CEL Code P0068 - MAP Sensor? - Chevy Colorado & GMC Canyon
post #1 of 2 (permalink) Old 05-18-2009, 04:28 PM Thread Starter
Here's the problem, started this past weekend: (2005 z71 - I-5, 65,000)
When starting the truck at first it did not want to turn over at all. (Which made me think it was the battery). After a few turns of the key, it turned over, but ran really really rough, like it was only firing 2 cylinders. I turned the truck off, and let it sit for a minute, and it turned over fine, but CEL remained on. Got it scanned and it was throwing code P0068. I've done some searching on here, but really haven't had much luck (a lot about the camshaft solenoid valve, but i checked that and it looked fine). I called the dealer and told them the code, and the tech said it was most likely a bad MAP sensor. Is there a way to check if the sensor is bad? What else could it be? Any help would be greatly appreciated.
webbman81 is offline
post #2 of 2 (permalink) Old 05-28-2009, 09:56 PM
Re: CEL Code P0068 - MAP Sensor?
ok heres how to diagnose your code P0068
Follow these instructions and it will tell you whats wrong
If you run into a problem or cant get ahold of a scan tool,(ask around someone prolly has one that you can use), ill be checking this post every couple days to help you out
hope this helps
2006 colorado 2wd
Offroad enthusiast
Automotive student
06colorado2wd is offline
