heat shield rattle - Chevy Colorado & GMC Canyon
post #1 of 9 (permalink) Old 02-24-2009, 10:03 AM Thread Starter
heat shield rattle
i have an 06 crew and i have a buzzing noise at about 2000 rpms and it is driving me nuts anybody know witch heat shield it is
njblazer is offline
post #2 of 9 (permalink) Old 02-24-2009, 10:07 AM
Re: heat shield rattle
Either the manifold shield or the secondary cat shield. Put a hose clamp over the second cat under the body and see if it goes away.
rangerbob is offline
post #3 of 9 (permalink) Old 02-24-2009, 10:10 AM Thread Starter
thanks ill try that
njblazer is offline
post #4 of 9 (permalink) Old 02-28-2009, 03:46 PM
I had the same problem too. They just tighten the bots on mine and it took care of it.
2005 Colorado Z71 Crew Cab 4x4 3.5 I-5
K&N Air Filter
ARE Toneau cover
AVS Bug Guard and Ventshades
Factory Nerf boards
gotigers1 is offline
post #5 of 9 (permalink) Old 03-01-2009, 08:39 AM Thread Starter
i will try that if not i just might remove the heat shield
njblazer is offline
post #6 of 9 (permalink) Old 03-01-2009, 08:53 AM
Send a message via AIM to koolz71
if you remove the heat shield you will create lots of unnecessary heat under the hood, and it would probably not be the best thing for the motor...mine had a bolt stripped out of it from the factory and it was just stripped out...it could just be a simple fix
koolz71 is offline
post #7 of 9 (permalink) Old 03-24-2009, 08:35 PM
i have a 2008 z71 crew cab n i was wondering what was a faster way to change the spark plugs? cause damn its complicated
diffuser_11 is offline
post #8 of 9 (permalink) Old 04-10-2009, 06:22 PM
I had a problem with rattleing between 2050rpm and 3000rpm and it ended up being the second catalytic converter (the one built into the exhaust manifold) I guess the cat thats built into the exhaust breaks without too much of a bump to the exhaust pipe. It was replaced under the 8 year or 80k emissions warranty. Some of the heat shields may look like they have a broken weld but dont because they are welded and have the lip of the shield coming down after the weld.
DirtNWaterMakeMud is offline
post #9 of 9 (permalink) Old 04-10-2009, 07:10 PM
I had this same issue with my truck. Manifold was replaced under the 80k warranty. I also noticed that the silver AC lines under the truk were causing a little bit of a rattle also. They run under the passenger side close to the manifold. I just bent them away from each other a little and it was fixed.
blackmetal19 is offline
