Check Engine light P0455 - Chevy Colorado & GMC Canyon
Old 10-25-2008, 09:00 PM   #1 (permalink)
Default Check Engine light P0455
Alright, I have looked at the search for this and it does say it can be caused by the fuel cap. However I also checked this issue and replaced the cap because of the same issue, that and it was broken. The fuel cap light only comes on when I have around 3/4 of a tank or less. I am not sure if it is the line itself. Because it would seem funny to have another bad fuel cap after only a month of use.
Any suggestions? Or anyone have to replace the line? Sounds like a pain in the ass. Truck is stock no lift or anything.
2004 Chevrolet Colorado Crew Cab, Green, Z71 4x4 with 3.73 (GT4) G80. Firestone Destination 31x10.5 15
Spectre Air Filter, Optima Yellow Top 34-78, Imperial Tranny Cooler, Pioneer 7700MP HU, Pioneer Component Speakers with Sony Amp.
OffroadJunkie84 is offline   Reply With Quote
Old 10-25-2008, 09:14 PM   #2 (permalink)
Default Re: Check Engine light P0455
Would also think it was the gas cap. Maybe you bought a bad (new) gas cap that does not seal good. Might try another. Do you smell and gas around the truck? Under the truck?
http://www.obd-codes.com/p0455
Steve
jackedupcanyon is offline   Reply With Quote
Old 10-25-2008, 11:28 PM   #3 (permalink)
Odds are that the problem is elsewhere in the evap system.
2005 Z71 LS Crew Cab 4X4 L52, 4L60E, GT4, Silver Birch Metallic MAXX Shackles: http://www.355nation.net/forum/suspe...here-here.html MAXX Cam JR Lift Kit for 4X4 & 2WD Z71: http://www.355nation.net/forum/suspe...ering-kit.html
MAXX Stak Lift Kit for 2WD: http://www.355nation.net/forum/suspe...t-numbers.html PerforMAXX Body Lift: http://www.355nation.net/forum/suspe...y-spacers.html
ssgjurista is offline   Reply With Quote
Old 10-27-2008, 09:13 AM   #4 (permalink)
Well I did notice the green seal for the gascap isn't as... how to put this.... springy? I dunno but it seems flat like my other one had been. Except for the fact it locks where as my other one just spun around. I wonder if I could stretch the seal back to what it was originally. I thought that was the major problem with the old caps?
It's not like I keep screwing in the cap alot after it clicks, I just make sure it clicks then try to pull on it lightly to make sure that it is locked properly.
Old 10-27-2008, 10:51 AM   #5 (permalink)
I've had a gas cap fail on me. Try replacing this first.
rangerbob is offline   Reply With Quote
Old 10-27-2008, 10:06 PM   #6 (permalink)
ditto. gas cap first.
Steve
Old 10-28-2008, 06:22 PM   #7 (permalink)
I cleaned the seal on the gascap and then the filler hole. I just find it BS that I would have to replace a gascap that is only a month and a half old.
Old 10-29-2008, 12:08 AM   #8 (permalink)
When you replaced the gas cap before, did you buy it or did the dealer replace it under the special coverage?
Old 10-30-2008, 02:39 PM   #9 (permalink)
I ended up buying it myself, I realized I was wordy in my email I sent them, because I originally said I had the 0455 code and the gas cap light come on and I did mention the cap was broken. I really didn't feel like fighting it but they were being dumb, the guy was giving me the run around about having to hook it up to their computer. I should have said "hey broken cap, you have to give me a new one" but I wasn't in the mood to argue, probably would have punched the guy... anyways....
I think cleaning the cap seal and the filler neck did the trick, no light came on. Wierd... it's not like it was really dirty just a little water and dirt. But I guess if it doesn't have a perfect seal it would do that, I don't see how it would be a large leak.
I'll keep you guys posted if it comes up again.
Old 12-01-2008, 11:39 AM   #10 (permalink)
I know I'm double posting but... Same problem check engine light following a gas cap indicator. Now... it had been a heavy snow last week and one day I start my truck low and behold the light is gone, was like that for a day or so then it came back. Not sure what this could be a possible leaky hose or bad connection?
You may not post new threads
You may not post replies
