so that you can use the hydraulic porta-power against where the lower control arm mounts to the front. (Turn the
wheel left). Position porta-power to be placed inside dimple of the middle of the hub. DO NOT DAMAGE ABS SENSOR...
Pump Porta-power until hub "Pops".. be extremely careful removing the hub not to damage the ABS wire at all.. It is easy to break and not notice (I did
this and had to resplice it)
9) Hub should be removed from vehicle by this point and you can remove the six bolts holding the old rotor on. Still be careful not to damage the sensor.
10) Change the rotor. (do not use impact gun to reattach.. may strip threads)
11) Installation is basically reverse of removal.
12) Install brake pads, press caliper back in (typical brake job)
13) Put tire back on.. do other side.. and you're done.
Porta Power is this.... http://www.southern-tool.com/store/porta_power_kit.html
any questions... message me.
<Nick>
HRspiller219 is offline
post #2 of 79 (permalink) Old 10-23-2008, 05:19 PM
Re: Front Brake Rotor Removal
The "official how to" is in here
viewtopic.php?f=8&t=42147
Glamdring70 is offline
post #3 of 79 (permalink) Old 06-16-2009, 08:47 AM
Another approach:
Instead of using a porta Power, we used the hydraulic steering force to pop the hub off. Remove the bolts from the bearing housing, loosen the axel nut and then wedge an extension/socket/whatever between the rotor and the shock mount (or whatever you can). Then turn the wheel with the engine running. The hob popped right off.
Chris
ubaldc is offline
post #4 of 79 (permalink) Old 06-17-2009, 08:20 PM
Send a message via AIM to con8quest6
anyone get any pics of the procedure?
con8quest6 is offline
post #5 of 79 (permalink) Old 06-18-2009, 09:21 AM
Originally Posted by ubaldc
Another approach:
Chris
That is an interesting approach. I wonder if there is any harm done by removing the rotor this way (granted you have someone to catch it so it does not fall on the ground and damage the speed sensor)?!
2004 Sunburst Orange Colorado .--. Extended Cab .--. I5 3.5L .--. Automatic .--. 2WD
Macronyx is offline
post #6 of 79 (permalink) Old 06-27-2009, 11:55 AM
If you had to use a hydrualic ram to push the hub out how are you getting it back in?
"The price of Freedom is eternal Vigilance"
- Thomas Jefferson -
nolan62 is offline
post #7 of 79 (permalink) Old 06-27-2009, 09:41 PM
It comes out hard becuase of the buildup of rust/dirt. Once it's out and cleaned up you can put it back in by hand.
post #8 of 79 (permalink) Old 06-27-2009, 10:04 PM
fbody4life's Avatar
I found it easier to take the four bolts holding the hub on almost completely off then putting a small 2x4 on it and hitting the bolts all the way around. It loosens the hub enough to take off by hand. And the hub will only go as far as the bolt so no damaged parts unless you miss the 2x4 and hit your sensor.
04' Crew Cab 4WD Z71
Lifted member #264
4" Skyjacker lift, 2" Shackles, 16x8 Pro Comp 8128, Toyo open country M/T 285/75R16
K&N CAI, Gutted pre-cat, MBRP exhaust, PCM4less tune
Kenwood DNX5120, Subthump box, Solobaric 8L7, Kicker amp, Infinity Kappa door speakers
SSK Crossmember Caps, Auto shifter
SuperSkidz front skid plate
fbody4life is offline
post #9 of 79 (permalink) Old 06-27-2009, 10:07 PM
Thank you!
I can do this now. I wish I had kept track of all the money I have saved on doing repairs myself thanks to the guys on this site. I has to be in the thousands!
Ed
nolan62 is offline
post #10 of 79 (permalink) Old 07-07-2009, 07:54 PM
does any know how to remove and install the abs sensor from the hub bearing assembly? if not, how about finding one that comes already complete cause i cant find em' ..... thanks btw this website ROCKS!!!!!!!!!!!
Z71mOtO-x is offline
post #11 of 79 (permalink) Old 07-07-2009, 08:15 PM
A good investment is to buy the service manual in addition to using the site for "tech support"
wpage505 is offline
post #12 of 79 (permalink) Old 07-07-2009, 11:47 PM
With all the recent discussion about the ABS sensor and hub setup, I did some research on replacing it. Not much too it really. But why remove the old one if you don't have a replacement?
post #13 of 79 (permalink) Old 07-08-2009, 12:00 AM
I am glad i found this, i need to do my brakes ASAP.
