How much tow? - Chevy Colorado & GMC Canyon
post #1 of 11 (permalink) Old 11-09-2008, 01:36 PM Thread Starter
Send a message via AIM to Rawgerod Send a message via MSN to Rawgerod
How much tow?
I have a series of questions...
Can i tow this blazer 260miles??? Would you tow this blazer with your colorado 260 miles...
2005 Colorado crew cab i dont know what motor it has but when I open the hood it says 3500 vortec... which i assume is the 3.5L and i dont know what axel which shows a difference in weight tow capacity load...in the manual..
i read the manual and now I have more questions than answers..would you tow it in another gear D 3 2 1??? and which one?? not alot of hills..
Rawgerod is offline
post #2 of 11 (permalink) Old 11-09-2008, 03:27 PM
naskie18's Avatar
Re: How much tow?
Thats a nice looking K-blazer!!
Always liked them :)
The towing capacity of your Colorado (legally) is 4000#. If the K-Blazer and trailer/dolly weigh more than that, then legally you shouldn't tow it. I'd probably do it anyway, we've seen that these trucks can tow well over what they're rated, just be sure to leave yourself plenty of room for braking.
Your gear ratio won't effect how much you can tow.
Whenever you're towing anything, you shouldn't use overdrive, so in the case of the Colorado, you should tow in 3.
naskie18 is offline
post #3 of 11 (permalink) Old 11-09-2008, 03:45 PM
Re: How much tow?
I would tow the coly with the blazer. You won't even feel it back there. My two cents....
calzq8 is offline
post #4 of 11 (permalink) Old 11-09-2008, 03:53 PM
naskie18's Avatar
Re: How much tow?
Yeah, but even if the K-Blazer is in great shape (which it certainly looks to be), you still really don't want to drive it 260 miles. Colorado would be much more comfortable, even though it isn't necessarily better suited to towing it.
naskie18 is offline
post #5 of 11 (permalink) Old 11-09-2008, 04:01 PM Thread Starter
Re: How much tow?
Its not so much the tow but how long ill be towing it for ... its going to be about 4+hrs... The only thing wrong with the blazer is that one of the heads is bad and that's the reason im towing it.. if not I wouldnt mind driving the blazer and towing the colorado...im going to decide what im going to do later this coming weekend
Rawgerod is offline
post #6 of 11 (permalink) Old 11-09-2008, 04:37 PM
Re: How much tow?
I towed 6500 pounds with my manual tranny Canyon. No problem. Do it in 3
rangerbob is offline
post #7 of 11 (permalink) Old 11-10-2008, 04:11 PM
Send a message via AIM to Cobra4B
Re: How much tow?
I tow 4900-5500lbs 5-6x a year when going to the race track. The truck really benefits from a 7-pin wire so you can run a brake controller which I do. I also have an equalizer hitch and airbags. The airbags are overkill, but the hitch and brake controller are necessary.
Now if you're just going to go slow and take it where it needs to go then you can tow as-is, but I wanted safety and security. I can tow at 70 w/o issue. I always tow in 3rd. Oh and I also installed a B&M air/liquid aux. trans cooler in the factory cooler's return line.
2004 GMC Canyon - DD/toy hauler
2001 Quicksilver Z06 - NASA TTA racecar
2003 Torch Red/Tan Corvette Convertible
Cobra4B is offline
post #8 of 11 (permalink) Old 11-10-2008, 04:24 PM Thread Starter
Re: How much tow?
Im thinking by everyone's response that it shouldn't be a problem. The manual does say for anything that is hitched to your truck has its own braking system. It says that riding the break too much can make them fail or loose its breaking power.. but in my case im just going through the outside of every town for less breaking.thanks for the advice
Rawgerod is offline
post #9 of 11 (permalink) Old 11-11-2008, 12:19 PM
Re: How much tow?
i towed a 6x12 u-haul from VA to TX...with the back of my truck loaded completely down...yeah i got about 3 mpg but didn't have any real problems moving or stopping...
(3mpg is an exaggeration btw...can't remember what exactly i got but it was in the low teens)
tow the blazer...no problem
Just had a baby....so i'm living vicariously through you and your truck...
eddiejoe is offline
post #10 of 11 (permalink) Old 11-11-2008, 10:02 PM
Re: How much tow?
I measured 12.9 MPG towing my Panoz on my trailer w/ the bed and by toolbox and cab fully loaded. Most of the trip my CC was set at 70 towing in 3rd.
Cobra4B is offline
post #11 of 11 (permalink) Old 12-02-2008, 12:08 PM
Re: How much tow?
I towed my friends grand am on a dolly, as well as his 1981 1100 cc harley (in the bed). I climbed some serious hills as well (where i slowed to about 55mph) but at 65 mph the colorado didn't seem to mind at all. my colly is an '06 4x4 crew cab 3.5. I agree with Cobra 4b: if you plan on towing that kind of weight more often, i'd invest in a new trailer harness and brake control. I also managed to travel the full 300 miles i towed on one tank of gas (17.8 gallons when i filled up).
Gregor is offline
