my truck will not shift into gear....... now it wont start!! - Chevy Colorado & GMC Canyon
post #1 of 13 (permalink) Old 03-23-2009, 11:15 AM Thread Starter
hey guys need a lil help, dont know if this has happened to anyone else. i had a hard time puttin my truck into reverse and it does not want to go in drive. i went back in my house to call my local chevy dealer but all they told me was they wont know what is wrong til they run a diagnostic test, i went back outside, tried to start my truck but now it will not turn over.
David_D is offline
post #2 of 13 (permalink) Old 03-23-2009, 11:42 AM
Re: my truck will not shift into gear....... now it wont start!!
Start with having the battery tested at your local auto parts store. These trucks are extremely sensitive to voltage changes. A bad battery or one going bad may cause all manner of problems.
post #3 of 13 (permalink) Old 03-23-2009, 11:44 AM
what year and about how many miles?and welcome to coloradofans
CORVETTEHOOP/ 2008 T.O.T.W. #40/Gun Toting American Club Member #58
1982 Silverado 2wd reg cab red/2003 S-10 black loaded Crew Cab 4x4 (R.I.P.)2008 Total Loss
2009 Colorado Z-71 4x4 Crew 3LT Black I-5 sunroof, leather, Hella 500ff's, pull bar, 20% tint, gm hitch w/pintle hitch, hood insulation, Tb crank, gm mudflaps, gm moulded carpet mats, Xzilon paint protection so far... 1998 Starcraft POP-UP Camper
1995 High Maintainance Son W/ Kawasaki KLX 110 dirt bike, Fmx bmx race bike, Dk general lee
corvettehoop is offline
post #4 of 13 (permalink) Old 03-23-2009, 12:16 PM Thread Starter
even if evrythin stil turns on like the radio, even the gas gauage and temp needles move jus like u would turn the key to on. if so which battery would u recommend for a replacement
its a 2007 with 45010 miles. thanks
David_D is offline
post #5 of 13 (permalink) Old 03-23-2009, 12:43 PM
naskie18's Avatar
I don't think the battery is your problem, my sister's 04 (with pretty close to the same miles, she's somewhere in the 40s, if I remember right) just had a similar issue, except she forced it into drive and then shut it off and wasn't able to get it back out of drive to start it again.
Did you manage to get it back out of reverse, or is it stuck in gear? If its stuck in gear, that's why it won't try to start. The truck won't start in any gear other than park or neutral.
She ended up having to have it towed to the dealer and it cost her a couple hundred bucks to have it fixed.
I don't remember what the issue was, and although I know exactly where the paperwork is, I won't be home until tomorrow night
naskie18 is offline
post #6 of 13 (permalink) Old 03-23-2009, 12:53 PM
Naskie to the rescue? :D
post #7 of 13 (permalink) Old 03-23-2009, 01:01 PM
naskie18's Avatar
Got somebody to fax it to me :)
Here's a PDF of the invoice. Like I said, not sure whether its the same problem you're having, but it sounds very similar.
If I remember right, it was a pretty involved repair and they had to take apart a lot of the steering column.
naskie18 is offline
post #8 of 13 (permalink) Old 03-23-2009, 01:29 PM Thread Starter
thanks that is exactly wha happened, i did get it out of reverse but the guage is still shown that it is in reverse i will probabaly jus have to do the same i appreciate all the help
David_D is offline
post #9 of 13 (permalink) Old 03-23-2009, 01:45 PM
naskie18's Avatar
Print out a copy of the PDF from the post above and take that with you to the dealer when you go, and if they can't quickly tell you what's wrong, show them that and tell them it had similar symptoms and hopefully that'll help them be able to quickly diagnose it and get it fixed & back to you.
naskie18 is offline
post #10 of 13 (permalink) Old 03-23-2009, 02:41 PM
Sorry I was hopin to say it is under warranty but 07 has 100,000 mile powertrain warranty and that sounds electrical to me, sorry and keep us informed
post #11 of 13 (permalink) Old 03-23-2009, 06:36 PM Thread Starter
i finnally got word back bout my truck, they will have to keep it over night they wont be able to have some one look at it till tomor, hopefully. it has nothing to do with the steering column, so they think its jus a bent or damaged linkage underneath the truck. thanks for the help naskie18 the print out helped them get an idea of what it was, i will post more as soon as i get my truck back
David_D is offline
post #12 of 13 (permalink) Old 03-26-2009, 12:25 AM Thread Starter
got my truck back after two nights n three days, they had to replace a transmission cable, which cost me bout 280 dollars but it s all good jus happy i got my truck back
David_D is offline
post #13 of 13 (permalink) Old 03-26-2009, 12:34 AM
Good deal, sometimes it's just worth it to take it to the stealership. Glad you got it back up and running.
dents-n-dings is offline
