Truck wont start 2005 GMC Canyon - Chevy Colorado & GMC Canyon
Old 07-01-2009, 10:28 AM   #1 (permalink)
Default Truck wont start 2005 GMC Canyon
Truck will not start...When I put key in ignition the dash comes on no errors like check engine no security lights etc..I turn key nothing.Doesnt click click click(Battery) Doesnt attempt to turn over nothing.Put on a scanner and no codes pop up.Started truck direct from battery to starter truck starts up fine.Took apart steering column and replaced ignition switch still nothing.Tried to reset computer by holding neg. to pos. for 20 seconds still nothing.Also I charged the battery and cleaned terminals still nothing.Where can I look next is this possibly a bad computer?Any help would be greatly appreciated.The truck is 4wd 2.8 Automatic.Thanks,
Matt
lyo1984 is offline   Reply With Quote
Old 07-02-2009, 01:54 AM   #2 (permalink)
Default Re: Truck wont start 2005 GMC Canyon
sounds like theres a short somewhere in the starter circuit
deepseadynamo is offline   Reply With Quote
Old 07-02-2009, 04:16 AM   #3 (permalink)
The first place I would look is fuse 43 (30 amp) then relay 62 and relay 61. After that it would be the neutral safety switch.
You probably should go download the "Starting Automatic Trans.pdf schematic and take some voltage readings there to see which way to go. (I am new to this forum and could not figure out how to add the file to this posting.)
As a example from the schematic, if there is +12 coming out of Relay 82 then everything upstream is OK and you have a bad starter solenoid.
It is kind of hard to help diagnose this further without some voltage readings from the various components.
n9cv is offline   Reply With Quote
Old 07-02-2009, 07:20 PM   #4 (permalink)
http://www.naskie18.com/colorado/schema ... 0Trans.pdf
2005 Z71 LS Crew Cab 4X4 L52, 4L60E, GT4, Silver Birch Metallic MAXX Shackles: http://www.355nation.net/forum/suspe...here-here.html MAXX Cam JR Lift Kit for 4X4 & 2WD Z71: http://www.355nation.net/forum/suspe...ering-kit.html
MAXX Stak Lift Kit for 2WD: http://www.355nation.net/forum/suspe...t-numbers.html PerforMAXX Body Lift: http://www.355nation.net/forum/suspe...y-spacers.html
ssgjurista is offline   Reply With Quote
Old 07-05-2009, 02:29 PM   #5 (permalink)
I see you refer to fuse/relay #'s.... like # 43... How do I find out what fuse is what number/location?
I am having the same problem but, my truck is a standard. I realy don't think it has anything to do with the clutch switch. Please help. This is my only transpertation and I have my baby to take to daycare. Please.. Thanks yall
'71 Chevy C10 LWB "LOW DOUGH"
'69 Chevy C10 LWB "Parts Truck"
'06 GMC CANYON Z85 "Daily Driver"
LOW DOUGH is offline   Reply With Quote
Old 07-05-2009, 03:39 PM   #6 (permalink)
ok found something with all the numbers.
http://www.coloradofans.com/forums/v...hp?f=8&t=47680
Old 07-05-2009, 08:01 PM   #7 (permalink)
jpo
Is the Passlock System tripped preventing starting? Locked door with Remote Keyless Entry but opened the door with the key?
2007 Canyon Ext Cab
jpo is offline   Reply With Quote
Old 07-06-2009, 10:44 AM   #8 (permalink)
I don't have Keyless Entry.
I bypassed everything. I took a wire from the starter and one from the Batt. and brought them in the cap. I have to turn the key to on then touch the 2 wires together to get it to start. Ofcours my foot is on the clutch too.
So it's not the keyless thing.
Any other ideas guys??
thanks, I don't like hot wireing my truck. I looks bad. HAHAHA
Edit: Sorry don't mean to highjack this thread. I made a new one.
viewtopic.php?f=8&t=74041&p=987455#p987455
You may not post new threads
You may not post replies
