Fan control switch finally quit for good... how-to replace? - Chevy Colorado & GMC Canyon
post #1 of 26 (permalink) Old 11-07-2008, 10:07 AM Thread Starter
Send a message via AIM to Cobra4B
My fan control switch only works on the max #4 setting. For a few months now I could twist it back and forth quickly and it'd start working on all speeds again. Yesterday it quit for good and will only work on setting 4.
Behind the trim is the HVAC unit one complete part? Do I have to replace all of it, or is the fan control switch a seperate part? Anyone know? Anyone have pics of replacement?
Thanks,
Brian
2004 GMC Canyon - DD/toy hauler
2001 Quicksilver Z06 - NASA TTA racecar
2003 Torch Red/Tan Corvette Convertible
Cobra4B is offline
post #2 of 26 (permalink) Old 11-07-2008, 10:12 AM
Re: Fan control switch finally quit for good... how-to replace?
all one unit, $100 from gmpartsdirect.com i'd get you the part # but the online catalog isn't working right for that part you'll have to call them or maybe a parts store might carry them
2008 GMC Canyon SLE Reg Cab
2.9L 5-speed - Red Orange Metallic
Line-x
Z-71 Flares
BakFlip Tonneau
wrightek is offline
post #3 of 26 (permalink) Old 11-07-2008, 10:21 AM
GM Part #: 25841856
post #4 of 26 (permalink) Old 11-07-2008, 10:56 AM Thread Starter
Thanks guys... I assume I have to pop off the plastic radio surroud piece... how do I pop that off w/o marring it? Small screw driver around the edges or are there screws somewhere?
Thanks,
Brian
Cobra4B is offline
post #5 of 26 (permalink) Old 11-07-2008, 12:11 PM
Small screwdriver at one of the bottom corners and then work it off with your hands from bottom to top.
post #6 of 26 (permalink) Old 11-08-2008, 11:12 AM Thread Starter
Ok thanks... so it just pops out.
Cobra4B is offline
post #7 of 26 (permalink) Old 11-08-2008, 11:21 AM
naskie18's Avatar
Yeah, I didn't even use a screw driver to pry mine off, Started at the bottom (above the power outlets) and then worked up the sides.
naskie18 is offline
post #8 of 26 (permalink) Old 11-08-2008, 02:05 PM
Send a message via AIM to gettingspeedy Send a message via MSN to gettingspeedy
i dont think its your switch dude, i had the same problem. rplace your blower motor resistor and wiring harness, then there is a relay under the hood that came loose. mine works fine now
gettingspeedy is offline
post #9 of 26 (permalink) Old 11-08-2008, 03:09 PM
definately try the resistor first. it's cheaper and a known solution to the problem
2004 Colorado LS Ex. Cab Z71
View My Garage
Lifted Club #217 (2" torsion bar/shackle lift)
~Dan
metal_emt is offline
post #10 of 26 (permalink) Old 11-08-2008, 09:24 PM
I just bought the blower resister and will be replacing it tomorrow. I'll keep track of how I do it so that others can follow :p
Sparky87 is offline
post #11 of 26 (permalink) Old 11-09-2008, 12:27 AM Thread Starter
Where is this resistor? Any pics?
Cobra4B is offline
post #12 of 26 (permalink) Old 11-09-2008, 01:42 AM
if you look underneath the dash on the passanger side, you'll see your blower motor and beside it on the left is a 4 wire connector. That's the resistor.
Sparky87 is offline
post #13 of 26 (permalink) Old 11-09-2008, 08:01 AM
Canyon08Z71's Avatar
viewtopic.php?f=8&t=48293
Canyon08Z71 is offline
post #14 of 26 (permalink) Old 11-09-2008, 03:09 PM
Never knew there was a how-to on this already. I won't bother with my pics then :P
Sparky87 is offline
post #15 of 26 (permalink) Old 11-10-2008, 10:34 AM Thread Starter
Thanks for the link guys.
Cobra4B is offline
post #16 of 26 (permalink) Old 11-10-2008, 03:06 PM Thread Starter
Well... it's fixed for now. I pulled the side access cover and looked around and then looked up under where the plug goes into the resistor. It wasn't fully seated. The plug allows for a little play which may be the issue. I pushed the plug all the way in and everything works perfectly. None of my pins or wires are "burnt up" or discolored at all.
Thanks for saving me some money.
Cobra4B is offline
post #17 of 26 (permalink) Old 11-13-2008, 02:55 PM Thread Starter
Well hit a big bumpt today and it stopped working on 1, 2, and 3 again. Reached up under the dash and jiggled the pluge and all is working again perfectly.
So does this mean there's a design flaw in the plug that doesn't keep it fully seated even when clipped in?
I'm going to try using some gorilla tape on it. Any other ideas? The plug and wiring all looks perfect... no burning etc.
Cobra4B is offline
post #18 of 26 (permalink) Old 11-22-2008, 07:08 PM
Terminals are prolly loose in the connector. That is why it is recommended to replace both the connector/harness and the resistor together. I heard GM re-designed the new parts.
post #19 of 26 (permalink) Old 11-23-2008, 02:52 AM
Exactly. Maybe try getting one of those little tiny picks or sunglass screwdriver and try to carefully bend the female terminals slightly to cause some pressure against the pins for better contact.
turbizzy is offline
post #20 of 26 (permalink) Old 11-24-2008, 10:00 PM Thread Starter
Thanks guys... it's been ok for a bit, at least I know where it is and didn't waste my money.
Cobra4B is offline