Canyon & Colorado Club Of Canada Memeber #12
Lifted Member #248
Access Vanish Tonneau Cover
Billit grille, chrome altezza tail lights.
15 X 8 Core Racing Explorer
2" T Bar crank, 1.5" shackles
Pioneer AVH-P4100DVD
JL 250/1 Pioneer TS-SW1041D (10" shallow)
Waiting to install:
Pioneer TS-A702C (front). TS-D170R (rear)
Pioneer GM-6000F (50 X 4 RMS)
white06Z71 is offline
post #14 of 79 (permalink) Old 07-12-2009, 02:07 PM
Guest
Posts: n/a
i did this recently on my 05 Z71 and decided one thing....if i even have to do this again i'm going to burn the truck to the ground and whiz on the ashes...
post #15 of 79 (permalink) Old 07-12-2009, 04:01 PM
I don't understand why you all feel the need to replace your rotors at every brake job. If they're not grooved or scored then just pad slap it. If you want a new rough surface with new pads then have a brake shop or your dealer resurface the rotors with the oncar brake lathe.
turbizzy is offline
post #16 of 79 (permalink) Old 07-12-2009, 11:25 PM
not being smarty pants,40 years at it and NEVER WAS GOOD IDEA TO TURN A ROTOR.its not going to work.put new ones on,IF NECESSARY.if rotors look ok, i agree just put pads on.
there was shadetree mechanic show on years ago on tv.they always replaced the rotors on brake job.
usually my rotors go before my pads do.
sproulman is offline
post #17 of 79 (permalink) Old 07-13-2009, 12:06 AM
If a rotor isn't scored or damaged in anyway, there is nothing wrong with taking off a couple of thousands of an inch and reusing it. Hell, Ive taken rotors that were in good shape and scuffed them up with 80 grit sandpaper and installed new pads.
post #18 of 79 (permalink) Old 07-13-2009, 01:05 AM
been there done that.WASTE OF TIME AND WILL WASTE YOUR MONEY,it aint going to work.as for sandpaper,NO PROBLEM.I ALWAYS SANDPAPER A ROTOR THAT IS OK and put new pads on.rotors are just not heavy enough after turning for them to not warp again.china rotors are real dandy ones, turn then onec and see if you dont curse a month from now.
i like WAGNER products too.
post #19 of 79 (permalink) Old 07-13-2009, 04:43 AM
Not to sound like a smarty pants either but im failing to see your explanation of why its a waste of time/money. If you have a shitty old school bench lathe then yes i agree, but now a days we use an oncar brake lathe that you mount to the actual hub with an adapter and the machine auto compensates for hub runout and this is an approved factory method by GM and by Nissan.
In fact, in Nissan school we actually watched a demonstration on a brand new set of OE rotors being put onto an a brand new Altima and had over .100" runout brand new outta the box once placed on the hub. The rotors themselves were true but once placed on the vehicle the car's hub has runout which adds to brake pulsationg. And the car had like 7 miles on it. The approved method for repair is not new rotors, they have us machine the new rotors with an on car brake lathe which machines the rotor with the hub runout and compensates for it so realistically the freshly resurfaced rotors on the on car lathe are TRUER on the car than they were brand new outta the box. Basically you have to match the rotors to your vehicle instead of using a universal method of a bench lathe.
So again, i don't see your point on how its a waste. Please explain how you seem to know more than these billion dollar companies' engineers (no offense). You mention china rotots, well theres your problem. I (GM and Nissan dealer tech) only use and only recommend OEM replacement factory parts because yes, china rotors may warp as stated. But I will say this, some OEM rotors don't like to be resurfaced either, brands like Volvo, VW, Audi, (i've worked at all these dealers before and they strictly replace rotors) seems like most European companies, warp rotors really easy due to their really hard pad material so those i wouldn't suggest replacing. But for the most part, all GM rotors are ok to machine and it even recommends it so in the FACTORY SERVICE MANUAL using the procut oncar lathe.
turbizzy is offline
post #20 of 79 (permalink) Old 07-13-2009, 04:55 AM
Everyone please see this video and you'll see what im talkin about when i say on car brake lathe and how its extremely accurate and far better than the old school traditional style bench lathes which should all be melted for scrap. This machine is the exact one we use at work, the PROCUT is the only approved lathe by all major auto manufacturers and in fact, as i stated earlier, are known to be used on brand new rotors to true them up to the vehicle's built in wheel bearing/hub runout so technically this is even better than a brand new set of rotors.
http://www.youtube.com/watch?v=qAOFErcUMoE
turbizzy is offline
