4wd will not engage flashing light - Chevy Colorado & GMC Canyon
post #1 of 55 (permalink) Old 12-02-2008, 04:34 PM Thread Starter
I woke up this mornign to the first snow of the year and pulled out of my driveway to find the roads a bit slick so I decided to put the 05 Canyon into 4 hi. So I press the button and all it does is flash? So I press 2 hi and it flashes a few times then goes solid and I drive to work in 2 hi.
When I get to work I decided to put it into neutral and see if it will go into 4 hi then, but no luck still just flashes. So I try 4 low, I put it in neutral and I hear it go into low, but the 4 low light also just flashes so I try to drive and it is defenitely still in 2wd. So I push 2 hi and it goes back into that.
I tried putting it into 4hi at a stop, at low speed (a few mph), at higher speed (20 mph), and even while slowly rolling backwards all with no luck.
I also noticed that when I put the transmission into neutral the N light does not light up on the 4wd button panel. I thought it used to light up with a red light if I remember correctly???
Any ideas or other things to try?
bainer1290 is offline
post #2 of 55 (permalink) Old 12-02-2008, 05:04 PM
Send a message via AIM to platinumZ71
Re: 4wd will not engage flashing light
mine did this acouple months ago when i 1st tried my 4x4 and u had to go thru this process i found on here...do a quick search u should be able to find it but u have the right idea i had to shift to neutral acouple of times while pulling the ebrake i think and then it worked and never had a problem since
08 Inferno Orange Z71 Colorado Crew Cab 4x4 I5
MODS: Spray-On Bed Liner, Lund Smoked Bug Shield, AVS Smoked Vent Visors
3rd brake light cover, 20%tint with windshield drop
Black Metal Taillight guards, Hunter Black Brush Guard
Black Verticle grille, Black housing halo headlights, Black front bumper
3" exhaust, Black H3 Wheels, mass airflow sensor...etc
platinumZ71 is offline
post #3 of 55 (permalink) Old 12-02-2008, 05:24 PM Thread Starter
I found a article that says the procedure is listed in the owner's manual. Is this true for my 05?
post #4 of 55 (permalink) Old 12-02-2008, 07:51 PM Thread Starter
Found the section in the manual on how to put it in neutral, did it 3 times, then tried 4 hi and low again but same flashing light...
What gives?
post #5 of 55 (permalink) Old 12-02-2008, 07:59 PM
If you search enough I am sure this has been discussed. It's been over a year since I have seen it though. When you say it was flashing in 4hi/lo and you knew it was in 2hi, do you mean that the light didn't go back to 2hi? But was flashing 4hi/lo when driving?
RIP Spike 9-25-2007
coyote is offline
post #6 of 55 (permalink) Old 12-02-2008, 09:40 PM
atxcoloradofan's Avatar
Send a message via AIM to atxcoloradofan Send a message via Yahoo to atxcoloradofan
it says in the manual a whole process you should go through to get it back to work and its not that 3 times deal. it says:
"On vehicles with an automatic transmission, if your transfer case does not shift into 4HI, your transmission indicator switch may require adjustment. With your transmission in NEUTRAL (N), press and release the 4HI button. While the 4HI indicator light is flashing, shift your transmission into PARK (P). Wait until the 4HI indicator light remains illuminated before shifting your transmission into gear. Press the 4HI button again to complete the shift. This will get you into 4HI, but you should take your vehicle in for service to restore normal operation."
and if that doesnt work, dont know what to tell ya. take it and let them see what the problem is.
Mud Club Member #19
Lifted Club Member #195
atxcoloradofan is offline
post #7 of 55 (permalink) Old 12-02-2008, 10:30 PM Thread Starter
Correct, if I press 4hi it keeps flashing while parked or driving, it does not change back to 2hi.
I found a few discussions but nothing that has worked yet, everything that I have tried I have mentioned in this discussion.
I will try what you mentioned atxcolorado and let you know if it works. Thanks.
