P0017 scary thought and questions - Chevy Colorado & GMC Canyon
post #1 of 35 (permalink) Old 07-13-2009, 10:44 PM Thread Starter
Howdy everyohe. So, I was driving to work on Friday morning, and the truck started fine. Left my house, and the truck sounded a little funny. Got half way to work (3 miles), and go to a stop sign, and the truck went BLAH!!! Rough idle (300 rpms). Made it to work and the truck stalled, without a check engine light. Restarted the truck at work, got the check engine light, and made it stall again. With my friends code reader, i got a P0017 code. I already knew what that was, so I called the dealer. Under warranty, so I had it flatbedded to the dealer. At the end of the day, I was told what the problem was, and the part was not in stock. So, Monday is here, and my truck is fixed. They replaced the Camshaft Position Actuator Solenoid Valve, and changed the oil, since one of my 3 screens was missing. The screen was found, in tact, according to the service manager, and I was told I was lucky they found the screen. He then gave me a 3 page printout of the "preliminary inspection document" # PIP3694C (document 2235070). This can be a very bad situation. If the crankshaft end play is out of spec, they recommend a engine replacement!! OUCH!!!!
SO, HERE ARE MY THOUGHTS AND QUESTIONS:
1- my truck is a 2006 colorado crew cab, 3.5l with 19,000 miles on it. Since 1500 miles, it has used Mobil 1 Synthetic, and changed at least 2 times a year. I also use a oil filter magnet on my truck, and all vehicles since i have started driving since 1989. Is there any cause for concern with either of my choices here?
2- should i be concerned since the truck is so young in miles, that this could happen again?
3- dealer did a regular oil change, and i came home and re-did the oil change with mobil 1 again.
4- how many others have had this problem ( i know there are topics on this already), but has anyone had to have the motor replaced?
All help is greatly appreciated ! thanks.
Grego is offline
post #2 of 35 (permalink) Old 07-13-2009, 10:59 PM
Re: P0017 scary thought and questions
did you break in the new engine with synthetics?
zeuce is offline
post #3 of 35 (permalink) Old 07-13-2009, 11:11 PM Thread Starter
Mobil 1 after 1500 miles. It was a typo and I corrected it.
Grego is offline
post #4 of 35 (permalink) Old 07-13-2009, 11:42 PM
Crankshaft end play or camshaft end play?
The camshaft position actuator solenoid has been redesigned to eliminate the screens from coming loose. The dealer should have installed the new design because if they tried to order the old part number, the GM parts system would give them the new number. Any solenoid can fail but because of the new design, it would fail without pieces of the screen going through the system.
The magnet may work if the screens are magnetic but even without a magnet the screens would get trapped in the filter media.
Your questions are certainly valid, but I think you can rest easy.
post #5 of 35 (permalink) Old 07-28-2009, 11:36 PM
What does the PO017 code mean? i just got it on my 06 canyon and so far my mechanic has not been able to fix it. do you still have this?
mattflan is offline
post #6 of 35 (permalink) Old 07-29-2009, 12:02 AM
http://service.gm.com/gmspo/mode6/pdf/2 ... file14.pdf
Most likely the camshaft position sensor ot the actuator solenoid.
post #7 of 35 (permalink) Old 07-29-2009, 02:03 PM
funny to read about magnets.i use 2 magnets with tie ban around filter.i use them on my honda shadow bike and my lawnmowers.
sproulman is offline
post #8 of 35 (permalink) Old 07-29-2009, 07:50 PM Thread Starter
it works for me!
Grego is offline
post #9 of 35 (permalink) Old 12-04-2009, 03:36 AM
My 2006 gmc canyon with 18,000 miles started running rough and engine light came on. I took it to auto zone and they pulled a p0017 code. I took it to the Gmc dealer. They called me today and told me my engine was inoperable and the engine essembly had to be replace because the internal bearings were bad. I am 7mnths out of the 3yr warranty but they contacted Gm and they are replacing it with a brand new engine, parts and labor free. Has anyone else had this problem?? It just seems to odd for only 18,000 miles!?
markthehunter is offline
post #10 of 35 (permalink) Old 12-04-2009, 06:43 AM Thread Starter
wow! i was almost at that point, but thankfully, my engine was ok. it is now about 3000 miles since my code, and all is ok, but i am now out of warranty.
Grego is offline
post #11 of 35 (permalink) Old 12-04-2009, 02:02 PM
i think that was year when they had bigtime engine problems.valve problems from what i read.
post #12 of 35 (permalink) Old 12-06-2009, 09:19 PM
Well, guess what, the next day I get a call from the dealership. They told me the District Gm manager called them back and said I had to pay 50% of the cost $2,300.00 I spent 2 hrs on the phone with Gm, they say they will get back to me sometime this coming tuesday.. Time to lawyer up!!!
post #13 of 35 (permalink) Old 12-06-2009, 11:55 PM
forget lawyer.they will cost you a lot and most wont handle a case for 2300.get info from others on here that had their engines replaced,they should be able to help you.
post #14 of 35 (permalink) Old 12-07-2009, 06:34 AM Thread Starter
what was their reason for changing their mind?
Grego is offline
post #15 of 35 (permalink) Old 12-07-2009, 01:17 PM
They said that the GM district manager sent them an email back informing them I had to pay 50%.. I did call 1800gmcares and they opened a investigation/claim looking into it. I should hear from GM tomorrow. The Gm tech that is working on my truck is saying Gm should replace the engine because it is a defect/shouldn't happen at 18,000 miles and there is nothing I could have done to cause it. The endplay is beyond Gm specs so the only fix is a new engine assembly. I would greatly appreciate any advice anyone might have :) Who should I call next if I get bad news from Gmcares tomorrow? Is there a different avenue I should seek? Thanks
post #16 of 35 (permalink) Old 12-07-2009, 01:41 PM
You could tell the service manager to reach down between his legs and summon some testicular fortitude and go to bat for you. A good service manager would get a hold of the district manager and change his mind for you so you don't have to pay out of pocket.
post #17 of 35 (permalink) Old 12-07-2009, 10:47 PM
post #18 of 35 (permalink) Old 12-10-2009, 01:50 AM
Any word on the verdict? Hope things turned out in your favor.
2005 Canyon Crew, 3.5L, Chrome Hummer H3 wheels and tires, Street Scene grill, K&N breather, Cold air intake, SnugTop bed cover.
tzsv4k is offline
post #19 of 35 (permalink) Old 12-10-2009, 11:46 AM
I heard from the shop yesterday. They said the AVN(area vehichle manager ) still says I have to pay 50% of the cost. Then Gm customer service called me soon after . They said the case was closed and thats all that they can do is 50%.. No one I talk to can understand how GM is just fine and dandy with a whole engine having to be replaced at 18,000 miles and raping the customer. I just dont get it.
post #20 of 35 (permalink) Old 12-10-2009, 12:41 PM
Send a message via AIM to FixxxerKH202
i would call the better business bureau and your state attorney general and let them in on the situation a motor with 18,000 miles should not have faulty bearings unless you were running some REALLY heavy weight oil, the only argument i can see on their part is it wasn't broken in properly
FixxxerKH202 is offline
