Changing Automatic Transmission Fluid - Chevy Colorado & GMC Canyon
post #1 of 4 (permalink) Old 11-16-2009, 02:56 PM Thread Starter
Send a message via AIM to coldsolderjoint
Hello,
Can you guys tell me the proper procedure for changing the automatic transmission fluid on my truck. It's an 06 Crew Cab, 4 Cylinder, 2WD, Automatic Trans.
Is it just a simple drain, change the filter, and refill like an oil change?
Thank You,
coldsolderjoint
coldsolderjoint is offline
post #2 of 4 (permalink) Old 11-16-2009, 06:39 PM
Re: Changing Automatic Transmission Fluid
http://www.355nation.net/forum/how-tuto ... hange.html
post #3 of 4 (permalink) Old 08-27-2011, 06:53 PM
Send a message via AIM to gixxr750
good write up... thanks for the link!
06' I5 z85 crew cab, over the past three years... k&n cold air, hptuner tuned, test pipe, gutted first cat,
low pro crossmember, trail blazer tb mod, 20" american racing trench, belltech adj. coilovers,
3" lower control arms (front), 3" belltech springs/shocks (back) + 1" blocks, belltech front/rear sway bars,
v-led LED's, HID reverse light mod, gps navigation, back-up camera, alpine 7" flip screen.
kicker 2500.1, kicker 300.1, boss 30 farad cap, 3 12" kicker L7's, inifnity reference mids/highs,
wishlist: boston acoustic pro's, body kit, turbo? hot dangit i love my truck! I'm addicted!
gixxr750 is offline
post #4 of 4 (permalink) Old 08-29-2011, 10:26 PM
Originally Posted by coldsolderjoint View Post
Hello,
Thank You,
coldsolderjoint
Only one thing to add to this is to make sure you get the old (o) ring out of the tube area where it slides in at. Quite easy to overlook, other that it straight forward. Just don't ring the bolts off of the pan.
Colorado Cajun is offline
