vent valve - Chevy Colorado & GMC Canyon
post #1 of 11 (permalink) Old 03-23-2009, 11:19 AM Thread Starter
vent valve
how do i install the evaporative vent valve 05 colorado or where is it located?
carnut is offline
post #2 of 11 (permalink) Old 03-23-2009, 11:55 AM
Re: vent valve
Are you referring to the purge valve?
post #3 of 11 (permalink) Old 03-24-2009, 02:58 PM Thread Starter
Re: vent valve
dont know.it has a hose and some wire connections.problem is the gas cap light is on then trouble code sets for large vacume leak in evaporative vent valve.
carnut is offline
post #4 of 11 (permalink) Old 03-25-2009, 09:31 AM
Re: vent valve
The purge canister and solenoid are located underneath above the fuel tank. There is also a purge valve on the driver's side of the engine block.
post #5 of 11 (permalink) Old 03-25-2009, 12:00 PM
Send a message via AIM to koolz71
Re: vent valve
i have this issue on my truck..dealership told me it would be about a 275.00 fix..the valve is on the top of the tank if i remember correctly..im just gonna let her go for now, till i get the money
koolz71 is offline
post #6 of 11 (permalink) Old 04-06-2009, 07:28 PM
Re: vent valve
I just replaced both the vent valve and the purge valve on my truck. The vent valve is located at the back of the truck pretty handy to the spare tire. It is attatched to the side of the charcoal canister.. the valve assembly itself looks like a coffee cup. The list price at the dealer is around $200... but if you take it off and take it in and ask for one for a hummer h2 they are exactly the same part except the hummer one doesn't come with the pipe so you will have to reuse the old one. The one for the hummer h2 is about $45... if they don't have one for a hummer just take it in and they will have one there off another vehicle that will fit for about $50. The purge valve is on the drivers side engine compartment. If you take the rubber mud guard off the wheel well you can look in through and see it.. its right by a cord with plug on it that has tinfoil like wrapping.
nateashfield is offline
post #7 of 11 (permalink) Old 04-06-2009, 09:29 PM
Send a message via AIM to DYANIK
Re: vent valve
Has replacing this valve solved a large evap leak issue for anyone, I have an 05 that is showing either a loose gas cap or other large evap leak?
2005 Colorado LS Ext Cab Z85
4x4 I5 5 spd 3.73 Auto Locker
Victory Red w/ color keyed facia
All the power options and sunroof
Stock at the moment
DYANIK is offline
post #8 of 11 (permalink) Old 04-09-2009, 05:57 PM
Re: vent valve
what fault code or codes are you getting.. I could be the trigger for a large evap leak if it was stuck open.
post #9 of 11 (permalink) Old 04-16-2009, 10:47 AM
Re: vent valve
Hay gays I'm getting the code p0446 vent valve problem. So i took the vent valve off and tested it with 12v power. And it seems to be working fine opens and closes. when i was doing this i was blowing in the hose to see if there would be any leaks when the valve was close there were no leaks. So could it be something else like the fuel tank pressure control?
RM-67-E is offline
post #10 of 11 (permalink) Old 04-16-2009, 02:05 PM
Re: vent valve
Another member just had a similar problem and it turned out the harness on the solenoid was not making a good connection.
viewtopic.php?f=8&t=70820
post #11 of 11 (permalink) Old 04-25-2009, 07:24 PM
Re: vent valve
The part number for the much cheaper replacement vent valve is GM part # 15208329.. it is exactly the same valve minus the pipe. I paid $46.55 from the local dealer but they are on gmpartsdirect.com for around $18