If I missed something please let me know.
post #8 of 55 (permalink) Old 12-02-2008, 10:52 PM
now when you put into 4HI in the first place were you completely stopped?! or were you driving?! if you were driving that cant be good for it.
Mud Club Member #19
post #9 of 55 (permalink) Old 12-02-2008, 11:11 PM
It's shift on the fly 4WD? I put mine into 4HI at speed all the time with no problems.
rangerbob is offline
post #10 of 55 (permalink) Old 12-02-2008, 11:16 PM
oh ok, just said in the manual have to be at a certain slow speed or stopped to do it, so just goin off what it said on there.
Mud Club Member #19
post #11 of 55 (permalink) Old 12-02-2008, 11:23 PM Thread Starter
Yes I have put it into 4 hi many times while moving and stopped, never an issue before. 4 low is different the tranny needs to be in neutral and you need to be stopped or only barely moving a few mph...
post #12 of 55 (permalink) Old 12-02-2008, 11:38 PM Thread Starter
Just tried this 3 times, but light just kept flashing...
post #13 of 55 (permalink) Old 12-02-2008, 11:46 PM
sucks man i dont know what to tell ya...undo your battery and put it back, ha ha j/k but yea if your still under warranty go have a dealership look at it.
Mud Club Member #19
post #14 of 55 (permalink) Old 12-02-2008, 11:53 PM Thread Starter
warranty ended about 8 months ago...
I may take a closer look at the actuator this weekend to see if it is even trying to engage. Other than that I read a discussion where it was some control module under the drivers seat but that is probably worth $$$ so hopefully it is not that...
Any other ideas let me know...
post #15 of 55 (permalink) Old 12-03-2008, 07:57 AM
It almost sounds like the actuator is sticking or something.It it below freezing where you are? Did maybe some water get in the transfer case and freeze? If not I would think a trip to the dealer would be in order. It sounds like it needs an adjustment or a part. You can hear it click when changing drive modes. Just have someone else press the button while you are under the truck and listen for it.
RIP Spike 9-25-2007
coyote is offline
post #16 of 55 (permalink) Old 12-03-2008, 09:52 AM Thread Starter
I live up in Alberta Canada and it was just barely below freezing yesterday. Transfer case oil has not been changed yet, vehicle has 85,000 km's now so probably about time to do that anyways, but I doubt it has water in it as this vehicle barely ever goes off the highway. I will crawl under there and have somebody press the buttons to engage 4 hi and 2 hi to see if I can hear anything.
Is there 2 actualtors 1 for 4wd and one for low? Reason I ask is the light flashes endlessly for both 4 hi and 4 low, but when I put it into 4 low I do hear the normal thump, which I think is it going into low gear...
post #17 of 55 (permalink) Old 12-03-2008, 10:48 AM Thread Starter
One other thing worth mentioning, there are no check lights that have come on on my dash. In some of th eother discussions people have said the service 4wd light has illuminated, but no lights have come on for me...
post #18 of 55 (permalink) Old 12-03-2008, 11:15 AM
I'd have to look at my Haynes manual to see how many actuators there are.
RIP Spike 9-25-2007
coyote is offline
post #19 of 55 (permalink) Old 12-03-2008, 12:20 PM Thread Starter
I'm thinking they are separate...
post #20 of 55 (permalink) Old 12-03-2008, 07:11 PM Thread Starter
So I just crawled under the truck and had a buddy press the different buttons and I could hear the actuator on the drivers side of the front diff. It made a sound for a few seconds when 4 hi and the same on 4 low, but also a clunk at the end of 4 low which was the gears going into place. Then it also made a sound when 2 hi was pressed. So all this seems good except the light still flashes in 4 hi and low and I only have 2wd.
I then checked the connector to the actuator and it looks good, I pulled it off and it was really clean.
Could the actuator still be bad but make a sound? Seems to me this is the most likely cause since it seems to be getting power and the signal it just doesn't get into 4wd?
Anything else to check?
