obd code p0106 and p0506. - Chevy Colorado & GMC Canyon
post #1 of 3 (permalink) Old 03-18-2009, 09:53 PM Thread Starter
Send a message via AIM to dstark181
Idle Air Control (IAC) System RPM Lower Than Expected and Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem. anyone having/had this same problem? im not to sure how or where to start with this. p0506 is normally an indicator for another code, in this case p0106.
any suggestions would be helpful.
Dustin Stark
dstark181 is offline
post #2 of 3 (permalink) Old 03-18-2009, 10:13 PM
Re: obd code p0106 and p0506.
You didn't have to wait until you had a problem to join. Just kidding. Welcome Aboard. Seriously, one of the chief causes for the the P0506 code is a dirty throttle body.
The P0106 is a weird one, means 'the MAP sensor is stuck within the normal operating range'. I would try cleaning the throttle body, get the codes erased, and see if they return.
Here's the 'How To' on cleaning the throttle body: viewtopic.php?f=8&t=54407
post #3 of 3 (permalink) Old 03-19-2009, 01:09 AM
i had the same problem... all i did was clean the throttle body and bamn codes gone :)
05' Z71 Extended cab Sliver Brich 2wd
K&N intake|MagnaFlow Exhaust|No CATS|Blacked out bowtie|
Painted interior|ScanGague2|BFGoodrich A/T|55wH.I.D's|2in shackle lift/torsion bar|
ericbg is offline
